查看: 4396|回复: 0
大佬们 为什么我的gy906非接触式测温模块测的温度一直是-273
发表于 2023-4-19 15:39:45 | 显示全部楼层 |阅读模式
这个模块是没焊接的 买来之后自己焊接上显示-273(既然能输出 显示-273 代码应该没问题吧),后来发现虚焊了,又去焊接了一下结果还是-273,难道是硬件坏了?很奇怪 会不会是代码不匹配的问题。
         float temp=0.0;
        delay_init();                     //ÑÓʱº¯Êý³õʼ»¯
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //ÉèÖÃNVICÖжϷÖ×é2:2λÇÀÕ¼ÓÅÏȼ¶£¬2λÏìÓ¦ÓÅÏȼ¶
        uart_init(115200);         //´®¿Ú³õʼ»¯Îª115200
        LED_Init();                             //LED¶Ë¿Ú³õʼ»¯
        KEY_Init();          //³õʼ»¯Óë°´¼üÁ¬½ÓµÄÓ²¼þ½Ó¿Ú
         SMBus_Init();
                LED0=!LED0;
                delay_ms(100);
                temp=SMBus_ReadTemp();
                printf("ζÈֵΪ£º%.2f\r\n",temp);
接线按照下面接的
#include "mlx90614.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define ACK         0 //Ó¦´ð
#define        NACK 1 //ÎÞÓ¦´ð
#define SA                                0x00 //Slave address µ¥¸öMLX90614ʱµØַΪ0x00,¶à¸öʱµØַĬÈÏΪ0x5a
#define RAM_ACCESS                0x00 //RAM access command RAM´æÈ¡ÃüÁî
#define EEPROM_ACCESS        0x20 //EEPROM access command EEPROM´æÈ¡ÃüÁî
#define RAM_TOBJ1                0x07 //To1 address in the eeprom Ä¿±ê1ζÈ,¼ì²âµ½µÄºìÍâÎÂ¶È -70.01 ~ 382.19¶È
#define SMBUS_PORT        GPIOB      //PB¶Ë¿Ú(¶Ë¿ÚºÍÏÂÃæµÄÁ½¸öÕë½Å¿É×Ô¶¨Òå)
#define SMBUS_SCK                GPIO_Pin_6 //PB6£ºSCL
#define SMBUS_SDA                GPIO_Pin_7 //PB7£ºSDA2
#define RCC_APB2Periph_SMBUS_PORT                RCC_APB2Periph_GPIOB
#define SMBUS_SCK_H()            SMBUS_PORT->BSRR = SMBUS_SCK //Öøߵçƽ
#define SMBUS_SCK_L()            SMBUS_PORT->BRR = SMBUS_SCK  //Öõ͵çƽ
#define SMBUS_SDA_H()            SMBUS_PORT->BSRR = SMBUS_SDA
#define SMBUS_SDA_L()            SMBUS_PORT->BRR = SMBUS_SDA
GMT+8, 2025-4-13 04:27 , Processed in 0.104759 second(s), 24 queries , Gzip On.
