查看: 1401|回复: 1
STM32F030的EXTI问题
发表于 2023-12-4 17:25:38 | 显示全部楼层 |阅读模式
用HAL库搞好了,但是标准库一直只能PA0的按键触发,PC13的按键无法触发,不知道哪里有问题,求助。
#include "main.h"
        SysTick_Init();                                                //初始化延时函数
        LED_GPIO_Config();                                        //LED 端口初始化
        EXTI_KEY_Config();                                         //初始化EXTI中断,按下按键会触发中断
//等待中断,由于使用中断方式,CPU不用轮询按键
//配置嵌套向量中断控制器NVIC
static void NVIC_Configuration(void)
        NVIC_InitStructure.NVIC_IRQChannel = KEY1_INT_EXTI_IRQ;        //配置中断源:按键1
        NVIC_InitStructure.NVIC_IRQChannelPriority = 2;                        //配置优先级
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //使能中断通道
        NVIC_InitStructure.NVIC_IRQChannel = KEY2_INT_EXTI_IRQ;        //配置中断源:按键2,其他使用上面相关配置
        NVIC_InitStructure.NVIC_IRQChannelPriority = 1;                        //配置优先级
//配置 IO为EXTI中断口,并设置中断优先级
void EXTI_KEY_Config(void)
        EXTI_InitTypeDef EXTI_InitStructure;
        RCC_AHBPeriphClockCmd(KEY1_INT_GPIO_CLK,ENABLE);//开启按键端口的时钟
        RCC_AHBPeriphClockCmd(RCC_APB2Periph_SYSCFG,ENABLE);//开启按键端口的时钟
        NVIC_Configuration();                                                        //配置 NVIC 中断
/*--------------------------KEY1配置-----------------------------*/
        GPIO_InitStructure.GPIO_Pin = KEY1_INT_GPIO_PIN;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
        GPIO_Init(KEY1_INT_GPIO_PORT,&GPIO_InitStructure);
        SYSCFG_EXTILineConfig(KEY1_INT_EXTI_PORTSOURCE,KEY1_INT_EXTI_PINSOURCE);
        EXTI_InitStructure.EXTI_Line = KEY1_INT_EXTI_LINE;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;                                //EXTI为中断模式
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;                        //上升沿中断
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;                                                //使能中断
        EXTI_Init(&EXTI_InitStructure);
        EXTI_ClearITPendingBit(KEY1_INT_EXTI_LINE);               //清除中断标志位
/*--------------------------KEY2配置-----------------------------*/
        RCC_AHBPeriphClockCmd(KEY2_INT_GPIO_CLK,ENABLE);//开启按键端口的时钟
        GPIO_InitStructure.GPIO_Pin = KEY2_INT_GPIO_PIN;
        GPIO_Init(KEY2_INT_GPIO_PORT,&GPIO_InitStructure);
        SYSCFG_EXTILineConfig(KEY2_INT_EXTI_PORTSOURCE,KEY2_INT_EXTI_PINSOURCE);
        EXTI_InitStructure.EXTI_Line = KEY2_INT_EXTI_LINE;
        EXTI_ClearITPendingBit(KEY2_INT_EXTI_LINE);               //清除中断标志位
#include "stm32f0xx.h"
#include "Delay.h"
//引脚定义
#define KEY1_INT_GPIO_PORT         GPIOA
#define KEY1_INT_GPIO_CLK          RCC_AHBPeriph_GPIOA
#define KEY1_INT_GPIO_PIN          GPIO_Pin_0
#define KEY1_INT_EXTI_PORTSOURCE   EXTI_PortSourceGPIOA
#define KEY1_INT_EXTI_PINSOURCE    EXTI_PinSource0
#define KEY1_INT_EXTI_LINE         EXTI_Line0
#define KEY1_INT_EXTI_IRQ          EXTI0_1_IRQn
#define KEY1_IRQHandler            EXTI0_1_IRQHandler
#define KEY2_INT_GPIO_PORT         GPIOC
#define KEY2_INT_GPIO_CLK          RCC_AHBPeriph_GPIOC
#define KEY2_INT_GPIO_PIN          GPIO_Pin_13
#define KEY2_INT_EXTI_PORTSOURCE   EXTI_PortSourceGPIOC
#define KEY2_INT_EXTI_PINSOURCE    EXTI_PinSource13
#define KEY2_INT_EXTI_LINE         EXTI_Line13
#define KEY2_INT_EXTI_IRQ          EXTI4_15_IRQn
#define KEY2_IRQHandler            EXTI4_15_IRQHandler
void EXTI_KEY_Config(void);
void KEY1_IRQHandler(void)
        if(EXTI_GetITStatus(KEY1_INT_EXTI_LINE) != RESET)           //确保是否产生了EXTI Line中断
                LED1_TOGGLE;        //LED1 取反
//                LED2_TOGGLE;        //LED2 取反
//                EXTI_ClearFlag(KEY1_INT_EXTI_LINE);               //清除中断标志位
//                EXTI_ClearITPendingBit(KEY1_INT_EXTI_LINE);               //清除中断标志位
void KEY2_IRQHandler(void)
        if(EXTI_GetITStatus(KEY2_INT_EXTI_LINE) != RESET)           //确保是否产生了EXTI Line中断
                LED2_TOGGLE;
                LED3_TOGGLE;        //LED3 取反
//                EXTI_ClearFlag(KEY2_INT_EXTI_LINE);                //清除中断标志位
//                EXTI_ClearITPendingBit(KEY2_INT_EXTI_LINE);               //清除中断标志位
只触发KEY1,不触发KEY2
 楼主| 发表于 2023-12-5 09:10:10 | 显示全部楼层
终于找到问题了,RCC_AHBPeriphClockCmd(RCC_APB2Periph_SYSCFG,ENABLE);//开启按键端口的时钟
这个要改成RCC_APB2Cmd.我是说呢
GMT+8, 2025-4-12 23:34 , Processed in 0.227881 second(s), 23 queries , Gzip On.
