查看: 6182|回复: 1
[求助] imx6ull的LCD管脚怎么当普通的IO
发表于 2021-12-14 16:13:09 | 显示全部楼层 |阅读模式
50火花
因为用的IO比较多,但是我又不用LCD,现在想把LCD的功能禁用掉,将其管脚当普通IO。目前在设备树以及屏蔽掉LCD相关的了,kernel也屏蔽掉LCD,但是当普通IO一直不行,求大家给点建议。
我的设备树:
                pinctrl_led: ledgrp {
                        fsl,pins = <
                                MX6UL_PAD_GPIO1_IO02__GPIO1_IO02        0x49
                                MX6UL_PAD_GPIO1_IO04__GPIO1_IO04        0x14
                                MX6UL_PAD_LCD_DATA16__GPIO3_IO21        0x49
                                MX6UL_PAD_LCD_DATA17__GPIO3_IO22        0x14
                                MX6UL_PAD_LCD_DATA18__GPIO3_IO23        0x17059
                                MX6UL_PAD_LCD_DATA08__GPIO3_IO13         0x17059
                                MX6UL_PAD_LCD_DATA09__GPIO3_IO14        0x17059
                                MX6UL_PAD_LCD_DATA10__GPIO3_IO15        0x17059
                                MX6UL_PAD_LCD_DATA12__GPIO3_IO17         0x17059
                                MX6UL_PAD_LCD_DATA13__GPIO3_IO18        0x17059
                                MX6UL_PAD_LCD_DATA14__GPIO3_IO19        0x17059
                                MX6UL_PAD_LCD_DATA15__GPIO3_IO20         0x17059
        led-lxl {
                #address-cells = <1>;
                #size-cells = <1>;
                compatible = "atkalpha-led";
                pinctrl-names = "default";
                pinctrl-0 = <&pinctrl_led>;
                led-gpio = <&gpio1 2 GPIO_ACTIVE_LOW
                                        &gpio1 4 GPIO_ACTIVE_LOW
                                        &gpio3 21 GPIO_ACTIVE_LOW
                                        &gpio3 22 GPIO_ACTIVE_LOW
                                        &gpio3 23 GPIO_ACTIVE_LOW
                                        &gpio3 13 GPIO_ACTIVE_LOW
                                        &gpio3 14 GPIO_ACTIVE_LOW
                                        &gpio3 15 GPIO_ACTIVE_LOW
                                        &gpio3 17 GPIO_ACTIVE_LOW
                                        &gpio3 18 GPIO_ACTIVE_LOW
                                        &gpio3 19 GPIO_ACTIVE_LOW
                                        &gpio3 20 GPIO_ACTIVE_LOW
                status = "okay";
 楼主| 发表于 2021-12-15 17:35:43 | 显示全部楼层
问题已经解决,主要问题不在设备树上,而是在UBOOT,需要先把uboot中初始化LCD的IO注释掉先。
GMT+8, 2024-11-22 22:08 , Processed in 0.025775 second(s), 22 queries , Gzip On.
