查看: 16950|回复: 1
请问ADS1256采集速度很低,怎么提高采样速率?
发表于 2021-11-20 19:58:46 | 显示全部楼层 |阅读模式
芯片使用的是stm32F103C8,目前1秒钟就2组数据,怎么把采样速率提高到1000HZ左右
程序如下
#include "stm32f10x.h"
#include <stdio.h>
#define uchar unsigned char
#define uint unsigned int
uchar dat,a,ds[30],i,sign[4];
long AD_DATA;
long buff[5]={0};
#define K1 GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_0)
/*************************** 宏定义***********************************************/
/*Registers' Address*/
#define REG_STATUS  0
#define REG_MUX     1
#define REG_ADCON   2
#define REG_DRATE   3
#define REG_IO      4
#define REG_OFC0    5
#define REG_OFC1    6
#define REG_OPC2    7
#define REG_FSC0    8
#define REG_FSC1    9
#define REG_FSC2    10
/*Operation Command*/
//#define CMD_WAKEUP     0x00
#define CMD_RDATA      0x01
#define CMD_RDATAC     0x03
#define CMD_SDATAC     0x0F
#define CMD_RREG       0x10
#define CMD_WREG       0x50
#define CMD_SELFCAL    0xf0
#define CMD_SELFOCAL   0xf1
#define CMD_SELFGCAL   0xf2
#define CMD_SYSOCAL    0xf3
#define CMD_SYSGCAL    0xf4
#define CMD_SYNC       0xfc
#define CMD_STANDBY    0xfd
#define CMD_RESET      0xfe
#define CMD_WAKEUP     0xFF
#define PGA_1            0x00
#define PGA_2            0x01
#define PGA_4            0x02
#define PGA_8            0x03
#define PGA_16           0x04
#define PGA_32           0x05
#define PGA_64           0x06
#define POSITIVE_AIN0            (0X00<<4)  //AINP  高位对应 BIT4-BIT7
#define POSITIVE_AIN1            (0X01<<4)
#define POSITIVE_AIN2            (0X02<<4)
#define POSITIVE_AIN3            (0X03<<4)
#define POSITIVE_AIN4            (0X04<<4)
#define POSITIVE_AIN5            (0X05<<4)
#define POSITIVE_AIN6            (0X06<<4)
#define POSITIVE_AIN7            (0X07<<4)
#define POSITIVE_AINCOM          (0X08<<4)
#define NEGTIVE_AIN0              0X00     //AINN  低位对应 BIT0-BIT3
#define NEGTIVE_AIN1              0X01
#define NEGTIVE_AIN2              0X02
#define NEGTIVE_AIN3              0X03
#define NEGTIVE_AIN4              0X04
#define NEGTIVE_AIN5              0X05
#define NEGTIVE_AIN6              0X06
#define NEGTIVE_AIN7              0X07
#define NEGTIVE_AINCOM            0X08
/*For fclkin=7.68MHz, data rate*/
#define DATARATE_30K              0xf0
#define DATARATE_15K              0xe0
#define DATARATE_7_5K             0xd0
#define DATARATE_3_7_5K           0xc0
#define DATARATE_2K               0xb0
#define DATARATE_10SPS            0x23
#define DATARATE_5SPS             0x13
#define DATARATE_2_5SPS           0x03
/*STATUS REGISTER*/
#define MSB_FRIST                (0x00<<3)
#define LSB_FRIST                (0x01<<3)
#define ACAL_OFF                 (0x00<<2)
#define ACAL_ON                  (0x01<<2)
#define BUFEN_OFF                (0x00<<1)
#define BUFEN_ON                 (0x01<<1)
/*ADCON REGISTER*/
#define CLKOUT_OFF               (0x00<<5)
#define CLKOUT_CLKIN             (0x01<<5)
#define DETECT_OFF               (0x00<<3)
#define DETECT_ON_2UA            (0x02<<3)
#define ADS1256_DRDY    ((GPIOB->IDR)&(1<<10))   //    GPIOB->IDR读端口B的数据寄存器   DRDY --- PB12
#define ADS1256_DO      ((GPIOB->IDR)&(1<<14))      // DOUT --- PB14
#define SetADS1256_DRDY   GPIOB->BSRR =  (1<<10)   //BSRR对低16位中的某位置'1'则它对应的端口位被置'1'
#define SetADS1256_DO     GPIOB->BSRR =  (1<<14)
