查看: 7734|回复: 2
MUP6050串口正常,但上位机没反应是怎么回事啊
发表于 2021-9-22 21:44:01 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
#include "stm32f10x_it.h"
#include "led.h"
#include "key.h"
#include "delay.h"
#include "timer.h"
#include "usart.h"
#include "i2c.h"
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include "cJSON.h"
#include "rtc.h"
#include "spi_flash.h"
#include "SysTick.h"
#include "exti.h"
//设置是否使用LCD进行显示,不需要的话把这个宏注释掉即可
//#define USE_LCD_DISPLAY
#ifdef USE_LCD_DISPLAY
    #include "ili9341_lcd.h"
#endif
#include "mltypes.h"
#include "inv_mpu_dmp_motion_driver.h"
#include "log.h"
#include "invensense.h"
#include "invensense_adv.h"
#include "eMPL_outputs.h"
#include "mpu.h"
#include "inv_mpu.h"
#include "log.h"
#include "packet.h"
#define TASK_ENABLE 0
extern unsigned int Task_Delay[NumOfTask];
/* Private typedef -----------------------------------------------------------*/
/* Data read from MPL. */
#define PRINT_ACCEL     (0x01)
#define PRINT_GYRO      (0x02)
#define PRINT_QUAT      (0x04)
#define PRINT_COMPASS   (0x08)
#define PRINT_EULER     (0x10)
#define PRINT_ROT_MAT   (0x20)
#define PRINT_HEADING   (0x40)
#define PRINT_PEDO      (0x80)
#define PRINT_LINEAR_ACCEL (0x100)
#define PRINT_GRAVITY_VECTOR (0x200)
volatile uint32_t hal_timestamp = 0;
#define ACCEL_ON        (0x01)
#define GYRO_ON         (0x02)
#define COMPASS_ON      (0x04)
#define MOTION          (0)
#define NO_MOTION       (1)
/* Starting sampling rate. */
#define DEFAULT_MPU_HZ  (20)
#define FLASH_SIZE      (512)
#define FLASH_MEM_START ((void*)0x1800)
#define PEDO_READ_MS    (1000)
#define TEMP_READ_MS    (500)
#define COMPASS_READ_MS (100)
struct rx_s {
    unsigned char header[3];
    unsigned char cmd;
struct hal_s {
    unsigned char lp_accel_mode;
    unsigned char sensors;
    unsigned char dmp_on;
    unsigned char wait_for_tap;
    volatile unsigned char new_gyro;
    unsigned char motion_int_mode;
    unsigned long no_dmp_hz;
    unsigned long next_pedo_ms;
    unsigned long next_temp_ms;
    unsigned long next_compass_ms;
    unsigned int report;
    unsigned short dmp_features;
    struct rx_s rx;
static struct hal_s hal = {0};
/* Every time new gyro data is available, this function is called in an
* ISR context. In this example, it sets a flag protecting the FIFO read
* function.
/* USB RX binary semaphore. Actually, it's just a flag. Not included in struct
* because it's declared extern elsewhere.
volatile unsigned char rx_new;
unsigned char *mpl_key = (unsigned char*)"eMPL 5.1";
/* Platform-specific information. Kinda like a boardfile. */
struct platform_data_s {
    signed char orientation[9];
/* The sensors can be mounted onto the board in any orientation. The mounting
* matrix seen below tells the MPL how to rotate the raw data from the
* driver(s).
* TODO: The following matrices refer to the configuration on internal test
* boards at Invensense. If needed, please modify the matrices to match the
* chip-to-body matrix for your particular set up.
static struct platform_data_s gyro_pdata = {
         .orientation = { 1, 0, 0,
                     0, 1, 0,
                     0, 0, 1}
#if defined MPU9150 || defined MPU9250
static struct platform_data_s compass_pdata = {
    .orientation = { 0, 1, 0,
                     1, 0, 0,
                     0, 0, -1}
#define COMPASS_ENABLED 1
#elif defined AK8975_SECONDARY
    .orientation = {-1, 0, 0,
                     0, 1, 0,
                     0, 0,-1}
#elif defined AK8963_SECONDARY
                     0,-1, 0,
                     0, 0, 1}
#endif
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
#define BYTE0(dwTemp)       (*(char *)(&dwTemp))
#define BYTE1(dwTemp)       (*((char *)(&dwTemp) + 1))
#define BYTE2(dwTemp)       (*((char *)(&dwTemp) + 2))
#define BYTE3(dwTemp)       (*((char *)(&dwTemp) + 3))
  * @brief  控制串口发送1个字符
  * @param  c:要发送的字符
  * @retval none
void usart_send_char(uint8_t c)
    while(USART_GetFlagStatus(USART_DEBUG,USART_FLAG_TXE)==RESET); //循环发送,直到发送完毕
    USART_SendData(USART_DEBUG,c);
/*函数功能:根据匿名最新上位机协议写的显示姿态的程序(上位机0512版本)
*具体协议说明请查看上位机软件的帮助说明。
void Data_Send_Status(float Pitch,float Roll,float Yaw)
