查看: 3169|回复: 1
[求助] 设置串口自动登录失败
发表于 2024-4-26 15:08:23 | 显示全部楼层 |阅读模式
按照教程中改了配置文件,但是重启后还是需要输入密码
debian@npi:/lib/systemd/system$ cat ./serial-getty\@.service
#  SPDX-License-Identifier: LGPL-2.1+
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
[Unit]
Description=Serial Getty on %I
Documentation=man:agetty(8) man:systemd-getty-generator(8)
Documentation=http://0pointer.de/blog/projects/serial-console.html
BindsTo=dev-%i.device
After=dev-%i.device systemd-user-sessions.service plymouth-quit-wait.service getty-pre.target
After=rc-local.service
# If additional gettys are spawned during boot then we should make
# sure that this is synchronized before getty.target, even though
# getty.target didn't actually pull it in.
Before=getty.target
IgnoreOnIsolate=yes
# IgnoreOnIsolate causes issues with sulogin, if someone isolates
# rescue.target or starts rescue.service from multi-user.target or
# graphical.target.
Conflicts=rescue.service
Before=rescue.service
[Service]
# The '-o' option value tells agetty to replace 'login' arguments with an
# option to preserve environment (-p), followed by '--' for safety, and then
# the entered username.
#ExecStart=-/sbin/agetty -o '-p -- \\u' --keep-baud 115200,38400,9600 %I $TERM
ExecStart=-/sbin/agetty  --autologin debian --keep-baud 115200,38400,9600 --noclear %I vt220
Type=idle
Restart=always
UtmpIdentifier=%I
TTYPath=/dev/%I
TTYReset=yes
TTYVHangup=yes
KillMode=process
IgnoreSIGPIPE=no
SendSIGHUP=yes
[Install]
WantedBy=getty.target
发表于 2024-4-27 16:29:43 | 显示全部楼层
看着没啥问题,或者试试root能不能自动
GMT+8, 2025-4-4 19:03 , Processed in 0.127263 second(s), 25 queries , Gzip On.
