查看: 3614|回复: 5
[求助] IM6ULL 驱动部分
发表于 2024-2-25 21:02:17 | 显示全部楼层 |阅读模式
再执行  sudo ./make_deb.sh 时
为什么会 报这些错误呢
UPD     include/generated/compile.h
  CC      init/do_mounts.o
  CC      arch/arm/vdso/vgettimeofday.o
/tmp/ccEKCQ5E.s: Assembler messages:
/tmp/ccEKCQ5E.s:35: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:49: 错误: selected processor does not support `isb ' in ARM mode
/tmp/ccEKCQ5E.s:52: 错误: selected processor does not support `mrrc p15,1,r4,r5,c14' in ARM mode
/tmp/ccEKCQ5E.s:68: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:83: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:176: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:186: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:205: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:217: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:286: 错误: selected processor does not support `dmb ish' in ARM mode
/tmp/ccEKCQ5E.s:297: 错误: selected processor does not support `isb ' in ARM mode
/tmp/ccEKCQ5E.s:300: 错误: selected processor does not support `mrrc p15,1,r6,r7,c14' in ARM mode
/tmp/ccEKCQ5E.s:319: 错误: selected processor does not support `dmb ish' in ARM mode
make[2]: *** [/home/lighting/Linux_Driver/ebf-buster-linux/scripts/Makefile.build:304:arch/arm/vdso/vgettimeofday.o] 错误 1
make[1]: *** [/home/lighting/Linux_Driver/ebf-buster-linux/Makefile:1046:arch/arm/vdso] 错误 2
make[1]: *** 正在等待未完成的任务....
/tmp/cc2eK4sL.s: Assembler messages:
/tmp/cc2eK4sL.s:311: 错误: selected processor does not support `isb ' in ARM mode
/tmp/cc2eK4sL.s:595: 错误: selected processor does not support `isb ' in ARM mode
make[2]: *** [/home/lighting/Linux_Driver/ebf-buster-linux/scripts/Makefile.build:304:arch/arm/vfp/vfpmodule.o] 错误 1
make[1]: *** [/home/lighting/Linux_Driver/ebf-buster-linux/Makefile:1046:arch/arm/vfp] 错误 2
这是我的编译器版本
ecking=release --disable-bootstrap --enable-languages=c,c++,fortran,lto --build=x86_64-unknown-linux-gnu --host=x86_64-unknown-linux-gnu --target=arm-linux-gnueabihf --prefix=/home/tcwg-buildslave/workspace/tcwg-make-release_1/_build/builds/destdir/x86_64-unknown-linux-gnu
线程模型:posix
gcc 版本 7.5.0 (Linaro GCC 7.5-2019.12)
大佬们为什么我执行内个 sudo./make_deb.sh会报这么多错误呢
发表于 2024-2-26 10:27:40 | 显示全部楼层
这个是我们网盘虚拟机的GCC版本,好像最高支持到ubuntu18的7.5.0。你那个ubuntu是什么版本的?是不是都是7.5但是ubuntu版本不一样导致出现这个问题了?
 楼主| 发表于 2024-2-26 17:05:16 | 显示全部楼层
我的ubuntu版本可能有点高了(22.04 z之前一直用的) 我试试降低gcc版本吧  谢谢
 楼主| 发表于 2024-2-26 17:35:24 | 显示全部楼层
好的我降了gcc到7.5.0也不行 我再试试咱链接里的ubuntu18吧
 楼主| 发表于 2024-2-26 19:01:03 | 显示全部楼层
我换了ubuntu18 就行了 好的感谢
发表于 2024-3-2 11:14:57 | 显示全部楼层
版本不一致总会出现问题,所以还不能轻易更新版本。
GMT+8, 2025-4-7 02:56 , Processed in 0.179126 second(s), 26 queries , Gzip On.
