查看: 45476|回复: 1
[求助] 【设备树】【gpio子系统】【&gpio1 08 low】【编译报错】
发表于 2021-5-5 15:43:48 | 显示全部楼层 |阅读模式
1火花
请教问题,设备树下面代码,被屏蔽的两行,注册了gpio1 08和09,就会报错,把08和09改成其他引脚,就没问题,请教是什么原因?报错:123.21-23 Bad integer literal '08'
  1. <blockquote>
 楼主| 发表于 2021-5-6 15:57:26 | 显示全部楼层
  1. fsio {
  2.                 pinctrl-name = "default";
  3.                 pinctrl-0 = <&pinctrl_fsio>;
  4.                 compatible = "fsml,fsio";
  5.                 fsio_i1 = <&gpio4 21 GPIO_ACTIVE_LOW>;
  6.                 fsio_i2 = <&gpio4 23 GPIO_ACTIVE_LOW>;
  7.                 fsio_i3 = <&gpio4 25 GPIO_ACTIVE_LOW>;
  8.                 fsio_i4 = <&gpio4 27 GPIO_ACTIVE_LOW>;
  9.                 fsio_o1 = <&gpio1 04 GPIO_ACTIVE_LOW>;
  10.                 fsio_o2 = <&gpio1 02 GPIO_ACTIVE_LOW>;
  11.                 fsio_o3 = <&gpio1 00 GPIO_ACTIVE_LOW>;
  12.                 //fsio_o4 = <&gpio1 08 GPIO_ACTIVE_LOW>;
  13.                 //fsio_fbo1 = <&gpio1 09 GPIO_ACTIVE_LOW>;
  14.                 fsio_fb02 = <&gpio1 03 GPIO_ACTIVE_LOW>;
  15.                 fsio_fb03 = <&gpio4 28 GPIO_ACTIVE_LOW>;
  16.                 fsio_fb04 = <&gpio4 24 GPIO_ACTIVE_LOW>;
  17.                 fsio_led1 = <&gpio3 27 GPIO_ACTIVE_LOW>;
  18.                 fsio_led2 = <&gpio3 26 GPIO_ACTIVE_LOW>;
  19.                 fsio_led3 = <&gpio3 25 GPIO_ACTIVE_LOW>;
  20.                 fsio_led4 = <&gpio3 28 GPIO_ACTIVE_LOW>;
  21.                 fsio_m_en = <&gpio1 06 GPIO_ACTIVE_LOW>;
  22.         };
GMT+8, 2025-4-7 13:31 , Processed in 0.107860 second(s), 22 queries , Gzip On.
