查看: 28980|回复: 1
AD7888读数一直为0
发表于 2021-8-7 11:00:59 | 显示全部楼层 |阅读模式
10火花
有没有大佬用STM32驱动过AD7888,读数一直为0
unsigned int ReadFromAD7888ViaSPI(unsigned char RegValue)
        unsigned int ReceiveData = 0;
        unsigned char ControlValue = 0;
        unsigned int i = 0;
        unsigned int iTemp =0;
        ControlValue = RegValue;
        //Write Control register and Read result data
     GPIO_ResetBits(CS_GPIO_PORT, CS_GPIO_PIN);    //CS=0
     GPIO_ResetBits(SCLK_GPIO_PORT, SCLK_GPIO_PIN);        //SCLK=0
        for(i=0; i<16; i++)
                ReceiveData <<= 1;        //Rotate data
                //write register code
                if(i < 8)
                        if(0x80 == (ControlValue & 0x80)) //1000 0000
                                 GPIO_SetBits(DIN_GPIO_PORT, DIN_GPIO_PIN);// DIN=1
                                 GPIO_ResetBits(DIN_GPIO_PORT, DIN_GPIO_PIN);//DIN=0
                        ControlValue <<= 1;        //Rotate data
                  Delay(1);
                 GPIO_SetBits(SCLK_GPIO_PORT, SCLK_GPIO_PIN);           //SCLK=1
                //read data code
                iTemp = GPIO_ReadInputDataBit(DOUT_GPIO_PORT, DOUT_GPIO_PIN);        //Read SDI of AD7888
                        if(0x00000020 == (iTemp & 0x00000020))                           //DOUT=1
                                ReceiveData |= 1;
                        Delay(1);
         GPIO_SetBits(CS_GPIO_PORT, CS_GPIO_PIN);        //CS=1
        return ReceiveData;
发表于 2021-8-7 13:53:52 | 显示全部楼层
建议先用示波器或者逻辑分析仪看一下模拟的时序对不对。
GMT+8, 2024-11-24 16:27 , Processed in 0.044771 second(s), 22 queries , Gzip On.