    unsigned char i=0;
    unsigned char _cnt=0,sum = 0;
    unsigned int _temp;
    u8 data_to_send[50];
    data_to_send[_cnt++]=0xAA;
    data_to_send[_cnt++]=0x01;
    data_to_send[_cnt++]=0;
    _temp = (int)(Roll*100);
    data_to_send[_cnt++]=BYTE1(_temp);
    data_to_send[_cnt++]=BYTE0(_temp);
    _temp = 0-(int)(Pitch*100);
    _temp = (int)(Yaw*100);
    _temp = 0;
    data_to_send[_cnt++]=BYTE3(_temp);
    data_to_send[_cnt++]=BYTE2(_temp);
    data_to_send[_cnt++]=0xA0;
    data_to_send[3] = _cnt-4;
    //和校验
    for(i=0;i<_cnt;i++)
        sum+= data_to_send;
    data_to_send[_cnt++]=sum;
    //串口发送数据
    for(i=0;i<_cnt;i++)
        usart_send_char(data_to_send);
/*函数功能:根据匿名最新上位机协议写的显示传感器数据(上位机0512版本)
void Send_Data(int16_t *Gyro,int16_t *Accel)
    unsigned char i=0;
//    unsigned int _temp;
    data_to_send[_cnt++]=0x02;
    data_to_send[_cnt++]=BYTE1(Accel[0]);
    data_to_send[_cnt++]=BYTE0(Accel[0]);
    data_to_send[_cnt++]=BYTE1(Accel[1]);
    data_to_send[_cnt++]=BYTE0(Accel[1]);
    data_to_send[_cnt++]=BYTE1(Accel[2]);
    data_to_send[_cnt++]=BYTE0(Accel[2]);
    data_to_send[_cnt++]=BYTE1(Gyro[0]);
    data_to_send[_cnt++]=BYTE0(Gyro[0]);
    data_to_send[_cnt++]=BYTE1(Gyro[1]);
    data_to_send[_cnt++]=BYTE0(Gyro[1]);
    data_to_send[_cnt++]=BYTE1(Gyro[2]);
    data_to_send[_cnt++]=BYTE0(Gyro[2]);
    //和校验
    for(i=0;i<_cnt;i++)
        sum+= data_to_send;
    //串口发送数据
    for(i=0;i<_cnt;i++)
extern struct inv_sensor_cal_t sensors;
/* Get data from MPL.
* TODO: Add return values to the inv_get_sensor_type_xxx APIs to differentiate
* between new and stale data.
static void read_from_mpl(void)
    long msg, data[9];
    int8_t accuracy;
    unsigned long timestamp;
    float float_data[3] = {0};
    MPU_DEBUG_FUNC();
    if (inv_get_sensor_type_quat(data, &accuracy, (inv_time_t*)×tamp)) {
       /* Sends a quaternion packet to the PC. Since this is used by the Python
        * test app to visually represent a 3D quaternion, it's sent each time
        * the MPL has new data.
        eMPL_send_quat(data);
        /* Specific data packets can be sent or suppressed using USB commands. */
        if (hal.report & PRINT_QUAT)
            eMPL_send_data(PACKET_DATA_QUAT, data);
    if (hal.report & PRINT_ACCEL) {
        if (inv_get_sensor_type_accel(data, &accuracy,
            eMPL_send_data(PACKET_DATA_ACCEL, data);
    if (hal.report & PRINT_GYRO) {
        if (inv_get_sensor_type_gyro(data, &accuracy,
            eMPL_send_data(PACKET_DATA_GYRO, data);
#ifdef COMPASS_ENABLED
    if (hal.report & PRINT_COMPASS) {
        if (inv_get_sensor_type_compass(data, &accuracy,
            eMPL_send_data(PACKET_DATA_COMPASS, data);
#endif
    if (hal.report & PRINT_EULER) {
        if (inv_get_sensor_type_euler(data, &accuracy,
            eMPL_send_data(PACKET_DATA_EULER, data);
        /*********发送数据到匿名四轴上位机**********/
    if(1)
                    char cStr [ 70 ];
                #endif
                unsigned long timestamp,step_count,walk_time;
                /*获取欧拉角*/
              if (inv_get_sensor_type_euler(data, &accuracy,(inv_time_t*)×tamp))
                            float Pitch,Roll,Yaw;
                            Pitch =data[0]*1.0/(1<<16) ;
                            Roll = data[1]*1.0/(1<<16);
                            Yaw = data[2]*1.0/(1<<16);
                            /*向匿名上位机发送姿态*/
                            Data_Send_Status(Pitch,Roll,Yaw);
                            /*向匿名上位机发送原始数据*/
                            Send_Data((int16_t *)&sensors.gyro.raw,(int16_t *)&sensors.accel.raw);
                                sprintf ( cStr, "Pitch :   %.4f   ",Pitch );    //inv_get_sensor_type_euler读出的数据是Q16格式,所以左移16位.
                                ILI9341_DispString_EN(30,90,cStr);
                                sprintf ( cStr, "Roll :   %.4f   ", Roll );    //inv_get_sensor_type_euler读出的数据是Q16格式,所以左移16位.
                                ILI9341_DispString_EN(30,110,cStr);
                                sprintf ( cStr, "Yaw :   %.4f   ", Yaw );    //inv_get_sensor_type_euler读出的数据是Q16格式,所以左移16位.
