查看: 25353|回复: 4
学习 scanf 开发板范例 链接 出错 Undefined symbol __vfscanf_char_file (referred
发表于 2014-4-18 17:07:36 | 显示全部楼层 |阅读模式
linking...
.\Obj\output.axf: Error: L6218E: Undefined symbol __vfscanf_char_file (referred from __0scanf.o).
.\Obj\output.axf: Not enough information to list image symbols.
.\Obj\output.axf: Finished: 1 information, 0 warning and 1 error messages.
Target not created
为什么编译出现上述错误?初学scanf,希望得到指点,不胜感激...
main.c
#include "stm32f10x.h"
#include <stdio.h>
#include "usart_printf.h"
#define EXAMPLE_NAME        "printf & scanf Testing"
#define EXAMPLE_DATE        "2010-01-02"
        函数名:main
        输  入:
        输  出:
        功能说明:用户程序入口
                这个函数是ST库中的函数,函数实体在
                Libraries\CMSIS\Core\CM3\system_stm32f10x.c
                配置内部Flash接口,初始化PLL,配置系统频率
                系统时钟缺省配置为72MHz,你如果需要更改,则需要去修改相关的头文件中的宏定义
        SystemInit();
        /* 配置串口, 该函数在usart_printf.c */
        USART_Configuration();
        /* 通过串口输出例程名和更新日期 */
        PrintfLogo(EXAMPLE_NAME, EXAMPLE_DATE);
        /* KEIL 下,编译scanf,功能正确,但是在IAR下编译,scanf会遗漏首字符(原因待查) */
        while (1)
                int a,b,c;
                char str[200];
                printf("input 3 number a,b,c :\r\n");
                scanf("%d", &a);
                scanf("%d", &b);
                scanf("%d", &c);
                printf("a=%d, b=%d, c=%d\r\n",a,b,c);
                printf("input a sting :\r\n");
                scanf("%s", str);
                printf("str = %s\r\n", str);
                printf("\r\n");
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
uart.c
/* Includes ------------------------------------------------------------------*/
#include <stdio.h>
        函数名:PrintfLogo
        输  入: 例程名称和例程最后更新日期
        输  出:
        功能说明:
void PrintfLogo(char *strName, char *strDate)
        printf("*************************************************************\n\r");
        printf("* Example Name : %s\r\n", strName);
        printf("* Update Date  : %s\r\n", strDate);
        printf("* StdPeriph_Lib Version : V3.1.2\n\r");
        printf("* \n\r");
        printf("* Copyright www.armfly.com \r\n");
        printf("* QQ    : 1295744630 \r\n");
        printf("* Email : armfly@qq.com \r\n");
        函数名:USART_Configuration
        输  入:
        输  出:
        功能说明:
        初始化串口硬件设备,未启用中断。
        配置步骤:
        (1)打开GPIO和USART的时钟
        (2)设置USART两个管脚GPIO模式
        (3)配置USART数据格式、波特率等参数
        (4)最后使能USART功能
void USART_Configuration(void)
        /* 第1步:打开GPIO和USART部件的时钟 */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
        /* 第2步:将USART Tx的GPIO配置为推挽复用模式 */
        /* 第3步:将USART Rx的GPIO配置为浮空输入模式
                由于CPU复位后,GPIO缺省都是浮空输入模式,因此下面这个步骤不是必须的
                但是,我还是建议加上便于阅读,并且防止其它地方修改了这个口线的设置参数
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        /*  第3步已经做了,因此这步可以不做
        /* 第4步:配置USART参数
            - BaudRate = 115200 baud
            - Word Length = 8 Bits
            - One Stop Bit
            - No parity
            - Hardware flow control disabled (RTS and CTS signals)
            - Receive and transmit enabled
        USART_InitStructure.USART_BaudRate = 115200;
        USART_Init(USART1, &USART_InitStructure);
        /* 第5步:使能 USART, 配置完毕 */
        USART_Cmd(USART1, ENABLE);
        /* CPU的小缺陷:串口配置好,如果直接Send,则第1个字节发送不出去
                如下语句解决第1个字节无法正确发送出去的问题 */
        USART_ClearFlag(USART1, USART_FLAG_TC);     /* 清发送外城标志,Transmission Complete flag */
        函数名:fputc
        输  入:
        输  出:
        功能说明:
        重定义putc函数,这样可以使用printf函数从串口1打印输出
int fputc(int ch, FILE *f)
        /* Place your implementation of fputc here */
        /* e.g. write a character to the USART */
        USART_SendData(USART1, (uint8_t) ch);
        /* Loop until the end of transmission */
        while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
        return ch;
        函数名:fputc
        输  入:
        输  出:
        功能说明:
        重定义getc函数,这样可以使用scanff函数从串口1输入数据
int fgetc(FILE *f)
        /* 等待串口1输入数据 */
        while (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
        return (int)USART_ReceiveData(USART1);
发表于 2014-4-18 17:10:05 | 显示全部楼层
在工程选项里把微库勾上看看
 楼主| 发表于 2014-4-18 17:14:41 | 显示全部楼层
勾了。也是这样。
发表于 2014-4-18 17:33:59 | 显示全部楼层
mingguo001 发表于 2014-4-18 17:14
勾了。也是这样。
勾了之后,清理工程整个工程重新编译一下
 楼主| 发表于 2014-4-19 11:13:51 | 显示全部楼层
弄好了 是MDK的版本问题 换了一个4.72就没问题了。
GMT+8, 2024-11-23 12:40 , Processed in 0.030899 second(s), 27 queries , Gzip On.
