查看: 11859|回复: 1
[求助] I.MX6ULL Pro板无法连接WIFI
发表于 2021-9-27 08:50:09 | 显示全部楼层 |阅读模式
I.MX6ULL Pro无法连接wifi,麻烦大佬们帮忙看看。
WIFI模块是AP6236,跳线帽如下图,J1002用杜邦线连接也已经试过,与不连接是一样的现象:
系统版本为最新的20210902,已经重新烧录过两次,版本如下图:
操作方法遵循以下这个文档:
http://doc.embedfire.com/linux/i ... tml#fire-configwifi
参考过以下这个帖子仍旧未解决:
https://www.firebbs.cn/forum.php ... &highlight=wifi
fire-config设置后重启,打印以下错误信息,使用fire-config工具中的wifi-scan无法检测到wifi:
cat /boot/uEnv.txt |grep "dtoverlay" 指令后的信息如下图:
ifconfig指令后的信息如下图:
dmesg后的开机信息如下:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.35-imx6 (root@cicd-ubuntu.embedfire.local) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #1.2109stable SMP PREEMPT Thu Sep 2 02:58:16 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Embedfire i.MX6ULL Board
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x8c000000, size 320 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] On node 0 totalpages: 131072
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[    0.000000] random: get_random_bytes called from start_kernel+0xa0/0x41c with crng_init=0
[    0.000000] percpu: Embedded 16 pages/cpu @(ptrval) s36364 r8192 d20980 u65536
[    0.000000] pcpu-alloc: s36364 r8192 d20980 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttymxc0 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 vt.global_cursor_default=0
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 164588K/524288K available (13312K kernel code, 1125K rwdata, 4412K rodata, 1024K init, 505K bss, 32020K reserved, 327680K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xa0800000 - 0xff800000   (1520 MB)
                   lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
                   pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
                   modules : 0x7f000000 - 0x7fe00000   (  14 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (14304 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   (1126 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 506 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:         RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000]         Tasks RCU enabled.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] Switching to timer-based delay loop, resolution 333ns
[    0.000018] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[    0.000063] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[    0.003541] Console: colour dummy device 80x30
[    0.003614] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003657] pid_max: default: 32768 minimum: 301
[    0.004052] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.004087] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.005656] CPU: Testing write buffer coherency: ok
[    0.006436] CPU0: update cpu_capacity 1024
[    0.006474] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.060663] Setting up static identity map for 0x80100000 - 0x80100060
[    0.080665] rcu: Hierarchical SRCU implementation.
[    0.130991] smp: Bringing up secondary CPUs ...
[    0.131034] smp: Brought up 1 node, 1 CPU
[    0.131061] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.131081] CPU: All CPU(s) started in SVC mode.
[    0.132858] devtmpfs: initialized
[    0.145538] Duplicate name in lcdif@21c8000, renamed to "display#1"
[    0.162003] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.162953] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.163006] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.188231] pinctrl core: initialized pinctrl subsystem
[    0.190725] NET: Registered protocol family 16
[    0.220629] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.223281] cpuidle: using governor menu
[    0.241695] vdd3p0: supplied by regulator-dummy
[    0.243237] cpu: supplied by regulator-dummy
[    0.244567] vddsoc: supplied by regulator-dummy
[    0.246340] mxs_phy 20c9000.usbphy: Linked as a consumer to regulator.1
[    0.247617] mxs_phy 20ca000.usbphy: Linked as a consumer to regulator.1
[    0.271259] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.271295] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.277084] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.278100] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[    0.282414] imx rpmsg driver is registered.
[    0.450867] SCSI subsystem initialized
[    0.453798] libata version 3.00 loaded.
[    0.454397] usbcore: registered new interface driver usbfs
[    0.454541] usbcore: registered new interface driver hub
[    0.454784] usbcore: registered new device driver usb
[    0.458063] i2c i2c-0: IMX I2C adapter registered
[    0.458116] i2c i2c-0: can't use DMA, using PIO instead.
[    0.460162] i2c i2c-1: IMX I2C adapter registered
[    0.460210] i2c i2c-1: can't use DMA, using PIO instead.
