查看: 6346|回复: 0
GD32的DMA的多数据结构和单数据结构有什么区别
发表于 2023-4-3 23:19:56 | 显示全部楼层 |阅读模式
GD32的DMA的多数据结构和单数据结构有什么区别!!!!
/* DMA multidata mode initialize struct */
typedef struct
    uint32_t periph_addr;                           /*!< peripheral base address */
    uint32_t periph_width;                          /*!< transfer data size of peripheral */
    uint32_t periph_inc;                            /*!< peripheral increasing mode */
    uint32_t memory0_addr;                          /*!< memory 0 base address */
    uint32_t memory_width;                          /*!< transfer data size of memory */
    uint32_t memory_inc;                            /*!< memory increasing mode */
    uint32_t memory_burst_width;                    /*!< multi data mode enable */
    uint32_t periph_burst_width;                    /*!< multi data mode enable */
    uint32_t critical_value;                        /*!< FIFO critical */
    uint32_t circular_mode;                         /*!< DMA circular mode */
    uint32_t direction;                             /*!< channel data transfer direction */
    uint32_t number;                                /*!< channel transfer number */
    uint32_t priority;                              /*!< channel priority level */
}dma_multi_data_parameter_struct;
/* DMA singledata mode initialize struct */
typedef struct
    uint32_t periph_memory_width;                   /*!< transfer data size of peripheral */
} dma_single_data_parameter_struct;
GMT+8, 2025-4-4 14:10 , Processed in 0.112592 second(s), 24 queries , Gzip On.
