查看: 3045|回复: 3
ubuntu下更新 lubancat的sdk LubanCat_Linux_SDK_20230419包报一下错
发表于 2023-6-7 08:25:58 | 显示全部楼层 |阅读模式
lijune:~/lubancat/LubanCat_Linux_SDK_20230419$ repo sync .
Traceback (most recent call last):
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/main.py", line 705, in <module>
    _Main(sys.argv[1:])
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/main.py", line 681, in _Main
    result = repo._Run(name, gopts, argv) or 0
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/main.py", line 228, in _Run
    result = run()
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/main.py", line 219, in <lambda>
    run = lambda: self._RunLong(name, gopts, argv) or 0
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/main.py", line 314, in _RunLong
    result = cmd.Execute(copts, cargs)
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/subcmds/sync.py", line 1273, in Execute
    m.manifestProject.PreSync()
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/project.py", line 3380, in PreSync
    cb = self.CurrentBranch
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/project.py", line 641, in CurrentBranch
    b = self.work_git.GetHead()
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/project.py", line 3111, in GetHead
    path = self.GetDotgitPath(subpath=HEAD)
  File "/home/liujun/lubancat/LubanCat_Linux_SDK_20230419/.repo/repo/project.py", line 3103, in GetDotgitPath
    assert setting.startswith('gitdir:')
AssertionError
 楼主| 发表于 2023-6-7 09:46:50 | 显示全部楼层
刚试了,python的版本
virtual-machine:~/lubancat/LubanCat_Linux_SDK_20230419$ python --version
Python 3.10.6
 楼主| 发表于 2023-6-7 14:29:58 | 显示全部楼层
分析了一下xml
<project dest-branch="master" name="device_rockchip" path="device/rockchip" revision="1bdb034914928ad1c51144a7d5926a994d12c196" upstream="master">
    <linkfile dest="mkfirmware.sh" src="common/mkfirmware.sh"/>
    <linkfile dest="build.sh" src="common/build.sh"/>
    <linkfile dest="rkflash.sh" src="common/rkflash.sh"/>
    <linkfile dest="device/rockchip/.target_product" src="rk356x"/>
  </project>
  <project dest-branch="master" name="deviceio_release" path="external/deviceio_release" remote="rk-github" revision="187439b6c9ed867c5a28d8b39cb2ecf19ba9dae6" upstream="master"/>
  <project dest-branch="master" name="gcc-buildroot-9.3.0-2020.03-x86_64_aarch64-rockchip-linux-gnu" path="prebuilts/gcc/linux-x86/aarch64/gcc-buildroot-9.3.0-2020.03-x86_64_aarch64-rockchip-linux-gnu" revision="427f5439bf87835ff3b20746acc8aaafba7d4f53" upstream="master"/>
  <project dest-branch="master" name="gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu" path="prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu" revision="f96f76d6be89a6e28d4dac1f233f9aca9921f69b" upstream="master"/>
  <project name="gstreamer-rockchip" path="external/gstreamer-rockchip" remote="rk-github" revision="9db260682e11ff6d5ca70f22e3a9e980a5f6ecd1" upstream="master"/>
  <project dest-branch="stable-4.19-rk356x" name="kernel" revision="327a4c875ed64b99592bcdcd3293955554d1ba73" upstream="stable-4.19-rk356x"/>
  <project dest-branch="master" name="libmali" path="external/libmali" revision="74d74912a708da0eeb55029b9ae953206a734dd6" upstream="master"/>
  <project dest-branch="im2d" name="linux-rga" path="external/linux-rga" remote="rk-github" revision="1e2f0dbb838de3512a8a29143196d7b5e460e1ca" upstream="im2d"/>
  <project dest-branch="develop" name="mpp" path="external/mpp" remote="rk-github" revision="9ffb11ca0ad1ec1c08d673af5020c5efd0006a42" upstream="develop"/>
  <project dest-branch="master" name="multivideoplayer" path="app/multivideoplayer" remote="rk-github" revision="5d566e0b2ab416c251b54d59d6237e7164c7e270" upstream="master"/>
  <project dest-branch="master" name="qcamera" path="app/qcamera" remote="rk-github" revision="3a74b34724828075bcb9f51b704e0c50e7dadaec" upstream="master"/>
  <project dest-branch="master" name="qfm" path="app/qfm" remote="rk-github" revision="7e94be4d1ce41e395909da8b963ad46c65ca285f" upstream="master"/>
  <project dest-branch="master" name="qplayer" path="app/qplayer" remote="rk-github" revision="0121646c9fe2335eef9a963071d07b797a17487e" upstream="master"/>
  <project dest-branch="develop" name="recovery" path="external/recovery" remote="rk-github" revision="69eb9ffe14c08e144205b096d91176c88fbfa345" upstream="develop"/>
  <project dest-branch="master" name="rkbin" revision="1f4778f3145971f8a2f84ad7ac46832fbde58768" upstream="master"/>
  <project dest-branch="master" name="rknpu2" path="external/rknpu2" remote="rk-github" revision="c0303684992ded83acb3c9e153d8920172dffd64" upstream="master"/>
  <project dest-branch="master" name="rkscript" path="external/rkscript" remote="rk-github" revision="6c1303d90b979ccd30ebea43d4f942e5aa6f8860" upstream="master"/>
  <project dest-branch="master" name="rktoolkit" path="external/rktoolkit" remote="rk-github" revision="77fb41f99185a6f9dc2c9c69e099f417d8ae905d" upstream="master"/>
  <project dest-branch="master" name="rkupdate" path="external/rkupdate" remote="rk-github" revision="534d8750105c2649e24648b40551fa1304f5eeab" upstream="master"/>
  <project dest-branch="master" name="rkwifibt" path="external/rkwifibt" revision="175e30a3aa42946044468b8f15dea1e09fade517" upstream="master"/>
  <project dest-branch="develop" name="settings" path="app/qsetting" revision="7719da2d42787bac1a6fe075f2ddf6157cd5d678" upstream="develop"/>
  <project dest-branch="master" name="tools" revision="e8adb3e955688312a9d4d240da2bdca965c57a44" upstream="master">
    <linkfile dest="tools/windows/RKDevTool/RKDevTool_Release/config.cfg" src="windows/RKDevTool/RKDevTool_Release/rk356x-config.cfg"/>
    <linkfile dest="tools/windows/RKDevTool/rockdev/package-file" src="windows/RKDevTool/rockdev/rk356x-package-file"/>
    <linkfile dest="tools/windows/RKDevTool/rockdev/mkupdate.bat" src="windows/RKDevTool/rockdev/rk356x-mkupdate.bat"/>
    <linkfile dest="tools/linux/Linux_Pack_Firmware/rockdev/mkupdate.sh" src="linux/Linux_Pack_Firmware/rockdev/rk356x-mkupdate.sh"/>
    <linkfile dest="tools/linux/Linux_Pack_Firmware/rockdev/package-file" src="linux/Linux_Pack_Firmware/rockdev/rk356x-package-file"/>
  </project>
  <project dest-branch="next-dev" name="u-boot" revision="ca2fcac8aad9b96713cef0182370c5879a95f8fe" upstream="next-dev"/>
</manifest>
GMT+8, 2024-11-23 08:24 , Processed in 0.033358 second(s), 24 queries , Gzip On.