//#define ADS1256_SYNC   (1<<8)
#define ADS1256_CS     (1<<12)    // CS --- PB12
#define ADS1256_IN     (1<<15)    // DIN --- PB15
#define ADS1256_CLK    (1<<13)    // SCLK--- PB13
#define ADS1256_RESET  (1<<11)    // SCLK--- PB11
//#define SetADS1256_SYNC   GPIOB->BSRR =  ADS1256_SYNC
#define SetADS1256_CS     GPIOB->BSRR =  ADS1256_CS
#define SetADS1256_IN     GPIOB->BSRR =  ADS1256_IN
#define SetADS1256_CLK    GPIOB->BSRR =  ADS1256_CLK
#define SetADS1256_RESET     GPIOB->BSRR =  ADS1256_RESET
#define ClrADS1256_SYNC   GPIOB->BRR =  ADS1256_SYNC   //BRR对低16位中的某位置'0'则端口x的对应位被清'0'
#define ClrADS1256_CS     GPIOB->BRR =  ADS1256_CS
#define ClrADS1256_IN     GPIOB->BRR =  ADS1256_IN
#define ClrADS1256_CLK    GPIOB->BRR =  ADS1256_CLK
unsigned char result[3];
#define ADCLK RCC_APB2Periph_GPIOA  //定义AD芯片所使用的I/O端口的时钟。
#define REG_MUX     1
#define REG_ADCON   2
#define REG_DRATE   3
#define REG_IO      4
#define REG_OFC0    5
#define REG_OFC1    6
#define REG_OPC2    7
#define REG_FSC0    8
#define REG_FSC1    9
#define REG_FSC2    10
void delayad(unsigned int tt)
    unsigned int i,j;
    for(j=tt;j>0;j--)
        for(i=5;i>0;i--);
void delayad_nopar(void)
    unsigned long i =10;
       while(i--);
函数: void RCC_Configuration(void)
功能: 复位和时钟控制 配置
参数: 无
返回: 无
void RCC_Configuration(void)//配置时钟
  ErrorStatus HSEStartUpStatus;                    //定义外部高速晶体启动状态枚举变量
  RCC_DeInit();                                    //复位RCC外部设备寄存器到默认值
  RCC_HSEConfig(RCC_HSE_ON);                       //打开外部高速晶振
  HSEStartUpStatus = RCC_WaitForHSEStartUp();      //等待外部高速时钟准备好
  if(HSEStartUpStatus == SUCCESS)                  //外部高速时钟已经准别好
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //开启FLASH预读缓冲功能,加速FLASH的读取。所有程序中必须的用法.位置:RCC初始化子函数里面,时钟起振之后
    FLASH_SetLatency(FLASH_Latency_2);                    //flash操作的延时
    RCC_HCLKConfig(RCC_SYSCLK_Div2);               //配置AHB(HCLK)时钟等于==SYSCLK
    RCC_PCLK1Config(RCC_HCLK_Div2);                       //配置APB1(PCLK1)钟==AHB1/2时钟
      RCC_PCLK2Config(RCC_HCLK_Div2);                //配置APB2(PCLK2)钟==AHB时钟
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);  //配置PLL时钟 == 外部高速晶体时钟 * 9 = 72MHz
    RCC_PLLCmd(ENABLE);                                   //使能PLL时钟
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)    //等待PLL时钟就绪
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);            //配置系统时钟 = PLL时钟
    while(RCC_GetSYSCLKSource() != 0x08)                  //检查PLL时钟是否作为系统时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB |RCC_APB2Periph_AFIO, ENABLE);
   //允许GPIOB、AFIO时钟
函数: GPIO_Configuration(void)
功能: 配置GPIO口
参数: 无
返回: 无
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;        //定义GPIO初始化结构体
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_12|GPIO_Pin_15 ;
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_10|GPIO_Pin_14;
函数:   NVIC_Configuration(void)
功能:   配置中断功能
输入:      无
输出:      无
返回:      无
void NVIC_Configuration(void)
   NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
   /* Configure the NVIC Preemption Priority Bits */
   /* Enable the USART1 Interrupt */
   NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;       //通道设置为串口1中断
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;       //中断响应优先级0
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;           //打开中断