                                ILI9341_DispString_EN(30,130,cStr);
                                /*温度*/
                                mpu_get_temperature(data,(inv_time_t*)×tamp);
                                sprintf ( cStr, "Temperature :   %.2f   ", data[0]*1.0/(1<<16) );    //inv_get_sensor_type_euler读出的数据是Q16格式,所以左移16位.
                                ILI9341_DispString_EN(30,150,cStr);
                            #endif
                    /*获取步数*/
                get_tick_count(×tamp);
                if (timestamp > hal.next_pedo_ms) {
                        hal.next_pedo_ms = timestamp + PEDO_READ_MS;
                        dmp_get_pedometer_step_count(&step_count);
                        dmp_get_pedometer_walk_time(&walk_time);
                            sUsartPrintf(USART_DEBUG,cStr, "Walked steps :  %ld  steps over  %ld  milliseconds..",step_count,walk_time);
                            ILI9341_DispString_EN(0,180,cStr);
                        #endif
    if (hal.report & PRINT_ROT_MAT) {
        if (inv_get_sensor_type_rot_mat(data, &accuracy,
            eMPL_send_data(PACKET_DATA_ROT, data);
    if (hal.report & PRINT_HEADING) {
        if (inv_get_sensor_type_heading(data, &accuracy,
            eMPL_send_data(PACKET_DATA_HEADING, data);
    if (hal.report & PRINT_LINEAR_ACCEL) {
        if (inv_get_sensor_type_linear_acceleration(float_data, &accuracy, (inv_time_t*)×tamp)) {
            MPL_LOGI("Linear Accel: %7.5f %7.5f %7.5f\r\n",
                    float_data[0], float_data[1], float_data[2]);
    if (hal.report & PRINT_GRAVITY_VECTOR) {
            if (inv_get_sensor_type_gravity(float_data, &accuracy,
                MPL_LOGI("Gravity Vector: %7.5f %7.5f %7.5f\r\n",
    if (hal.report & PRINT_PEDO) {
            unsigned long step_count, walk_time;
            MPL_LOGI("Walked %ld steps over %ld milliseconds..\n", step_count,
            walk_time);
    /* Whenever the MPL detects a change in motion state, the application can
     * be notified. For this example, we use an LED to represent the current
     * motion state.
    msg = inv_get_message_level_0(INV_MSG_MOTION_EVENT |
            INV_MSG_NO_MOTION_EVENT);
    if (msg) {
        if (msg & INV_MSG_MOTION_EVENT) {
            MPL_LOGI("Motion!\n");
        } else if (msg & INV_MSG_NO_MOTION_EVENT) {
            MPL_LOGI("No motion!\n");
void send_status_compass() {
    long data[3] = { 0 };
    int8_t accuracy = { 0 };
    inv_get_compass_set(data, &accuracy, (inv_time_t*) ×tamp);
    MPL_LOGI("Compass: %7.4f %7.4f %7.4f ",
            data[0]/65536.f, data[1]/65536.f, data[2]/65536.f);
    MPL_LOGI("Accuracy= %d\r\n", accuracy);
#endif
/* Handle sensor on/off combinations. */
static void setup_gyro(void)
    unsigned char mask = 0, lp_accel_was_on = 0;
    MPU_DEBUG_FUNC();
    if (hal.sensors & ACCEL_ON)
        mask |= INV_XYZ_ACCEL;
    if (hal.sensors & GYRO_ON) {
        mask |= INV_XYZ_GYRO;
        lp_accel_was_on |= hal.lp_accel_mode;
    if (hal.sensors & COMPASS_ON) {
        mask |= INV_XYZ_COMPASS;
#endif
    /* If you need a power transition, this function should be called with a
     * mask of the sensors still enabled. The driver turns off any sensors
     * excluded from this mask.
