查看: 29288|回复: 3
大佬们,菜鸡求助!
发表于 2021-5-9 10:54:57 | 显示全部楼层 |阅读模式
void delay(unsigned int z)
     unsigned int x,y;
     for(x=z;x>0;x--)
     for(y=1000;y>0;y--);
}   //来个大佬帮忙解释一下这个延时函数吧
          //配置RCC
          * (unsigned int *) 0x40021018 |=(1<<3);
          //配置CRL
         * (unsigned int *) 0x40010C00 &=~((1) << (4*0));
         * (unsigned int *) 0x40010C00 |=((1) << (4*0));
         * (unsigned int *) 0x40010C00 &=~((1) << (4*1));
         * (unsigned int *) 0x40010C00 |=((1) << (4*1));
         * (unsigned int *) 0x40010C00 &=~((1) << (4*5));
         * (unsigned int *) 0x40010C00 |=((1) << (4*5));
             //配置ODR
                  * (unsigned int *) 0x40010C0C &=~(1<<0);  //绿亮
                  delay(500);
                  * (unsigned int *) 0x40010C0C |=(1<<0);   //绿灭
                  delay(500);
                  * (unsigned int *) 0x40010C0C &=~(1<<1);   //蓝亮
                  delay(500);
                 * (unsigned int *) 0x40010C0C |=(1<<1);    //蓝灭
                  delay(500);
                 * (unsigned int *) 0x40010C0C &=~(1<<5);   //红亮
                  delay(500);
                 * (unsigned int *) 0x40010C0C |=(1<<5);     //红灭
                  delay(500);
void SystemInit()
 楼主| 发表于 2021-5-9 10:57:00 | 显示全部楼层
首先,为啥这个程序上电或者刚下载时会先显示白色和紫色,然后才红绿蓝。其次,有大佬帮忙解释一下这个延时函数吗?
 楼主| 发表于 2021-5-9 19:30:51 | 显示全部楼层
救救菜鸡吧
发表于 2021-5-11 09:18:08 | 显示全部楼层
第一层for循环变量每减一次 第二层for就是要减1000次   就是换一种写法 这样延时函数输入参数值字面上可以小些
GMT+8, 2024-11-24 20:03 , Processed in 0.027832 second(s), 23 queries , Gzip On.
