查看: 1314|回复: 2
FATFS源码移植的问题
回帖奖励 50 火花 回复本帖可获得 10 火花奖励! 每人限 1 次
发表于 2023-8-20 23:11:49 | 显示全部楼层 |阅读模式
文件系统的挂载和初始化都没问题,问题出在了f_open,f_open的错误码为FR_WRITE_PROTECTED
FR_WRITE_PROTECTED好像表示不能创建打开/写文件了
不知道问题出在哪里,求助各位大佬
main.c中有关FATFS的内容如下:
FATFS flash_fs;
FRESULT status;
BYTE work[FF_MAX_SS];
FIL file;
uint8_t write_buffer[] = "hehehehehehehehehehe";
UINT writtenbyte;
        HAL_Init();
        SystemClock_Config();
        MX_GPIO_Init();
        MX_SPI1_Init();
        MX_USART1_UART_Init();
    printf("\r\nFATFS 文件系统测试例程\r\n");
    /* 挂载和初始化文件系统 */
    status = f_mount(&flash_fs, "0:", 1);
    if(status == FR_NO_FILESYSTEM)
        printf("文件系统挂载失败,原因是没有文件系统\n");
        printf("正在格式化文件系统\n");
        status = f_mkfs("0:", NULL, work, sizeof work);
        if(status != FR_OK)
            printf("格式化文件系统失败,错误码为(%d)\n", status);
            printf("格式化文件系统成功\n");
            f_mount(NULL, "0:", 1);
    else if(status != FR_OK)
        printf("文件系统挂载失败,失败码为(%d)\n", status);
        printf("文件系统挂载成功,可以进行读写测试!\n");
    /* 写文件测试 */
    printf("\r\n写文件测试\r\n");
    status = f_open(&file, "0:测试文档.txt", FA_CREATE_ALWAYS | FA_WRITE);
    if(status != FR_OK)
        printf("文件打开/创建失败,失败码为(%d)\n", status);
        printf("文件打开/创建成功\n");
        printf("开始写文件\n");
        status = f_write(&file, write_buffer, sizeof(write_buffer), &writtenbyte);
        if(status != FR_OK)
            printf("写文件失败,失败码为(%d)\n", status);
            printf("写文件成功\n");
            printf("写进文件的内容是%s,写了%d个字节\n", write_buffer, writtenbyte);
现象如下:
diskio.c中有关内容如下:
#define DEV_FLASH       0
DSTATUS disk_status (
    BYTE pdrv       /* Physical drive nmuber to identify the drive */
    DSTATUS stat;
    int result;
    switch (pdrv) {
    case DEV_FLASH :
        result = Read_FLASH_JEDECID();
        // translate the reslut code here
        if(result == W25Q64_JEDECID)
            stat &= ~ STA_NOINIT;
            stat = STA_NOINIT;
        return stat;
    return STA_NOINIT;
DSTATUS disk_initialize (
    DSTATUS stat;
    switch (pdrv) {
    case DEV_FLASH :
        WakeUp();
        stat = disk_status(pdrv);
        return stat;
    return STA_NOINIT;
DRESULT disk_write (
    BYTE pdrv,          /* Physical drive nmuber to identify the drive */
    const BYTE *buff,   /* Data to be written */
    LBA_t sector,       /* Start sector in LBA */
    UINT count          /* Number of sectors to write */
    DRESULT res;
    uint32_t EraseCount;
    LBA_t sector_temp;
    switch (pdrv) {
    case DEV_FLASH :
        sector += (2048/4);
        sector_temp = sector;
        EraseCount = count;
        while(EraseCount--)
            SectorErase(sector_temp*4096);
            sector_temp += 4096;
        BufferWrite(sector*4096, count*4096, (BYTE *)buff);
        res = RES_OK;
        return res;
    return RES_PARERR;
> 说明: > > disk_initialize中没有初始化flash是因为main函数中已经在使用文件系统前就已经初始化完成,所以就没再初始化flash
flash的bsp有关如下:
static uint8_t Read_And_Receive_Byte(uint8_t Byte)
    HAL_StatusTypeDef FunctionStatus;
    uint8_t TxData[1];
    uint8_t RxData[1];
    TxData[0] = Byte;
    FunctionStatus = HAL_SPI_TransmitReceive(&hspi1, TxData, RxData, 1, 0xFFF);
    if(FunctionStatus != HAL_OK)
        return FunctionStatus;