    mpu_set_sensors(mask);
    mpu_configure_fifo(mask);
    if (lp_accel_was_on) {
        unsigned short rate;
        hal.lp_accel_mode = 0;
        /* Switching out of LP accel, notify MPL of new accel sampling rate. */
        mpu_get_sample_rate(&rate);
        inv_set_accel_sample_rate(1000000L / rate);
static void tap_cb(unsigned char direction, unsigned char count)
    MPU_DEBUG_FUNC();
    switch (direction) {
    case TAP_X_UP:
        MPL_LOGI("Tap X+ ");
        break;
    case TAP_X_DOWN:
        MPL_LOGI("Tap X- ");
        break;
    case TAP_Y_UP:
        MPL_LOGI("Tap Y+ ");
        break;
    case TAP_Y_DOWN:
        MPL_LOGI("Tap Y- ");
        break;
    case TAP_Z_UP:
        MPL_LOGI("Tap Z+ ");
        break;
    case TAP_Z_DOWN:
        MPL_LOGI("Tap Z- ");
        break;
    default:
        return;
    MPL_LOGI("x%d\n", count);
    return;
static void android_orient_cb(unsigned char orientation)
    MPU_DEBUG_FUNC();
    switch (orientation) {
    case ANDROID_ORIENT_PORTRAIT:
        MPL_LOGI("Portrait\n");
        break;
    case ANDROID_ORIENT_LANDSCAPE:
        MPL_LOGI("Landscape\n");
        break;
    case ANDROID_ORIENT_REVERSE_PORTRAIT:
        MPL_LOGI("Reverse Portrait\n");
        break;
    case ANDROID_ORIENT_REVERSE_LANDSCAPE:
        MPL_LOGI("Reverse Landscape\n");
        break;
    default:
        return;
static inline void run_self_test(void)
    int result;
    long gyro[3], accel[3];
    MPU_DEBUG_FUNC();
#if defined (MPU6500) || defined (MPU9250)
    result = mpu_run_6500_self_test(gyro, accel, 0);
#elif defined (MPU6050) || defined (MPU9150)
    result = mpu_run_self_test(gyro, accel);
#endif
    if (result == 0x7) {
    MPL_LOGI("Passed!\n");
        MPL_LOGI("accel: %7.4f %7.4f %7.4f\n",
                    accel[0]/65536.f,
                    accel[1]/65536.f,
                    accel[2]/65536.f);
        MPL_LOGI("gyro: %7.4f %7.4f %7.4f\n",
                    gyro[0]/65536.f,
                    gyro[1]/65536.f,
                    gyro[2]/65536.f);
        /* Test passed. We can trust the gyro data here, so now we need to update calibrated data*/
#ifdef USE_CAL_HW_REGISTERS
         * This portion of the code uses the HW offset registers that are in the MPUxxxx devices
         * instead of pushing the cal data to the MPL software library
        unsigned char i = 0;
        for(i = 0; i<3; i++) {
            gyro = (long)(gyro * 32.8f); //convert to +-1000dps
            accel *= 2048.f; //convert to +-16G
            accel = accel >> 16;
            gyro = (long)(gyro >> 16);
        mpu_set_gyro_bias_reg(gyro);
        mpu_set_accel_bias_6500_reg(accel);
        mpu_set_accel_bias_6050_reg(accel);
#endif
#else
        /* Push the calibrated data to the MPL library.
         * MPL expects biases in hardware units << 16, but self test returns
         * biases in g's << 16.
        unsigned short accel_sens;
        float gyro_sens;
        mpu_get_accel_sens(&accel_sens);
        accel[0] *= accel_sens;
        accel[1] *= accel_sens;
        accel[2] *= accel_sens;
        inv_set_accel_bias(accel, 3);
        mpu_get_gyro_sens(&gyro_sens);
        gyro[0] = (long) (gyro[0] * gyro_sens);
        gyro[1] = (long) (gyro[1] * gyro_sens);
        gyro[2] = (long) (gyro[2] * gyro_sens);
        inv_set_gyro_bias(gyro, 3);
#endif
    else {
            if (!(result & 0x1))
                MPL_LOGE("Gyro failed.\n");
            if (!(result & 0x2))
                MPL_LOGE("Accel failed.\n");
            if (!(result & 0x4))
                MPL_LOGE("Compass failed.\n");
static void handle_input(void)
    char c = USART_ReceiveData(USART_DEBUG);
    MPU_DEBUG_FUNC();
    switch (c) {
    /* These commands turn off individual sensors. */
    case '8':
        hal.sensors ^= ACCEL_ON;
        setup_gyro();
        if (!(hal.sensors & ACCEL_ON))
            inv_accel_was_turned_off();
        break;
    case '9':
        hal.sensors ^= GYRO_ON;
        setup_gyro();
        if (!(hal.sensors & GYRO_ON))
            inv_gyro_was_turned_off();
        break;
    case '0':
        hal.sensors ^= COMPASS_ON;
        setup_gyro();
        if (!(hal.sensors & COMPASS_ON))
            inv_compass_was_turned_off();
        break;
#endif
    /* The commands send individual sensor data or fused data to the PC. */
    case 'a':
        hal.report ^= PRINT_ACCEL;
        break;
    case 'g':
        hal.report ^= PRINT_GYRO;
        break;
    case 'c':
        hal.report ^= PRINT_COMPASS;
        break;
#endif
    case 'e':
        hal.report ^= PRINT_EULER;
        break;
    case 'r':
        hal.report ^= PRINT_ROT_MAT;
        break;
    case 'q':
        hal.report ^= PRINT_QUAT;
        break;
    case 'h':
        hal.report ^= PRINT_HEADING;
        break;
    case 'i':
        hal.report ^= PRINT_LINEAR_ACCEL;
        break;
    case 'o':
        hal.report ^= PRINT_GRAVITY_VECTOR;
        break;
    case 'w':
        send_status_compass();
        break;
#endif
    /* This command prints out the value of each gyro register for debugging.
     * If logging is disabled, this function has no effect.
    case 'd':
        mpu_reg_dump();
        break;
    /* Test out low-power accel mode. */
    case 'p':
        if (hal.dmp_on)
            /* LP accel is not compatible with the DMP. */
            break;
        mpu_lp_accel_mode(20);
        /* When LP accel mode is enabled, the driver automatically configures
         * the hardware for latched interrupts. However, the MCU sometimes
         * misses the rising/falling edge, and the hal.new_gyro flag is never
         * set. To avoid getting locked in this state, we're overriding the
         * driver's configuration and sticking to unlatched interrupt mode.
