查看: 8281|回复: 2
UART发送字符串程序失败
发表于 2022-3-15 22:03:09 | 显示全部楼层 |阅读模式
我写的这个程序发送字符串,使用单板为指南者,但是串口调试助手没有显示字符串,麻烦哪位大佬帮忙看一下,谢谢!
代码如下:
#include "stm32f10x.h"
#include "bsp_led.h"
#include "bsp_key.h"
#include "stm32f10x.h"                  // Device header
#include "./USART/bsp_usart.h"
#define PBout(n)   *(unsigned int*)(((GPIOB_BASE+0x0C)&0xF0000000)+0x02000000+(((GPIOB_BASE+0x0C)&0x00FFFFFF)<<5)+((n)<<2))
#define PAin(n)    *(unsigned int*)(((GPIOA_BASE+0x08)&0xF0000000)+0x02000000+(((GPIOA_BASE+0x08)&0x00FFFFFF)<<5)+((n)<<2))
int main()
DEBUG_UART_Config();
//USART_SendData(DEBUG_USARTx, 'K');
Usart_SendString(DEBUG_USARTx,"我爱你中国");
while(USART_GetFlagStatus(DEBUG_USARTx, USART_FLAG_TXE == RESET));
#include "bsp_usart.h"
void DEBUG_UART_Config()
GPIO_InitTypeDef GPIO_InitStructure; /*11111*/
//第一步 初始化GPIO
RCC_APB2PeriphClockCmd(DEBUG_USART_GPIO_CLK,ENABLE);
GPIO_InitStructure.GPIO_Pin = DEBUG_USART_TX_GPIO_PIN;
GPIO_Init(DEBUG_USART_TX_GPIO_PORT, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = DEBUG_USART_RX_GPIO_PIN;
GPIO_Init(DEBUG_USART_RX_GPIO_PORT, &GPIO_InitStructure);
//第二步 配置串口的初始化结构体
RCC_APB2PeriphClockCmd(DEBUG_USART_CLK,ENABLE);
USART_InitStructure.USART_BaudRate = DEBUG_USART_BAUDRATE;
USART_Init(DEBUG_USARTx, &USART_InitStructure);
//第三步 使能串口
USART_Cmd(DEBUG_USARTx, ENABLE);
void Usart_SendByte(USART_TypeDef* pUSARTx, uint8_t ch)
USART_SendData(pUSARTx,ch);
while(USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE == RESET));
void Usart_SendString(USART_TypeDef* pUSARTx, char *str)
unsigned int k = 0;
do
  Usart_SendByte(pUSARTx,*(str+k));
  k++;
}while(*(str + k)!='\0');
while(USART_GetFlagStatus(pUSARTx, USART_FLAG_TC == RESET));
#ifndef _BSP_USART_H
#define _BSP_USART_H
#define DEBUG_USARTx                         USART1
#define DEBUG_USART_CLK                      RCC_APB2Periph_USART1
#define DEBUG_USART_APBxClkCmd               RCC_APB2PeriphClockCmd
#define DEBUG_USART_BAUDRATE                 115200
#define DEBUG_USART_GPIO_CLK                 (RCC_APB2Periph_GPIOA)
#define DEBUG_USART_GPIO_APBxClkCmd          (RCC_APB2Periph_GPIOA)
#define DEBUG_USART_TX_GPIO_PORT              GPIOA
#define DEBUG_USART_TX_GPIO_PIN               GPIO_Pin_9
#define DEBUG_USART_RX_GPIO_PORT              GPIOA
#define DEBUG_USART_RX_GPIO_PIN               GPIO_Pin_10
#define DEBUG_USART_IRQ                       USART_IRQn
#define DEBUG_USART_IRQHandler                USART_IRHandler
void DEBUG_UART_Config(void);
void Usart_SendString(USART_TypeDef* pUSARTx, char *str);
#endif  /*BSP_USART_H*/
发表于 2022-3-17 10:39:14 | 显示全部楼层
检查usb转串口那边跳帽有没有盖好 串口助手打开com号后按下复位
发表于 2022-3-19 14:14:05 | 显示全部楼层
这个有可能是你的串口调试助手的问题,首先你用HEX查看一下是否收到数据,如果没有收到数据,说明没有发出来,如果收到数据了,但是没有显示,那有可能是你的串口调试助手不能识别的原因,换一个有可能就好了
GMT+8, 2024-11-23 12:32 , Processed in 0.028248 second(s), 23 queries , Gzip On.
