查看: 23519|回复: 2
[其它] 编译内核deb安装包出错
发表于 2021-7-27 15:25:11 | 显示全部楼层 |阅读模式
在内核目录下使用make_deb.sh编译内核deb安装包出现错误,有遇到过的吗?
发表于 2021-7-28 16:36:09 | 显示全部楼层
 楼主| 发表于 2021-7-29 11:22:07 | 显示全部楼层
995346855 发表于 2021-7-28 16:36
参考一下:https://www.firebbs.cn/forum.php?mod=viewthread&tid=29350
编译问题解决,多谢。
但是更新内核的时候有个报错:
root@npi:~# sudo dpkg -i linux-image-4.19.35-carp-imx6_1stable_armhf.deb
Selecting previously unselected package linux-image-4.19.35-carp-imx6.
(Reading database ... 13346 files and directories currently installed.)
Preparing to unpack linux-image-4.19.35-carp-imx6_1stable_armhf.deb ...
Unpacking linux-image-4.19.35-carp-imx6 (1stable) ...
Setting up linux-image-4.19.35-carp-imx6 (1stable) ...
update-initramfs: Generating /boot/initrd.img-4.19.35-carp-imx6
zz-uenv_txt: Updating /boot/uEnv.txt [uname_r=4.19.35-carp-imx6]
mv: cannot stat '/boot/dtbs/4.19.35-carp-imx6/*.dtb': No such file or directory
run-parts: /etc/kernel/postinst.d/zz-uenv_txt exited with return code 1
dpkg: error processing package linux-image-4.19.35-carp-imx6 (--install):
installed linux-image-4.19.35-carp-imx6 package post-installation script subpro
cess returned error exit status 1
Errors were encountered while processing:
重启后用uname查看内核版本似乎是更新成功了,但不知道这个报错是否有其他影响
GMT+8, 2025-4-6 11:55 , Processed in 0.073371 second(s), 27 queries , Gzip On.