[    0.461383] videodev: Linux video capture interface: v2.00
[    0.461504] pps_core: LinuxPPS API ver. 1 registered
[    0.461528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.461588] PTP clock support registered
[    0.464698] MIPI CSI2 driver module loaded
[    0.465183] Advanced Linux Sound Architecture Driver Initialized.
[    0.466390] Bluetooth: Core ver 2.22
[    0.466538] NET: Registered protocol family 31
[    0.466562] Bluetooth: HCI device and connection manager initialized
[    0.466602] Bluetooth: HCI socket layer initialized
[    0.466632] Bluetooth: L2CAP socket layer initialized
[    0.466733] Bluetooth: SCO socket layer initialized
[    0.468481] clocksource: Switched to clocksource mxc_timer1
[    0.468951] VFS: Disk quotas dquot_6.6.0
[    0.469143] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.493405] NET: Registered protocol family 2
[    0.495230] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.495316] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.495443] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.495605] TCP: Hash tables configured (established 4096 bind 4096)
[    0.495832] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.495906] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.496334] NET: Registered protocol family 1
[    0.527964] RPC: Registered named UNIX socket transport module.
[    0.528002] RPC: Registered udp transport module.
[    0.528022] RPC: Registered tcp transport module.
[    0.528043] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.540198] Trying to unpack rootfs image as initramfs...
[    1.300985] Freeing initrd memory: 5044K
[    1.305977] Bus freq driver module loaded
[    1.309028] Initialise system trusted keyrings
[    1.309528] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    1.335719] NFS: Registering the id_resolver key type
[    1.335794] Key type id_resolver registered
[    1.335819] Key type id_legacy registered
[    1.335921] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.337403] fuse init (API version 7.27)
[    1.361997] Key type asymmetric registered
[    1.362035] Asymmetric key parser 'x509' registered
[    1.372664] io scheduler noop registered
[    1.372702] io scheduler deadline registered
[    1.373107] io scheduler cfq registered (default)
[    1.373138] io scheduler mq-deadline registered
[    1.373162] io scheduler kyber registered
[    1.375067] imx-weim 21b8000.weim: Driver registered.
[    1.383403] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    1.383622] pwm-backlight backlight: Linked as a consumer to regulator.0
[    1.390605] sii902x 1-0039: No reset pin found
[    1.393825] mxsfb 21c8000.lcdif: 21c8000.lcdif supply lcd not found, using dummy regulator
[    1.394080] mxsfb 21c8000.lcdif: Linked as a consumer to regulator.0
[    1.512506] Console: switching to colour frame buffer device 100x30
[    1.527532] sii902x bound to mxs-lcdif from 21c8000.lcdif
[    1.609519] mxsfb 21c8000.lcdif: initialized
[    1.612882] imx-sdma 20ec000.sdma: loaded firmware 3.5
[    1.621841] mxs-dma 1804000.dma-apbh: initialized
[    1.628141] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[    1.628197] Console IMX rounded baud rate from 114943 to 114900
[    2.422017] console [ttymxc0] enabled
[    2.427891] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 68, base_baud = 5000000) is a IMX
[    2.472657] imx-rng 2284000.rngb: iMX RNG Registered.
[    2.478639] imx sema4 driver is registered.
