查看: 24666|回复: 3
看视频写GPIO置位复位函数,灯不闪烁,亮一下就灭了
发表于 2021-8-4 21:57:41 来自手机 | 显示全部楼层 |阅读模式
f407的板子,写了GPIO端口的置位复位函数,单独使用都没问题,放进while循环控制led闪烁,led只亮一下然后熄灭,请问各位大佬是啥问题。
麻烦帮看一下,用注释掉的代码运行led闪烁正常。置位复位单独用,能点亮熄灭led。
int main()
        *(unsigned int *)(0x40023830) |= (1<<5);
        GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_6;
        GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_OUT;
        GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_UP;
        GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;
        GPIO_Init(GPIOF,&GPIO_InitStruct);
//                GPIOF->ODR &= ~(1<<6);
//                delay(0x2fffff);
                GPIO_ResetBits(GPIOF,GPIO_Pin_6);
                delay(0xfffff);
                GPIO_SetBits(GPIOF,GPIO_Pin_6);
                delay(0xfffff);
置位复位函数
void GPIO_SetBits(GPIO_TypeDef * GPIOx,uint16_t GPIO_Pin)
        GPIOx->BSRRL = GPIO_Pin;
void GPIO_ResetBits(GPIO_TypeDef * GPIOx,uint16_t GPIO_Pin)
        GPIOx->BSRRH = GPIO_Pin;
发表于 2021-8-5 16:48:29 | 显示全部楼层
把代码贴出来才好分析问题所在。
 楼主| 发表于 2021-8-7 22:47:34 | 显示全部楼层
hansome 发表于 2021-8-5 16:48
把代码贴出来才好分析问题所在。
int main()
//                delay(0x2fffff);
                delay(0xfffff);
                delay(0xfffff);
置位复位函数
发表于 2021-8-9 16:32:46 | 显示全部楼层
int main()
你试着用GPIOF->IDR读取,然后再与上~(1<<6),最后再赋值给GPIOF->ODR。
GMT+8, 2024-11-23 14:59 , Processed in 0.045070 second(s), 24 queries , Gzip On.