   NVIC_Init(&NVIC_InitStructure);                            //初始化
函数名:USART1_Configuration
输 入:
输 出:
功能说明:配置串口参数
void USART1_Configuration(void)
    /* 打开GPIO和USART部件的时钟 */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    /* 将USART Tx的GPIO配置为推挽复用模式 */
    /* 将USART Rx的GPIO配置为浮空输入模式
        由于CPU复位后,GPIO缺省都是浮空输入模式,因此下面这个步骤不是必须的
        但是,我还是建议加上便于阅读,并且防止其它地方修改了这个口线的设置参数
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    /*   配置USART1参数
        - BaudRate = 9600 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
    USART_InitStructure.USART_BaudRate =115200;
    USART_Init(USART1, &USART_InitStructure);
    /* 若接收数据寄存器满,则产生中断 */
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    /* 使能 USART1, 配置完毕 */
    USART_Cmd(USART1, ENABLE);
    /* 如下语句解决第1个字节无法正确发送出去的问题 */
    USART_ClearFlag(USART1, USART_FLAG_TC);     // 清标志
函数名:Uart1_PutChar()
输  入:
输  出:
功能说明:串口发送一字节数据
void Uart1_PutChar(u8 ch)
  USART_SendData(USART1, (u8) ch);
  while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
函数: USART1_IRQHandler(void)
功能: 串口中断函数
参数: 无
返回: 无
void USART1_IRQHandler(void)            //在中断服务程序中,由于主机响应中断时并不知道是哪个中断源发出中断请求
                                        //  是不用做上述判别的。但是无论什么情况,做上述判别是个好习惯
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)    //若接收数据寄存器满
    dat = USART_ReceiveData(USART1);
函数: ADS1256_Write_Byte(unsigned char d)
功能: 写入一字节数据
参数: 无
返回: 无
void ADS1256_Write_Byte(unsigned char d)
    unsigned char i=8;
    ClrADS1256_CLK ;
       while(i--)
        if(d & 0X80)
              SetADS1256_IN  ;
            ClrADS1256_IN  ;
          delayad_nopar();
        SetADS1256_CLK;
          delayad_nopar();
          ClrADS1256_CLK ;
          delayad_nopar();
          d <<= 1;
函数: ADS1256_Read_Byte(void)
功能: 读取一字节数据
参数: 无
返回: 无
unsigned char ADS1256_Read_Byte(void)
    unsigned char i=8,d;
    ClrADS1256_CLK;
       while(i--)
          d <<=1;
          SetADS1256_CLK;
          delayad_nopar();
          ClrADS1256_CLK;
        delayad_nopar();
        SetADS1256_DO;
          if(ADS1256_DO)
             d |= 0x01;
             d &= 0xfe;
       return d;
函数: ADS1256_Write_Reg(unsigned char reg_name, unsigned char reg_data)
功能: 写寄存器函数
参数: 无
返回: 无
void  ADS1256_Write_Reg(unsigned char reg_name, unsigned char reg_data)
      while(ADS1256_DRDY);
    ADS1256_Write_Byte(CMD_WREG|reg_name);
       ADS1256_Write_Byte(0x00);
       ADS1256_Write_Byte(reg_data);
函数: ADS1256_Read_dat(void)
功能: 读取ADS1256三字节数据
参数: 无
返回: 无
void  ADS1256_Read_dat(void)
    ClrADS1256_CS;
    while(ADS1256_DRDY==0);
    while(ADS1256_DRDY);     //DRDY信号为低表示AD转换完成
       ADS1256_Write_Byte(CMD_RDATA);
//  delayad(50);   //min=50*(1/fCLKIN)=50*(1/7.68MHZ)=6500ns;max=whatever
      delayad_nopar();
       result[0] = ADS1256_Read_Byte();
       result[1] = ADS1256_Read_Byte();
       result[2] = ADS1256_Read_Byte();
    SetADS1256_CS;
函数: ADS1256_int()
功能: 初始化ADS1256
参数: 无
返回: 无
void ADS1256_int()
    ClrADS1256_CLK;
    delayad(2);
    ClrADS1256_CS;
    while(!ADS1256_DRDY);
    ADS1256_Write_Byte(CMD_RESET);
    ADS1256_Write_Reg(REG_STATUS,0xf4);//STATUS REGISTER:Auto-Calibration Enabled,Analog Input Buffer Disabled
    ADS1256_Write_Reg(REG_MUX,POSITIVE_AIN0+ NEGTIVE_AINCOM);  //MUX:AIN0