[    2.484213] [drm] Initialized vivante 1.0.0 20120216 for platform:Vivante GCCore on minor 0
[    2.492830] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    2.526139] brd: module loaded
[    2.550813] loop: module loaded
[    2.567835] libphy: Fixed MDIO Bus: probed
[    2.572110] random: fast init done
[    2.576509] CAN device driver interface
[    2.584219] fec 20b4000.ethernet: 20b4000.ethernet supply phy not found, using dummy regulator
[    2.593220] fec 20b4000.ethernet: Linked as a consumer to regulator.0
[    2.601017] pps pps0: new PPS source ptp0
[    2.606914] libphy: fec_enet_mii_bus: probed
[    2.676966] fec 20b4000.ethernet eth0: registered PHC device 0
[    2.685104] fec 2188000.ethernet: 2188000.ethernet supply phy not found, using dummy regulator
[    2.694200] fec 2188000.ethernet: Linked as a consumer to regulator.0
[    2.702225] pps pps1: new PPS source ptp1
[    2.707033] fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[    2.717248] fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 1a:1c:9b:4c:ec:c7
[    2.729785] fec 2188000.ethernet eth1: registered PHC device 1
[    2.737602] PPP generic driver version 2.4.2
[    2.742595] PPP BSD Compression module registered
[    2.747342] PPP Deflate Compression module registered
[    2.752552] PPP MPPE Compression module registered
[    2.757380] NET: Registered protocol family 24
[    2.762232] usbcore: registered new interface driver mt7601u
[    2.768026] usbcore: registered new interface driver mt76x0
[    2.773832] usbcore: registered new interface driver mt76x2u
[    2.779846] usbcore: registered new interface driver rtl8192cu
[    2.785715] RTW: module init start
[    2.789345] RTW: rtl8821cu v5.8.1.3_35898.20191211_COEX20191014-4141
[    2.795733] RTW: build time: Sep  2 2021 02:58:05
[    2.800524] RTW: rtl8821cu BT-Coex version = COEX20191014-4141
[    2.806619] usbcore: registered new interface driver rtl8821cu
[    2.812548] RTW: module init ret=0
[    2.816096] usbcore: registered new interface driver kaweth
[    2.821763] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    2.829341] usbcore: registered new interface driver pegasus
[    2.835116] usbcore: registered new interface driver rtl8150
[    2.841115] usbcore: registered new interface driver r8152
[    2.846769] usbcore: registered new interface driver asix
[    2.852389] usbcore: registered new interface driver ax88179_178a
[    2.858685] usbcore: registered new interface driver cdc_ether
[    2.864636] usbcore: registered new interface driver net1080
[    2.870475] usbcore: registered new interface driver rndis_host
[    2.876514] usbcore: registered new interface driver cdc_subset
[    2.882604] usbcore: registered new interface driver zaurus
[    2.888356] usbcore: registered new interface driver cdc_ncm
[    2.894110] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.900875] usbcore: registered new interface driver cdc_wdm
[    2.906702] usbcore: registered new interface driver usb-storage
[    2.913062] usbcore: registered new interface driver usbserial_generic
[    2.919783] usbserial: USB Serial support registered for generic
[    2.925936] usbcore: registered new interface driver ch341
[    2.931599] usbserial: USB Serial support registered for ch341-uart
[    2.937984] usbcore: registered new interface driver cp210x
[    2.943735] usbserial: USB Serial support registered for cp210x
[    2.949829] usbcore: registered new interface driver ftdi_sio
[    2.955670] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.963153] usbcore: registered new interface driver option
[    2.969001] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.976101] usbcore: registered new interface driver usb_ehset_test
[    2.985376] usbmisc_imx 2184800.usbmisc: 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    2.995591] usbmisc_imx 2184800.usbmisc: Linked as a consumer to regulator.0
[    3.004950] imx_usb 2184000.usb: 2184000.usb supply vbus not found, using dummy regulator
[    3.013487] imx_usb 2184000.usb: Linked as a consumer to regulator.0
[    3.047828] imx_usb 2184200.usb: 2184200.usb supply vbus not found, using dummy regulator
[    3.056552] imx_usb 2184200.usb: Linked as a consumer to regulator.0
[    3.066825] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    3.071904] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    3.108593] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    3.116105] hub 1-0:1.0: USB hub found
[    3.120218] hub 1-0:1.0: 1 port detected
[    3.140308] input: 20cc000.snvs:snvs-powerkey as /devices/soc0/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
[    3.159055] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-rtc-lp as rtc0
[    3.169381] i2c /dev entries driver
[    3.181338] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[    3.189523] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[    3.198019] Bluetooth: HCI UART driver ver 2.3
[    3.202694] Bluetooth: HCI UART protocol H4 registered
[    3.207866] Bluetooth: HCI UART protocol BCSP registered
[    3.213334] Bluetooth: HCI UART protocol ATH3K registered
[    3.219065] usbcore: registered new interface driver bcm203x
[    3.224879] usbcore: registered new interface driver btusb
[    3.230992] usbcore: registered new interface driver ath3k
