查看: 8981|回复: 3
点灯实验中GPIO_CRL的配置问题
发表于 2022-1-19 13:37:56 | 显示全部楼层 |阅读模式
led接PB5和PE5,gpiox_CRL复位值是0x4444 4444,通过代码设置MODE5为01,并没有对CNF5进行操作,理论上CNF5状态应该是01,对应开漏输出状态,但led灯还是亮了,这个是怎么回事,源代码如下:
unsigned int *GPIOE_ODR= (unsigned int *)(0x4001180c);
unsigned int *GPIOB_ODR= (unsigned int *)(0x40010c0c);
void LED1(char flag){
        if(flag==0){
                *GPIOE_ODR&=~(1<<5);
        else{
                *GPIOE_ODR|=(1<<5);
void LED0(char flag){
        if(flag==0){
                *GPIOB_ODR&=~(1<<5);
        else{
                *GPIOB_ODR|=(1<<5);
void delay(unsigned int x){
        unsigned int i;
        while(x--){
                for(i=500;i>0;i--);
int main(void){
        *(unsigned int *)(0x40021018)|=(1<<3);
        *(unsigned int *)(0x40021018)|=(1<<6);
        *(unsigned int *)(0x40011800)|=(1<<20);
        *(unsigned int *)(0x40010c00)|=(1<<20);
        #if 1           //这里置一或者清零都不对实验现象产生影响
        *(unsigned int *)(0x40011800)&=~(1<<22);
        *(unsigned int *)(0x40010c00)&=~(1<<22);
        #endif
        while(1){
                LED1(0);
                LED0(1);
                delay(5000);
                LED1(1);
                LED0(0);
                delay(5000);
void SystemInit(void){
发表于 2023-1-15 17:39:48 | 显示全部楼层
看的哔站视频是吧,我也是,很纳闷,火哥说CRL复位值是0,我觉得他讲错了,可能这里开漏和推勉都可以喽?
兄弟你解决了吗
发表于 2023-1-19 10:22:29 | 显示全部楼层
这个是直接控制GPIO的电平,哪个模式都可以
发表于 2023-1-19 10:27:32 | 显示全部楼层
只要是输出模式就行
GMT+8, 2024-11-23 14:51 , Processed in 0.087724 second(s), 26 queries , Gzip On.
