查看: 17604|回复: 5
STM32F407定时器14路输出PWM
发表于 2021-9-6 21:59:41 | 显示全部楼层 |阅读模式
开发板:野火骄阳电机开发板;使用定时器1控制两个直流无刷电机正反差速转。 野火论坛202109062147551443..png 野火论坛202109062148292239..png
通道2、3、4配置一样;
/*Cubemx生成的代码*/
  1. void MX_TIM1_Init(void)
  2. {
  3.   TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  4.   TIM_MasterConfigTypeDef sMasterConfig = {0};
  5.   TIM_OC_InitTypeDef sConfigOC = {0};
  6.   TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
  7.   htim1.Instance = TIM1;
  8.   htim1.Init.Prescaler = 1;
  9.   htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  10.   htim1.Init.Period = 5599;
  11.   htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  12.   htim1.Init.RepetitionCounter = 0;
  13.   htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  14.   if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
  15.   {
  16.     Error_Handler();
  17.   }
  18.   sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  19.   if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
  20.   {
  21.     Error_Handler();
  22.   }
  23.   if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
  24.   {
  25.     Error_Handler();
  26.   }
  27.   sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  28.   sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  29.   if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
  30.   {
  31.     Error_Handler();
  32.   }
  33.   sConfigOC.OCMode = TIM_OCMODE_PWM1;
  34.   sConfigOC.Pulse = 0;
  35.   sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  36.   sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  37.   sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  38.   sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  39.   sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  40.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
  41.   {
  42.     Error_Handler();
  43.   }
  44.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
  45.   {
  46.     Error_Handler();
  47.   }
  48.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
  49.   {
  50.     Error_Handler();
  51.   }
  52.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
  53.   {
  54.     Error_Handler();
  55.   }
  56.   sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
  57.   sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
  58.   sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  59.   sBreakDeadTimeConfig.DeadTime = 0;
  60.   sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  61.   sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  62.   sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
  63.   if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
  64.   {
  65.     Error_Handler();
  66.   }
  67.   HAL_TIM_MspPostInit(&htim1);
  68. }
定时器相关的初始化已在main函数里调用;
控制部分逻辑:
  1. if(DirControl==0xd0)  //向前
  2.                                         {
  3.                                           TIM1->CCR1 = Robot.leftSpeedOut;
  4.                                                 TIM1->CCR2 = 0;
  5.                                                 TIM1->CCR3 = Robot.rightSpeedOut;
  6.                                                 TIM1->CCR4 = 0;
  7.                                   }
  8.                                   if(DirControl==0xb0) //向后
  9.                                         {
  10.                                                 TIM1->CCR1 = 0;
  11.                                           TIM1->CCR2 = Robot.leftSpeedOut;
  12.                                                 TIM1->CCR3 = 0;
  13.                                           TIM1->CCR4 = Robot.rightSpeedOut;
  14.                                         }
  15.                                         if(DirControl==0x0d) //原地向右
  16.                                         {
  17.                                           TIM1->CCR1 = Robot.leftSpeedOut;
  18.                                           TIM1->CCR2 = 0;
  19.                                                 TIM1->CCR3 = 0;
  20.                                           TIM1->CCR4 = Robot.rightSpeedOut;
  21.                                         }
  22.                                         if(DirControl==0x0b) //原地向左
  23.                                         {
  24.                                           TIM1->CCR1 = 0;
  25.                                                 TIM1->CCR2 = Robot.leftSpeedOut;
  26.                                                 TIM1->CCR3 = Robot.rightSpeedOut;
  27.                                                 TIM1->CCR4 = 0;
  28.                                   }
  29.                                         if(DirControl==0xdd) //向前向右
  30.                                         {
  31.                                                 TIM1->CCR1 = Robot.leftSpeedOut;
  32.                                                 TIM1->CCR2 = 0;
  33.                                                 TIM1->CCR3 = Robot.rightSpeedOut/5;
  34.                                                 TIM1->CCR4 = 0;
  35.                                         }
  36.                                         if(DirControl==0xdb) //向前向左
  37.                                         {
  38.                                                 TIM1->CCR1 = Robot.leftSpeedOut/5;
  39.                                                 TIM1->CCR2 = 0;