[    3.239032] sdhci: Secure Digital Host Controller Interface driver
[    3.245263] sdhci: Copyright(c) Pierre Ossman
[    3.249735] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.258566] sdhci-esdhc-imx 2190000.usdhc: assigned as wifi host
[    3.264947] sdhci-esdhc-imx 2190000.usdhc: Linked as a consumer to regulator.5
[    3.306761] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    3.348833] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[    3.373660] usbcore: registered new interface driver usbhid
[    3.380727] usbhid: USB HID core driver
[    3.388426] vf610-adc 2198000.adc: Linked as a consumer to regulator.4
[    3.402562] NET: Registered protocol family 26
[    3.478781] mmc1: new DDR MMC card at address 0001
[    3.488704] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    3.496612] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[    3.510225] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[    3.517596] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[    3.539622] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB, chardev (245:0)
[    3.549717] xt_time: kernel timezone is -0000
[    3.554882] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[    3.562933] Initializing XFRM netlink socket
[    3.569130] NET: Registered protocol family 10
[    3.577580]  mmcblk1: p1 p2
[    3.596576] Segment Routing with IPv6
[    3.601265] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.609110] NET: Registered protocol family 17
[    3.613640] can: controller area network core (rev 20170425 abi 9)
[    3.620512] NET: Registered protocol family 29
[    3.625007] can: raw protocol (rev 20170425)
[    3.629609] can: broadcast manager protocol (rev 20170425 t)
[    3.635332] can: netlink gateway (rev 20170425) max_hops=1
[    3.641581] Bluetooth: RFCOMM TTY layer initialized
[    3.646534] Bluetooth: RFCOMM socket layer initialized
[    3.652007] Bluetooth: RFCOMM ver 1.11
[    3.655822] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.661241] Bluetooth: BNEP filters: protocol multicast
[    3.666539] Bluetooth: BNEP socket layer initialized
[    3.671726] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.677862] Bluetooth: HIDP socket layer initialized
[    3.683055] 8021q: 802.1Q VLAN Support v1.8
[    3.687354] lib80211: common routines for IEEE802.11 drivers
[    3.693267] lib80211_crypt: registered algorithm 'NULL'
[    3.693281] lib80211_crypt: registered algorithm 'WEP'
[    3.693292] lib80211_crypt: registered algorithm 'CCMP'
[    3.693302] lib80211_crypt: registered algorithm 'TKIP'
[    3.693356] Key type dns_resolver registered
[    3.699711] cpu cpu0: Linked as a consumer to regulator.2
[    3.705392] cpu cpu0: Linked as a consumer to regulator.3
[    3.712457] cpu cpu0: running cpufreq without cooling device: 0
[    3.720985] hub 1-1:1.0: USB hub found
[    3.725002] hub 1-1:1.0: 4 ports detected
[    3.749647] Loading compiled-in X.509 certificates
[    3.826637] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[    3.839425] [dhd] dhd_module_init: in Dongle Host Driver, version 100.10.545.12 (r826445-20200708-1)
[    3.839906] bcmdhd_wlan bcmdhd_wlan@0: Linked as a consumer to regulator.6
[    3.846885] [dhd] dhd_wifi_platform_load: Enter
[    3.846894] [dhd] Power-up adapter 'DHD generic adapter'
[    3.846962] [dhd] ======== PULL WL_REG_ON HIGH! ========
[    3.879113] [dhd] wifi_platform_bus_enumerate device present 1
[    3.879129] [dhd] ======== Card detection to detect SDIO card! ========
[    3.907759] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.915327] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.922851] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.931738] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.941338] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[    4.056475] mmc0: error -84 whilst initialising SDIO card
[    4.154077] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[    4.162103] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.170033] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.179862] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[    4.190485] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[    4.333850] mmc0: error -84 whilst initialising SDIO card
[    4.669737] mmc0: error -84 whilst initialising SDIO card
[    5.231835] mmc0: error -84 whilst initialising SDIO card
[    8.888640] [dhd] failed to power up DHD generic adapter, 0 retry left
[    8.904977] [dhd] ======== PULL WL_REG_ON LOW! ========
[    8.905192] [dhd] wifi_platform_bus_enumerate device present 0
[    8.905212] [dhd] ======== Card detection to remove SDIO card! ========
[    8.905266] [dhd] failed to power up DHD generic adapter, max retry reached**
[    8.906287] [dhd] dhd_module_init: Exit err=0
[    8.908090] input: sgpio-keys as /devices/soc0/sgpio-keys/input/input1
[    8.916772] snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:12:26 UTC (746)
[    8.926742] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.969484] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.976297] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
[    8.984833] WIFI_3V3: disabling
[    8.988003] wlan-en-gpio: disabling
[    8.991815] ALSA device list:
[    8.994803]   No soundcards found.