         * TODO: The MCU supports level-triggered interrupts.
        mpu_set_int_latched(0);
        hal.sensors &= ~(GYRO_ON|COMPASS_ON);
        hal.sensors |= ACCEL_ON;
        hal.lp_accel_mode = 1;
        break;
    /* The hardware self test can be run without any interaction with the
     * MPL since it's completely localized in the gyro driver. Logging is
     * assumed to be enabled; otherwise, a couple LEDs could probably be used
     * here to display the test results.
    case 't':
        run_self_test();
        /* Let MPL know that contiguity was broken. */
        break;
    /* Depending on your application, sensor data may be needed at a faster or
     * slower rate. These commands can speed up or slow down the rate at which
     * the sensor data is pushed to the MPL.
     * In this example, the compass rate is never changed.
    case '1':
        if (hal.dmp_on) {
            dmp_set_fifo_rate(10);
            inv_set_quat_sample_rate(100000L);
        } else
            mpu_set_sample_rate(10);
        inv_set_gyro_sample_rate(100000L);
        inv_set_accel_sample_rate(100000L);
        break;
    case '2':
        if (hal.dmp_on) {
            dmp_set_fifo_rate(20);
            inv_set_quat_sample_rate(50000L);
        } else
            mpu_set_sample_rate(20);
        inv_set_gyro_sample_rate(50000L);
        inv_set_accel_sample_rate(50000L);
        break;
    case '3':
        if (hal.dmp_on) {
            dmp_set_fifo_rate(40);
            inv_set_quat_sample_rate(25000L);
        } else
            mpu_set_sample_rate(40);
        inv_set_gyro_sample_rate(25000L);
        inv_set_accel_sample_rate(25000L);
        break;
    case '4':
        if (hal.dmp_on) {
            dmp_set_fifo_rate(50);
            inv_set_quat_sample_rate(20000L);
        } else
            mpu_set_sample_rate(50);
        inv_set_gyro_sample_rate(20000L);
        inv_set_accel_sample_rate(20000L);
        break;
    case '5':
        if (hal.dmp_on) {
            dmp_set_fifo_rate(100);
            inv_set_quat_sample_rate(10000L);
        } else
            mpu_set_sample_rate(100);
        inv_set_gyro_sample_rate(10000L);
        inv_set_accel_sample_rate(10000L);
        break;
    case ',':
        /* Set hardware to interrupt on gesture event only. This feature is
         * useful for keeping the MCU asleep until the DMP detects as a tap or
         * orientation event.
        dmp_set_interrupt_mode(DMP_INT_GESTURE);
        break;
    case '.':
        /* Set hardware to interrupt periodically. */
        dmp_set_interrupt_mode(DMP_INT_CONTINUOUS);
        break;
    case '6':
        /* Toggle pedometer display. */
        hal.report ^= PRINT_PEDO;
        break;
    case '7':
        /* Reset pedometer. */
        dmp_set_pedometer_step_count(0);
        dmp_set_pedometer_walk_time(0);
        break;
    case 'f':
        if (hal.lp_accel_mode)
            return;
        /* Toggle DMP. */
        if (hal.dmp_on) {
            unsigned short dmp_rate;
            unsigned char mask = 0;
            hal.dmp_on = 0;
            mpu_set_dmp_state(0);
            /* Restore FIFO settings. */
            /* When the DMP is used, the hardware sampling rate is fixed at
             * 200Hz, and the DMP is configured to downsample the FIFO output
             * using the function dmp_set_fifo_rate. However, when the DMP is
             * turned off, the sampling rate remains at 200Hz. This could be
             * handled in inv_mpu.c, but it would need to know that
             * inv_mpu_dmp_motion_driver.c exists. To avoid this, we'll just
             * put the extra logic in the application layer.
            dmp_get_fifo_rate(&dmp_rate);
            mpu_set_sample_rate(dmp_rate);
            inv_quaternion_sensor_was_turned_off();
            MPL_LOGI("DMP disabled.\n");
        } else {
            unsigned short sample_rate;
            hal.dmp_on = 1;
            /* Preserve current FIFO rate. */
            mpu_get_sample_rate(&sample_rate);
            dmp_set_fifo_rate(sample_rate);
            inv_set_quat_sample_rate(1000000L / sample_rate);
            mpu_set_dmp_state(1);
            MPL_LOGI("DMP enabled.\n");
        break;
    case 'm':
        /* Test the motion interrupt hardware feature. */
    #ifndef MPU6050 // not enabled for 6050 product
    hal.motion_int_mode = 1;
    #endif
        break;
    case 'v':
        /* Toggle LP quaternion.