    //while(ADS1256_DRDY);
    //ADS1256_Write_Reg(REG_MUX,0x08);//AIN0 is Positive,single-ended measurements
    ADS1256_Write_Reg(REG_ADCON,CLKOUT_OFF+DETECT_OFF+PGA_1);       //ADCON=00h
    ADS1256_Write_Reg(REG_DRATE,DATARATE_10SPS);//data rate 15k SPS
    ADS1256_Write_Byte(CMD_WAKEUP);
    delayad(10);
    SetADS1256_CS;
void Send_data_ascii(void)
      ds[1]=buff[0]/100000;
      ds[2]=buff[0]%100000/10000;
      ds[3]=buff[0]%10000/1000;
      ds[4]=buff[0]%1000/100;
      ds[5]=buff[0]%100/10;
      ds[6]=buff[0]%100%10;
      ds[7]=buff[1]/100000;
      ds[8]=buff[1]%100000/10000;
      ds[9]=buff[1]%10000/1000;
      ds[10]=buff[1]%1000/100;
      ds[11]=buff[1]%100/10;
      ds[12]=buff[1]%100%10;
        ds[13]=buff[2]/100000;
      ds[14]=buff[2]%100000/10000;
      ds[15]=buff[2]%10000/1000;
      ds[16]=buff[2]%1000/100;
      ds[17]=buff[2]%100/10;
      ds[18]=buff[2]%100%10;
//      Uart1_PutChar('V');
//      Uart1_PutChar(y+0x30);
      Uart1_PutChar(sign[0]);
      Uart1_PutChar(ds[1]+0X30);
      Uart1_PutChar('.');
      Uart1_PutChar(ds[2]+0X30);
      Uart1_PutChar(ds[3]+0X30);
      Uart1_PutChar(ds[4]+0X30);
      Uart1_PutChar(ds[5]+0X30);
      Uart1_PutChar(ds[6]+0X30);
        Uart1_PutChar(sign[1]);
      Uart1_PutChar(ds[7]+0X30);
      Uart1_PutChar('.');
      Uart1_PutChar(ds[8]+0X30);
      Uart1_PutChar(ds[9]+0X30);
      Uart1_PutChar(ds[10]+0X30);
      Uart1_PutChar(ds[11]+0X30);
      Uart1_PutChar(ds[12]+0X30);
        Uart1_PutChar(sign[2]);
      Uart1_PutChar(ds[13]+0X30);
      Uart1_PutChar('.');
      Uart1_PutChar(ds[14]+0X30);
      Uart1_PutChar(ds[15]+0X30);
      Uart1_PutChar(ds[16]+0X30);
      Uart1_PutChar(ds[17]+0X30);
      Uart1_PutChar(ds[18]+0X30);
      Uart1_PutChar(0x0d);
      Uart1_PutChar(0x0a);
函数:Write_Reg_Mux()
功能: 读取数据并通过UART1 发送数据
参数: 无
返回: 无
void  Write_Reg_Mux(uchar x)//写寄存器指令读取数值
      dat=0;
      ClrADS1256_CS;
      ADS1256_Write_Reg(REG_MUX,x);//选择通道
      ADS1256_Read_dat();
      if((result[0]&0x80)==0x80)//判断采集电压的正负,若为负电压,则转换二进制补码数据计算电压值
          result[0]=~result[0];//首字节二进制补码取反
          result[1]=~result[1];//中间字节二进制补码取反
          result[2]=~result[2];//尾字节二进制补码取反
        ds[0]='-';//负符号位
      ds[0]='+';//正符号位
      AD_DATA=((result[0]*66536+result[1]*256+result[2])*5)/83.88607;//计算电压值
函数: int main(void)
功能: main主函数
参数: 无
返回: 无
  RCC_Configuration();
  GPIO_Configuration();
  NVIC_Configuration();
  ADS1256_int();
  USART1_Configuration();//串口初始化
     a=POSITIVE_AIN2+ NEGTIVE_AIN3;
     Write_Reg_Mux(a);
     buff[0]=AD_DATA;
     sign[0]=ds[0];
//     Send_data_ascii(0);
     a=POSITIVE_AIN4+ NEGTIVE_AIN5;
     Write_Reg_Mux(a);
     buff[1]=AD_DATA;
     sign[1]=ds[0];
//     Send_data_ascii(1);
     a=POSITIVE_AIN6+ NEGTIVE_AIN7;
     Write_Reg_Mux(a);
     buff[2]=AD_DATA;
     sign[2]=ds[0];
     Send_data_ascii();
//     Send_data_ascii(2);
//     a=POSITIVE_AIN6+ NEGTIVE_AIN7;
//     Write_Reg_Mux(a);
//     Send_data_ascii(3);
//     delayad(50000);
发表于 2025-9-23 10:34:12 | 显示全部楼层
void ADS1256_int()
    ClrADS1256_CLK;
    delayad(2);
    ClrADS1256_CS;
    delayad(10);
    SetADS1256_CS;
#define DATARATE_10SPS            0x23找更高速度的定义,这个是影响采样和数据通信的关键
GMT+8, 2025-12-14 11:49 , Processed in 0.040666 second(s), 24 queries , Gzip On.
