查看: 3952|回复: 3
[求助] buildroot下载hash校验不通过
发表于 2024-4-14 00:43:48 | 显示全部楼层 |阅读模式
  1. ERROR: imx-alsa-plugins-rel_imx_4.9.x_1.0.0_ga.tar.gz has wrong sha256 hash:
  2. ERROR: expected: e76a71e9166fbedeaa535fd7ebc07edc30a1e87f529ab2aa733e3603d3183ed0
  3. ERROR: got     : 089bba009f82bf5e4a1e34b77a7d3badce2948619d92bec7a7ad42e766442d4c
  4. ERROR: Incomplete download, or man-in-the-middle (MITM) attack
  5. dl-wrapper: Re-downloading 'imx-alsa-plugins-rel_imx_4.9.x_1.0.0_ga.tar.gz'...
  6. --2024-04-13 09:37:28--  https://mirrors.163.com/kernel//imx-alsa-plugins/imx-alsa-p        lugins-rel_imx_4.9.x_1.0.0_ga.tar.gz
  7. Resolving mirrors.163.com (mirrors.163.com)... 101.71.33.11
  8. Connecting to mirrors.163.com (mirrors.163.com)|101.71.33.11|:443... connected.
  9. HTTP request sent, awaiting response... 404 Not Found
  10. 2024-04-13 09:37:28 ERROR 404: Not Found.
  11. --2024-04-13 09:37:28--  https://mirrors.163.com/kernel//imx-alsa-plugins-rel_imx_4.        9.x_1.0.0_ga.tar.gz
  12. Resolving mirrors.163.com (mirrors.163.com)... 101.71.33.11
  13. Connecting to mirrors.163.com (mirrors.163.com)|101.71.33.11|:443... connected.
  14. HTTP request sent, awaiting response... 404 Not Found
  15. 2024-04-13 09:37:29 ERROR 404: Not Found.
  16. package/pkg-generic.mk:143: recipe for target '/home/zzlyang/code/ebf_6ull_buildroot        /output/build/imx-alsa-plugins-rel_imx_4.9.x_1.0.0_ga/.stamp_downloaded' failed
  17. make[1]: *** [/home/zzlyang/code/ebf_6ull_buildroot/output/build/imx-alsa-plugins-re        l_imx_4.9.x_1.0.0_ga/.stamp_downloaded] Error 1
  18. Makefile:84: recipe for target '_all' failed
  19. make: *** [_all] Error 2
下载了兰州大学的开源镜像网站的文件以及更换为网易的下载源都无法通过文件的校验。有没有解决过的大神解答一下?
报错图片
报错图片
发表于 2024-4-14 19:42:41 | 显示全部楼层
有个配置文件的,把校验值改为你下载的这个包。如果没下载下来就手动下载,然后执行生成校验的命令,再去替换那个文件里面的值就行
 楼主| 发表于 2024-4-15 10:44:13 | 显示全部楼层
おおおじ。 发表于 2024-4-14 19:42
有个配置文件的,把校验值改为你下载的这个包。如果没下载下来就手动下载,然后执行生成校验的命令,再去替 ...
有没有可以参考的文档地址?
发表于 2024-6-22 11:28:45 | 显示全部楼层
先下载包到dl目录中,
ubuntu中使用命令:  sha256sum + <文件>   计算<文件>的哈希值,例如
sha256sum opencv4-4.5.5.tar.gz
更新hash码到opencv4.hash 文件中
GMT+8, 2025-4-4 14:10 , Processed in 0.205694 second(s), 28 queries , Gzip On.