         * The DMP features can be enabled/disabled at runtime. Use this same
         * approach for other features.
        hal.dmp_features ^= DMP_FEATURE_6X_LP_QUAT;
        dmp_enable_feature(hal.dmp_features);
        if (!(hal.dmp_features & DMP_FEATURE_6X_LP_QUAT)) {
            MPL_LOGI("LP quaternion disabled.\n");
        } else
            MPL_LOGI("LP quaternion enabled.\n");
        break;
    default:
        break;
    hal.rx.cmd = 0;
void gyro_data_ready_cb(void)
    hal.new_gyro = 1;
    inv_error_t result;
    unsigned char accel_fsr,  new_temp = 0;
    unsigned short gyro_rate, gyro_fsr;
    struct int_param_s int_param;
    LED_Init();   //LED初始化
    KEY_Init();        //按键初始化
    delay_init();             //延时函数初始化
    RTC_Init();              //RTC时钟初始化
    delay_ms(500);
    Usart1_Init(115200);//115200波特率 debug串口
    Usart2_Init(115200);//115200波特率 与JAVA通讯串口
    Usart3_Init(115200);
    TIM2_Int_Init(4999,7199);
    TIM3_Int_Init(2499,7199);
    ILI9341_Init ();         //LCD 初始化
  ILI9341_GramScan ( 6 );
    LCD_SetFont(&Font8x16);
    LCD_SetColors(RED,BLACK);
#endif
    //初始化systick
    SysTick_Init();
    SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk;
    //MPU6050中断引脚
    EXTI_Pxy_Config();
    //I2C初始化
    I2C_Bus_Init();
  ILI9341_Clear ( 0, 0, 240, 320);
  ILI9341_DispString_EN ( 20, 20, "This is a MPU6050 demo" );
#endif
UsartPrintf(USART_DEBUG,"mpu 6050 test start");
    result = mpu_init(&int_param);
      if (result) {
            LED0 = 0;
          MPL_LOGE("Could not initialize gyro.result =  %d\n",result);
                LCD_SetColors(BLUE,BLACK);
                ILI9341_DispString_EN ( 0, 40, "No MPU6050 detceted!Please check the hardware connection.");
            #endif
            LED1 = 0;
                ILI9341_DispString_EN(30,40,"MPU6050 decteted!");
            #endif
     /* If you're not using an MPU9150 AND you're not using DMP features, this
     * function will place all slaves on the primary bus.
     * mpu_set_bypass(1);
      result = inv_init_mpl();
      if (result) {
          MPL_LOGE("Could not initialize MPL.\n");
      /* Compute 6-axis and 9-axis quaternions. */
    inv_enable_quaternion();
    inv_enable_9x_sensor_fusion();
    /* The MPL expects compass data at a constant rate (matching the rate
     * passed to inv_set_compass_sample_rate). If this is an issue for your
     * application, call this function, and the MPL will depend on the
     * timestamps passed to inv_build_compass instead.
     * inv_9x_fusion_use_timestamps(1);
    /* This function has been deprecated.
     * inv_enable_no_gyro_fusion();
    /* Update gyro biases when not in motion.
     * WARNING: These algorithms are mutually exclusive.
    inv_enable_fast_nomot();
    /* inv_enable_motion_no_motion(); */
    /* inv_set_no_motion_time(1000); */
    /* Update gyro biases when temperature changes. */
    inv_enable_gyro_tc();
    /* This algorithm updates the accel biases when in motion. A more accurate
     * bias measurement can be made when running the self-test (see case 't' in
     * handle_input), but this algorithm can be enabled if the self-test can't
     * be executed in your application.
     * inv_enable_in_use_auto_calibration();
    /* Compass calibration algorithms. */
    inv_enable_vector_compass_cal();
    inv_enable_magnetic_disturbance();
#endif
    /* If you need to estimate your heading before the compass is calibrated,
     * enable this algorithm. It becomes useless after a good figure-eight is
     * detected, so we'll just leave it out to save memory.
     * inv_enable_heading_from_gyro();
    /* Allows use of the MPL APIs in read_from_mpl. */
    inv_enable_eMPL_outputs();
  result = inv_start_mpl();
  if (result == INV_ERROR_NOT_AUTHORIZED) {
      while (1) {
          MPL_LOGE("Not authorized.\n");
  if (result) {
      MPL_LOGE("Could not start the MPL.\n");
    /* Get/set hardware configuration. Start gyro. */
    /* Wake up all sensors. */
    mpu_set_sensors(INV_XYZ_GYRO | INV_XYZ_ACCEL | INV_XYZ_COMPASS);
#else
    mpu_set_sensors(INV_XYZ_GYRO | INV_XYZ_ACCEL);
#endif
    /* Push both gyro and accel data into the FIFO. */
    mpu_configure_fifo(INV_XYZ_GYRO | INV_XYZ_ACCEL);
    mpu_set_sample_rate(DEFAULT_MPU_HZ);
    /* The compass sampling rate can be less than the gyro/accel sampling rate.
     * Use this function for proper power management.
    mpu_set_compass_sample_rate(1000 / COMPASS_READ_MS);
#endif
    /* Read back configuration in case it was set improperly. */
    mpu_get_sample_rate(&gyro_rate);
    mpu_get_gyro_fsr(&gyro_fsr);
    mpu_get_accel_fsr(&accel_fsr);
    mpu_get_compass_fsr(&compass_fsr);
#endif
    /* Sync driver configuration with MPL. */
    /* Sample rate expected in microseconds. */
    inv_set_gyro_sample_rate(1000000L / gyro_rate);
    inv_set_accel_sample_rate(1000000L / gyro_rate);
    /* The compass rate is independent of the gyro and accel rates. As long as
     * inv_set_compass_sample_rate is called with the correct value, the 9-axis
     * fusion algorithm's compass correction gain will work properly.
    inv_set_compass_sample_rate(COMPASS_READ_MS * 1000L);
#endif
    /* Set chip-to-body orientation matrix.