    return RxData[0];
void PageWrite(uint32_t PageAddress, uint32_t NumByteToWrite, uint8_t * WriteData)
    WriteEnable();
    FLASH_COMMUNICATE_START();
    Read_And_Receive_Byte(PageProgram_CODE);
    Read_And_Receive_Byte((PageAddress&0xFF0000)>>16);
    Read_And_Receive_Byte((PageAddress&0xFF00)>>8);
    Read_And_Receive_Byte(PageAddress&0xFF);
    if(NumByteToWrite > FLASH_PerPageWriteSize)
        NumByteToWrite = FLASH_PerPageWriteSize;
        FLASH_INFO("Page Write Number is OverFlow");
    while(NumByteToWrite--)
        Read_And_Receive_Byte(*WriteData);
        WriteData++;
    FLASH_COMMUNICATE_STOP();
    WaitForWriteEnd();
void BufferWrite(uint32_t PageAddress, uint32_t NumByteToWrite, uint8_t * WriteData)
    // 在一个页的什么位置
    uint8_t WhichNumOfPage;
    // 距离下一个页还剩多少
    uint8_t NumToNextPage;
    // 需要写多少次整页
    uint8_t NumPageToWrite;
    // 写完所有整页后还剩写多少字节
    uint8_t NumByteToFinalWrite;
    WhichNumOfPage = PageAddress % FLASH_PageSize;
    NumToNextPage = FLASH_PageSize - WhichNumOfPage;
    NumPageToWrite = NumByteToWrite / FLASH_PageSize;
    NumByteToFinalWrite = NumByteToWrite % FLASH_PageSize;
    // 地址对齐
    if(WhichNumOfPage == 0)
        // 不足写一整页
        if(NumPageToWrite == 0)
            PageWrite(PageAddress, NumByteToWrite, WriteData);
        // 足够写一页
            while(NumPageToWrite--)
                PageWrite(PageAddress, FLASH_PageSize, WriteData);
                PageAddress += FLASH_PageSize;
                WriteData += FLASH_PageSize;
            PageWrite(PageAddress, NumByteToFinalWrite, WriteData);
    // 地址未对齐
        // 不足写一整页
            // 写的数量不足到下一页
            if(NumByteToWrite <= NumToNextPage)
            // 写的数量足够到下一页
                PageWrite(PageAddress, NumToNextPage, WriteData);
                PageAddress += NumToNextPage;
                WriteData += NumToNextPage;
                PageWrite(PageAddress, NumByteToWrite - NumToNextPage, WriteData);
        // 足够写一页
            NumByteToWrite -= NumToNextPage;
个人觉得问题应该不存在flash的bsp中,因为bsp中的各个API都经过测试都是可以正常使用的
 楼主| 发表于 2023-8-21 15:15:12 | 显示全部楼层
真相了,兄弟们,原因竟然真的出在了flash的bsp中
我们都知道大部分型号的FLASH都有着以下的编程要求:
  1. 擦除和写入前需要使能写入
  2. 写入数据前必须先擦除
  3. 擦除和写入后需要等待FLASH内部时序是否完成
这里报写保护的错误就出现在了擦除和写入后需要等待FLASH内部时序是否完成这一步
错误代码如下:
#define MAX_TimeOut (uint32_t)0x5000
static void WaitForWriteEnd(void)
    uint8_t RegStatus;
    uint32_t SPITimeout;
        SPITimeout = MAX_TimeOut;
    Read_And_Receive_Byte(ReadStatusRegister1_CODE);
    do
        RegStatus = Read_And_Receive_Byte(Dummy_Byte);
        if((SPITimeout--) == 0)
            printf("Wait For Write End Time out!\n");
            return ;
    while((RegStatus & 1) == SET);
  • 初看好像没有什么问题,问题出在这个SPITimeout的变量,这个变量好像会被优化掉,在函数内加__IO也不行,只能把它拿出来放在全局变量中,修改后如下:
  • #define MAX_TimeOut (uint32_t)0x5000
    static __IO uint32_t  SPITimeout = MAX_TimeOut;
      uint8_t RegStatus;
      do
              FLASH_ERROR("Wait For Write End Time out!");
              return ;
不过,错误的等待FLASH内部时序是否完成的函数在SPI FLASH的实验中依然好使
但是还是不知道为什么等待FLASH内部时序是否完成出现错误就会导致FLASH的写保护?
对于这个问题,有懂的老哥可以讲一下吗?
 楼主| 发表于 2023-8-22 10:02:01 | 显示全部楼层
完蛋了,昨天还没问题,今天又开始出现Flash写保护了,求求大佬!!
GMT+8, 2024-11-22 09:08 , Processed in 0.042638 second(s), 29 queries , Gzip On.