[    9.000245] Freeing unused kernel memory: 1024K
[    9.005200] Run /init as init process
[   10.547413] cfg80211: failed to load regulatory.db
[   11.832092] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[   12.525721] systemd[1]: System time before build time, advancing clock.
[   12.563055] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   12.585546] systemd[1]: Detected architecture arm.
[   12.631115] systemd[1]: Set hostname to <npi>.
[   13.530883] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   13.548752] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   13.833838] random: systemd: uninitialized urandom read (16 bytes read)
[   13.952178] systemd[1]: Configuration file /lib/systemd/system/generic-board-startup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[   14.017998] random: systemd: uninitialized urandom read (16 bytes read)
[   14.025994] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   14.069432] random: systemd: uninitialized urandom read (16 bytes read)
[   14.083695] systemd[1]: Created slice User and Session Slice.
[   14.119192] systemd[1]: Reached target Slices.
[   14.150583] systemd[1]: Listening on Journal Socket (/dev/log).
[   16.533660] systemd-journald[190]: Received request to flush runtime journal from PID 1
[   19.687972] fec 20b4000.ethernet eth2: renamed from eth0
[   20.550869] inv-mpu6050-i2c 0-0068: mounting matrix not found: using identity...
[   20.681038] Goodix-TS 0-005d: ID 4097, version: 0200
[   20.692860] Goodix-TS 0-005d: Falling back to syfs fallback for: goodix_4097_cfg.bin
[   20.819684] i2c i2c-0: Added multiplexed i2c bus 4
[   21.112630] imx-wm8960 sound: wm8960-hifi <-> 202c000.sai mapping ok
[   21.195497] imx-wm8960 sound: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
[   21.262118] imx-wm8960 sound: wm8960-hifi <-> 202c000.sai mapping ok
[   22.089053] input: Goodix Capacitive TouchScreen as /devices/soc0/soc/2100000.aips-bus/21a0000.i2c/i2c-0/0-005d/input/input2
[   23.234436] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   25.401748] random: crng init done
[   25.405186] random: 7 urandom warning(s) missed due to ratelimiting
[   26.522346] using random self ethernet address
[   26.522361] using random host ethernet address
[   26.522782] Mass Storage Function, version: 2009/09/11
[   26.522796] LUN: removable file: (no medium)
[   26.522975] LUN: removable file: /dev/mmcblk1p1
[   26.522983] Number of LUNs=1
[   26.552422] usb0: HOST MAC 7e:52:5b:bf:57:1c
[   26.552846] usb0: MAC 36:64:e5:d4:0b:05
[   26.555416] g_multi gadget: Multifunction Composite Gadget
[   26.555428] g_multi gadget: g_multi ready
[   27.829692] Micrel KSZ8081 or KSZ8091 20b4000.ethernet-1:01: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet-1:01, irq=POLL)
[   27.882054] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   28.070515] Micrel KSZ8081 or KSZ8091 20b4000.ethernet-1:02: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet-1:02, irq=POLL)
[   28.117960] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   30.386707] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
发表于 2021-9-27 09:44:51 | 显示全部楼层
板子右下角漏焊了一个排针跳帽 联系客服寄回
GMT+8, 2024-11-21 23:23 , Processed in 0.037398 second(s), 26 queries , Gzip On.