     * Set hardware units to dps/g's/degrees scaling factor.
    inv_set_gyro_orientation_and_scale(
            inv_orientation_matrix_to_scalar(gyro_pdata.orientation),
            (long)gyro_fsr<<15);
    inv_set_accel_orientation_and_scale(
            (long)accel_fsr<<15);
    inv_set_compass_orientation_and_scale(
            inv_orientation_matrix_to_scalar(compass_pdata.orientation),
            (long)compass_fsr<<15);
#endif
    /* Initialize HAL state variables. */
    hal.sensors = ACCEL_ON | GYRO_ON | COMPASS_ON;
#else
    hal.sensors = ACCEL_ON | GYRO_ON;
#endif
    hal.dmp_on = 0;
    hal.report = 0;
    hal.rx.cmd = 0;
    hal.next_pedo_ms = 0;
    hal.next_compass_ms = 0;
    hal.next_temp_ms = 0;
  /* Compass reads are handled by scheduler. */
    /* To initialize the DMP:
     * 1. Call dmp_load_motion_driver_firmware(). This pushes the DMP image in
     *    inv_mpu_dmp_motion_driver.h into the MPU memory.
     * 2. Push the gyro and accel orientation matrix to the DMP.
     * 3. Register gesture callbacks. Don't worry, these callbacks won't be
     *    executed unless the corresponding feature is enabled.
     * 4. Call dmp_enable_feature(mask) to enable different features.
     * 5. Call dmp_set_fifo_rate(freq) to select a DMP output rate.
     * 6. Call any feature-specific control functions.
     * To enable the DMP, just call mpu_set_dmp_state(1). This function can
     * be called repeatedly to enable and disable the DMP at runtime.
     * The following is a short summary of the features supported in the DMP
     * image provided in inv_mpu_dmp_motion_driver.c:
     * DMP_FEATURE_LP_QUAT: Generate a gyro-only quaternion on the DMP at
     * 200Hz. Integrating the gyro data at higher rates reduces numerical
     * errors (compared to integration on the MCU at a lower sampling rate).
     * DMP_FEATURE_6X_LP_QUAT: Generate a gyro/accel quaternion on the DMP at
     * 200Hz. Cannot be used in combination with DMP_FEATURE_LP_QUAT.
     * DMP_FEATURE_TAP: Detect taps along the X, Y, and Z axes.
     * DMP_FEATURE_ANDROID_ORIENT: Google's screen rotation algorithm. Triggers
     * an event at the four orientations where the screen should rotate.
     * DMP_FEATURE_GYRO_CAL: Calibrates the gyro data after eight seconds of
     * no motion.
     * DMP_FEATURE_SEND_RAW_ACCEL: Add raw accelerometer data to the FIFO.
     * DMP_FEATURE_SEND_RAW_GYRO: Add raw gyro data to the FIFO.
     * DMP_FEATURE_SEND_CAL_GYRO: Add calibrated gyro data to the FIFO. Cannot
     * be used in combination with DMP_FEATURE_SEND_RAW_GYRO.
    dmp_load_motion_driver_firmware();
    dmp_set_orientation(
        inv_orientation_matrix_to_scalar(gyro_pdata.orientation));
    dmp_register_tap_cb(tap_cb);
    dmp_register_android_orient_cb(android_orient_cb);
     * Known Bug -
     * DMP when enabled will sample sensor data at 200Hz and output to FIFO at the rate
     * specified in the dmp_set_fifo_rate API. The DMP will then sent an interrupt once
     * a sample has been put into the FIFO. Therefore if the dmp_set_fifo_rate is at 25Hz
     * there will be a 25Hz interrupt from the MPU device.
     * There is a known issue in which if you do not enable DMP_FEATURE_TAP
     * then the interrupts will be at 200Hz even if fifo rate
     * is set at a different rate. To avoid this issue include the DMP_FEATURE_TAP
     * DMP sensor fusion works only with gyro at +-2000dps and accel +-2G
    hal.dmp_features = DMP_FEATURE_6X_LP_QUAT | DMP_FEATURE_TAP |
        DMP_FEATURE_ANDROID_ORIENT | DMP_FEATURE_SEND_RAW_ACCEL | DMP_FEATURE_SEND_CAL_GYRO |
        DMP_FEATURE_GYRO_CAL;
    dmp_set_fifo_rate(DEFAULT_MPU_HZ);
    hal.dmp_on = 1;
  while(1){
    unsigned long sensor_timestamp;
    int new_data = 0;
    if (USART_GetFlagStatus (USART_DEBUG, USART_FLAG_RXNE)) {
        /* A byte has been received via USART. See handle_input for a list of
         * valid commands.
        USART_ClearFlag(USART_DEBUG, USART_FLAG_RXNE);
        handle_input();
        /* We're not using a data ready interrupt for the compass, so we'll
         * make our compass reads timer-based instead.
        if ((timestamp > hal.next_compass_ms) && !hal.lp_accel_mode &&
            hal.new_gyro && (hal.sensors & COMPASS_ON)) {
            hal.next_compass_ms = timestamp + COMPASS_READ_MS;
            new_compass = 1;
#endif
        /* Temperature data doesn't need to be read with every gyro sample.
