初中生
最后登录1970-1-1
在线时间 小时
注册时间2021-6-3
SRAM_HandleTypeDef hsram1;
/* FSMC initialization function */
void MX_FSMC_Init(void)
/* USER CODE BEGIN FSMC_Init 0 */
/* USER CODE END FSMC_Init 0 */
FSMC_NORSRAM_TimingTypeDef Timing = {0};
/* USER CODE BEGIN FSMC_Init 1 */
/* USER CODE END FSMC_Init 1 */
/** Perform the SRAM1 memory initialization sequence
hsram1.Instance = FSMC_NORSRAM_DEVICE;
hsram1.Extended = FSMC_NORSRAM_EXTENDED_DEVICE;
/* hsram1.Init */
hsram1.Init.NSBank = FSMC_NORSRAM_BANK4; // FSMC_NORSRAM_BANK4 FSMC_NORSRAM_BANK4
hsram1.Init.DataAddressMux = FSMC_DATA_ADDRESS_MUX_DISABLE;
hsram1.Init.MemoryType = FSMC_MEMORY_TYPE_NOR; // FSMC_MEMORY_TYPE_NOR FSMC_MEMORY_TYPE_SRAM
hsram1.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_16;
hsram1.Init.BurstAccessMode = FSMC_BURST_ACCESS_MODE_DISABLE;
hsram1.Init.WaitSignalPolarity = FSMC_WAIT_SIGNAL_POLARITY_LOW;
hsram1.Init.WrapMode = FSMC_WRAP_MODE_DISABLE;
hsram1.Init.WaitSignalActive = FSMC_WAIT_TIMING_BEFORE_WS;
hsram1.Init.WriteOperation = FSMC_WRITE_OPERATION_ENABLE;
hsram1.Init.WaitSignal = FSMC_WAIT_SIGNAL_DISABLE;
hsram1.Init.ExtendedMode = FSMC_EXTENDED_MODE_DISABLE;
hsram1.Init.AsynchronousWait = FSMC_ASYNCHRONOUS_WAIT_DISABLE;
hsram1.Init.WriteBurst = FSMC_WRITE_BURST_DISABLE;
/* Timing */
Timing.AddressSetupTime = 0;
Timing.AddressHoldTime = 0;
Timing.DataSetupTime = 8;
Timing.BusTurnAroundDuration = 0;
Timing.CLKDivision = 0;
Timing.DataLatency = 0;
Timing.AccessMode = FSMC_ACCESS_MODE_B;
/* ExtTiming */
if (HAL_SRAM_Init(&hsram1, &Timing, NULL) != HAL_OK)
Error_Handler( );
/** Disconnect NADV
__HAL_AFIO_FSMCNADV_DISCONNECTED();
/* USER CODE BEGIN FSMC_Init 2 */
/* USER CODE END FSMC_Init 2 */
// 然后我使用配套的代码 也点不亮,使用例程就可以,
* @brief 初始化ILI9341的IO引脚
* @param 无
* @retval 无
static void ILI9341_GPIO_Config ( void )
GPIO_InitTypeDef GPIO_Initure;
/* Enable GPIOs clock */
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOE_CLK_ENABLE();
__HAL_RCC_GPIOF_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
__HAL_RCC_FSMC_CLK_ENABLE(); //使能FSMC时钟
/* Common GPIO configuration */
GPIO_Initure.Mode = GPIO_MODE_OUTPUT_PP; //推挽输出
GPIO_Initure.Pull = GPIO_PULLUP;
GPIO_Initure.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_Initure.Pin=GPIO_PIN_6; // GPIO_PIN_12
HAL_GPIO_Init(GPIOG,&GPIO_Initure);
//初始化复位引脚G11
GPIO_Initure.Pin=GPIO_PIN_11;
GPIO_Initure.Mode=GPIO_MODE_AF_PP;
// GPIO_Initure.Alternate=GPIO_AF12_FSMC; //复用为FSMC
//初始化PD0,1,4,5,8,9,10,14,15
GPIO_Initure.Pin=GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_8|\
GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_14|GPIO_PIN_15;
HAL_GPIO_Init(GPIOD, &GPIO_Initure);
//初始化PE2,7,8,9,10,11,12,13,14,15
GPIO_Initure.Pin=GPIO_PIN_2|GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|\
GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
HAL_GPIO_Init(GPIOE,&GPIO_Initure);
//初始化G12
GPIO_Initure.Pin=GPIO_PIN_12; // PG6 复用推挽输出 GPIO_PIN_6
* @brief LCD FSMC 模式配置
* @param 无
* @retval 无
static void ILI9341_FSMC_Config ( void )
SRAM_Handler.Instance = FSMC_NORSRAM_DEVICE;
SRAM_Handler.Extended = FSMC_NORSRAM_EXTENDED_DEVICE;
/* SRAM device configuration */
Timing.AddressSetupTime = 0x00;
Timing.AddressHoldTime = 0x00;
Timing.DataSetupTime = 0x08;
Timing.BusTurnAroundDuration = 0x00;
Timing.CLKDivision = 0x00;
Timing.DataLatency = 0x00;
SRAM_Handler.Init.NSBank=FSMC_Bank1_NORSRAMx ; //使用NE4
SRAM_Handler.Init.DataAddressMux=FSMC_DATA_ADDRESS_MUX_DISABLE; //地址/数据线不复用
SRAM_Handler.Init.MemoryType=FSMC_MEMORY_TYPE_NOR; //NOR
SRAM_Handler.Init.MemoryDataWidth=FSMC_NORSRAM_MEM_BUS_WIDTH_16; //16位数据宽度
SRAM_Handler.Init.BurstAccessMode=FSMC_BURST_ACCESS_MODE_DISABLE; //是否使能突发访问,仅对同步突发存储器有效,此处未用到
SRAM_Handler.Init.WaitSignalPolarity=FSMC_WAIT_SIGNAL_POLARITY_LOW;//等待信号的极性,仅在突发模式访问下有用
SRAM_Handler.Init.WaitSignalActive=FSMC_WAIT_TIMING_BEFORE_WS; //存储器是在等待周期之前的一个时钟周期还是等待周期期间使能NWAIT
SRAM_Handler.Init.WriteOperation=FSMC_WRITE_OPERATION_ENABLE; //存储器写使能
SRAM_Handler.Init.WaitSignal=FSMC_WAIT_SIGNAL_DISABLE; //等待使能位,此处未用到
SRAM_Handler.Init.ExtendedMode=FSMC_EXTENDED_MODE_DISABLE; //读写使用相同的时序
SRAM_Handler.Init.AsynchronousWait=FSMC_ASYNCHRONOUS_WAIT_DISABLE; //是否使能同步传输模式下的等待信号,此处未用到
SRAM_Handler.Init.WriteBurst=FSMC_WRITE_BURST_DISABLE; //禁止突发写
/* SRAM controller initialization */
ILI9341_GPIO_Config();
HAL_SRAM_Init(& SRAM_Handler, &Timing, &Timing);
