查看: 1849|回复: 2
[求助] 开发板 无法连接WIFI
发表于 2023-7-29 21:24:58 | 显示全部楼层 |阅读模式
使用fire-config连接打开并wifi,但是提示这个错误
[   29.134560] [dhd-wlan0] wl_cfg80211_connect : Connecting with 76:d8:3e:f5:26:fc ssid "hp", len (2), sec=wpa2psk/mfpn/aes, channel=1[   29.134560][   29.305121] [dhd-wlan0] wl_iw_event : Link UP with 76:d8:3e:f5:26:fc[   29.312856] [dhd-wlan0] wl_ext_iapsta_event : [S] Link UP with 76:d8:3e:f5:26:fc[   29.325950] [dhd-wlan0] wl_bss_connect_done : Report connect result - connection succeeded[   29.433617] [dhd-wlan0] wl_add_keyext : key index (0)debian@npi:~$ sudo fire-config[   42.479318] sched: RT throttling activated[   45.515774] systemd-journald[194]: /dev/kmsg buffer overrun, some messages lost.[   46.513559] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=1, on_failure=1[   48.519823] systemd-journald[194]: /dev/kmsg buffer overrun, some messages lost.[   51.516507] systemd-journald[194]: /dev/kmsg buffer overrun, some messages lost.[   53.531042] [dhd-wlan0] wl_android_wifi_off : out
 楼主| 发表于 2023-7-29 21:35:12 | 显示全部楼层
显示信息
 楼主| 发表于 2023-7-29 21:36:16 | 显示全部楼层
系统版本
GMT+8, 2024-11-23 01:58 , Processed in 0.039722 second(s), 26 queries , Gzip On.