  40.                                                 TIM1->CCR3 = Robot.rightSpeedOut;
  41.                                                 TIM1->CCR4 = 0;
  42.                                         }
  43.                                         if(DirControl==0xbd) //向后向右
  44.                                         {
  45.                                                 TIM1->CCR1 = 0;
  46.                                           TIM1->CCR2 = Robot.leftSpeedOut;
  47.                                                 TIM1->CCR3 = 0;
  48.                                           TIM1->CCR4 = Robot.rightSpeedOut/5;
  49.                                         }
  50.                                         if(DirControl==0xbb) //向后向左
  51.                                         {
  52.                                                 TIM1->CCR1 = 0;
  53.                                           TIM1->CCR2 = Robot.leftSpeedOut/5;
  54.                                                 TIM1->CCR3 = 0;
  55.                                           TIM1->CCR4 = Robot.rightSpeedOut;
  56.                                         }
控制中,向前、向后、原地向左、原地向右都是正常的,当CCR的值一样时都没问题
问题就来了差速的时候,也就是向前向左、右,后退向左、右,此时就一个电机转,也就是只有一路PWM波输出,但是CCR的值都写进去了,一个5500,一个1100时,只有5500的那个电机转了,1100的无输出;
然后将代码移植到STM32F103RCT6中,全部控制指令都正常;但是在STM32F407IGT6骄阳开发板中,就出现以上问题。
 楼主| 发表于 2021-9-6 22:02:23 | 显示全部楼层
  1. /* TIM1 init function */
  2. void MX_TIM1_Init(void)
  3. {
  4.   TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  5.   TIM_MasterConfigTypeDef sMasterConfig = {0};
  6.   TIM_OC_InitTypeDef sConfigOC = {0};
  7.   TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
  8.   htim1.Instance = TIM1;
  9.   htim1.Init.Prescaler = 1;
  10.   htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  11.   htim1.Init.Period = 5599;
  12.   htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  13.   htim1.Init.RepetitionCounter = 0;
  14.   htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  15.   if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
  16.   {
  17.     Error_Handler();
  18.   }
  19.   sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  20.   if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
  21.   {
  22.     Error_Handler();
  23.   }
  24.   if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
  25.   {
  26.     Error_Handler();
  27.   }
  28.   sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  29.   sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  30.   if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
  31.   {
  32.     Error_Handler();
  33.   }
  34.   sConfigOC.OCMode = TIM_OCMODE_PWM1;
  35.   sConfigOC.Pulse = 0;
  36.   sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  37.   sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  38.   sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  39.   sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  40.   sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  41.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
  42.   {
  43.     Error_Handler();
  44.   }
  45.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
  46.   {
  47.     Error_Handler();
  48.   }
  49.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
  50.   {
  51.     Error_Handler();
  52.   }
  53.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
  54.   {
  55.     Error_Handler();
  56.   }
  57.   sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
  58.   sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
  59.   sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  60.   sBreakDeadTimeConfig.DeadTime = 0;
  61.   sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  62.   sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  63.   sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
  64.   if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
  65.   {
  66.     Error_Handler();
  67.   }
  68.   HAL_TIM_MspPostInit(&htim1);
  69. }
 楼主| 发表于 2021-9-6 22:03:15 | 显示全部楼层
                                                TIM1->CCR2 = 0;
                                                TIM1->CCR4 = 0;
                                                TIM1->CCR1 = 0;
                                                TIM1->CCR3 = 0;
                                          TIM1->CCR2 = 0;
                                                TIM1->CCR3 = 0;
                                          TIM1->CCR1 = 0;
                                                TIM1->CCR4 = 0;
                                                TIM1->CCR2 = 0;
                                                TIM1->CCR4 = 0;
                                                TIM1->CCR2 = 0;
                                                TIM1->CCR4 = 0;
                                                TIM1->CCR1 = 0;
                                                TIM1->CCR3 = 0;
                                                TIM1->CCR1 = 0;
                                                TIM1->CCR3 = 0;
 楼主| 发表于 2021-9-6 22:04:51 | 显示全部楼层
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
发表于 2021-9-7 09:52:46 | 显示全部楼层
cubeMX工程芯片设置的STM32F407 ? 可能F4配置上有些问题
发表于 2021-9-7 11:30:46 | 显示全部楼层
日常活跃,求积分,我要上初中
GMT+8, 2024-9-27 06:04 , Processed in 0.035494 second(s), 25 queries , Gzip On.
