查看: 8256|回复: 0
SD卡移植文件系统时字节对齐的问题
发表于 2022-3-13 18:42:42 | 显示全部楼层 |阅读模式
DRESULT disk_read (
        BYTE pdrv,                /* 设备物理编号(0..) */
        BYTE *buff,                /* 数据缓存区 */
        DWORD sector,        /* 扇区首地址 */
        UINT count                /* 扇区个数(1..128) */
        DRESULT status = RES_PARERR;
        SD_Error SD_state = SD_OK;
        switch (pdrv) {
                case ATA:        /* SD CARD */
                  if((DWORD)buff&3)
                                DRESULT res = RES_OK;
                                DWORD scratch[SD_BLOCKSIZE / 4];
                                while (count--)
                                        res = disk_read(ATA,(void *)scratch, sector++, 1);
                                        if (res != RES_OK)
                                                break;
                                        memcpy(buff, scratch, SD_BLOCKSIZE);
                                        buff += SD_BLOCKSIZE;
                    return res;
                        SD_state=SD_ReadMultiBlocks(buff,(uint64_t)sector*SD_BLOCKSIZE,SD_BLOCKSIZE,count);
                  if(SD_state==SD_OK)
                                /* Check if the Transfer is finished */
                                SD_state=SD_WaitReadOperation();
                                while(SD_GetStatus() != SD_TRANSFER_OK);
                        if(SD_state!=SD_OK)
                          status = RES_OK;
                        break;
                case SPI_FLASH:
                break;
                default:
        return status;
     上面是书籍配套例程,是SD卡移植文件系统中的函数,老师讲课时说如果字节不对齐可能会出错,
我想问下为什么用  DWORD scratch[SD_BLOCKSIZE / 4];  定义的数组就一定是四字节对齐的呢?
GMT+8, 2024-11-28 00:19 , Processed in 0.026470 second(s), 23 queries , Gzip On.
