查看: 12827|回复: 0
普通定时器输出PWM出现问题,最高电压只有0.6V
发表于 2021-11-8 14:08:27 | 显示全部楼层 |阅读模式
PWM2模式,极性低,是F103,例程可以正常调
#include "stm32f10x.h"
void pwm_init(void)
        u16 CCR_Val = 2400;
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
//    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
//    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
//    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_6;
//    GPIO_Init(GPIOC,&GPIO_InitStructure);
        /***************μ³¾ƷPWMʤ³ö¿ڪ******************/
    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_7;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        /* Time base configuration */
        TIM_TimeBaseStructure.TIM_Period = 7199;
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        /* PWM1 Mode configuration: Channel2 */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_Pulse = CCR_Val;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
        //TIM_OC1Init(TIM3, &TIM_OCInitStructure);
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);
        //TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM3, ENABLE);
        TIM_Cmd(TIM3, ENABLE);
int main()
    pwm_init();
    TIM_SetCompare2(TIM3,0);//问题:最高0.6V
    while(1){}
GMT+8, 2024-11-23 04:41 , Processed in 0.029545 second(s), 26 queries , Gzip On.