         * Let's make them timer-based like the compass reads.
        if (timestamp > hal.next_temp_ms) {
            hal.next_temp_ms = timestamp + TEMP_READ_MS;
            new_temp = 1;
    if (hal.motion_int_mode) {
        /* Enable motion interrupt. */
        mpu_lp_motion_interrupt(500, 1, 5);
        /* Notify the MPL that contiguity was broken. */
        /* Wait for the MPU interrupt. */
        while (!hal.new_gyro) {}
        /* Restore the previous sensor configuration. */
        mpu_lp_motion_interrupt(0, 0, 0);
        hal.motion_int_mode = 0;
    if (!hal.sensors || !hal.new_gyro) {
        continue;
        if (hal.new_gyro && hal.lp_accel_mode) {
            short accel_short[3];
            long accel[3];
            mpu_get_accel_reg(accel_short, &sensor_timestamp);
            accel[0] = (long)accel_short[0];
            accel[1] = (long)accel_short[1];
            accel[2] = (long)accel_short[2];
            inv_build_accel(accel, 0, sensor_timestamp);
            new_data = 1;
            hal.new_gyro = 0;
        } else if (hal.new_gyro && hal.dmp_on) {
            short gyro[3], accel_short[3], sensors;
            unsigned char more;
            long accel[3], quat[4], temperature;
            /* This function gets new data from the FIFO when the DMP is in
             * use. The FIFO can contain any combination of gyro, accel,
             * quaternion, and gesture data. The sensors parameter tells the
             * caller which data fields were actually populated with new data.
             * For example, if sensors == (INV_XYZ_GYRO | INV_WXYZ_QUAT), then
             * the FIFO isn't being filled with accel data.
             * The driver parses the gesture data to determine if a gesture
             * event has occurred; on an event, the application will be notified
             * via a callback (assuming that a callback function was properly
             * registered). The more parameter is non-zero if there are
             * leftover packets in the FIFO.
            dmp_read_fifo(gyro, accel_short, quat, &sensor_timestamp, &sensors, &more);
            if (!more)
                hal.new_gyro = 0;
            if (sensors & INV_XYZ_GYRO) {
                /* Push the new data to the MPL. */
                inv_build_gyro(gyro, sensor_timestamp);
                new_data = 1;
                if (new_temp) {
                    new_temp = 0;
                    /* Temperature only used for gyro temp comp. */
                    mpu_get_temperature(&temperature, &sensor_timestamp);
                    inv_build_temp(temperature, sensor_timestamp);
            if (sensors & INV_XYZ_ACCEL) {
                new_data = 1;
            if (sensors & INV_WXYZ_QUAT) {
                inv_build_quat(quat, 0, sensor_timestamp);
                new_data = 1;
        } else if (hal.new_gyro) {
            short gyro[3], accel_short[3];
            unsigned char sensors, more;
            long accel[3], temperature;
            /* This function gets new data from the FIFO. The FIFO can contain
             * gyro, accel, both, or neither. The sensors parameter tells the
             * For example, if sensors == INV_XYZ_GYRO, then the FIFO isn't
             * being filled with accel data. The more parameter is non-zero if
             * there are leftover packets in the FIFO. The HAL can use this
             * information to increase the frequency at which this function is
             * called.
            hal.new_gyro = 0;
            mpu_read_fifo(gyro, accel_short, &sensor_timestamp,
                &sensors, &more);
            if (more)
                hal.new_gyro = 1;
                new_data = 1;
                if (new_temp) {
                    new_temp = 0;
                new_data = 1;
        if (new_compass) {
            short compass_short[3];
            long compass[3];
            new_compass = 0;
            /* For any MPU device with an AKM on the auxiliary I2C bus, the raw
             * magnetometer registers are copied to special gyro registers.
            if (!mpu_get_compass_reg(compass_short, &sensor_timestamp)) {
                compass[0] = (long)compass_short[0];
                compass[1] = (long)compass_short[1];
                compass[2] = (long)compass_short[2];
                /* NOTE: If using a third-party compass calibration library,
                 * pass in the compass data in uT * 2^16 and set the second
                 * parameter to INV_CALIBRATED | acc, where acc is the
                 * accuracy from 0 to 3.
                inv_build_compass(compass, 0, sensor_timestamp);
            new_data = 1;
#endif
        if (new_data) {
            inv_execute_on_data();
            /* This function reads bias-compensated sensor data and sensor
             * fusion outputs from the MPL. The outputs are formatted as seen
             * in eMPL_outputs.c. This function only needs to be called at the
             * rate requested by the host.
            read_from_mpl();
发表于 2021-9-23 08:45:24 | 显示全部楼层
https://www.firebbs.cn/forum.php ... id=30037&extra=
用另一个版本上位机试试
 楼主| 发表于 2021-9-24 22:32:57 | 显示全部楼层
WishWish 发表于 2021-9-23 08:45
https://www.firebbs.cn/forum.php?mod=viewthread&tid=30037&extra=
用另一个版本上位机试试
已经解决了 版本问题
GMT+8, 2024-11-24 13:10 , Processed in 0.037350 second(s), 26 queries , Gzip On.
