查看: 18600|回复: 2
[求助] arm-none-eabi-gcc cps相关 出错
发表于 2021-9-10 10:02:02 | 显示全部楼层 |阅读模式
如题,编译例程,也是出错,如果拿掉cps相关的则OK。
这个是安装少了什么吗?
sources/project/start.s: Assembler messages:
sources/project/start.s:16: Error: selected processor does not support `cpsid i' in ARM mode
sources/project/start.s:19: Error: selected processor does not support `cps #0x12' in ARM mode
sources/project/start.s:32: Error: selected processor does not support `cps #0x13' in ARM mode
sources/project/start.s:36: Error: selected processor does not support `cpsie i' in ARM mode
make: *** [Makefile:46:build/start.o] 错误 1
发表于 2021-9-10 16:37:04 | 显示全部楼层
错误提示很明显,你编译的芯片类型不支持上面几个指令,你需要查查具体指令集
发表于 2021-9-11 00:35:52 | 显示全部楼层
gcc编译器版本问题,安装回Ubuntu18版本的就可以了,里面自带gcc-7版本的
GMT+8, 2024-11-23 19:00 , Processed in 0.025297 second(s), 23 queries , Gzip On.
