您好, 我想知道有人是否可以帮助我解决我的问题。我几乎没有编程经验。我正在尝试构建一个设备,该设备使用 Arduino Uno 在 1.8" TFT 显示器上绘制来自 9 轴运动屏蔽的加速度计数据。我想尽可能接近实时地绘制数据。 我找到了三个示例程序我认为包含实现这一切所需的一切。我缺乏正确组合它们的专业知识 。TFT 图形测试 模拟图 9 轴屏蔽样本:加速度计 从加速度计示例中,我只需要一个轴来绘制图形。我在想我可以用该数据替换 TFT 图形示例中的电位器电压。 非常感谢任何帮助。 谢谢!  Hello! I wonder if embrio can help me solve my problem. I have little programming experience. I'm trying to build a device that uses Arduino uno to draw accelerometer data from 9-axis motion shielding on a 1.8 "TFT display. I want to draw the data as close to real time as possible. I found three sample programs that I think contain everything needed to do all this. I lack the expertise to correctly combine them 。 TFT graphic test Simulation diagram 9-axis shield sample: accelerometer From the accelerometer example, I only need one axis to draw the graph. I was thinking that I could replace the potentiometer voltage in the TFT graphic example with this data. Thank you very much for any help. Thank you!
