查看: 1831|回复: 2
[求助] 鲁班猫a1安装水星usb无线网卡UX3驱动出现问题
发表于 2024-5-21 22:30:38 | 显示全部楼层 |阅读模式
鲁班猫a1无法安装水星usb无线网卡UX3驱动:
sudo dpkg -i aic8800fdrvpackage_arm64.deb
Selecting previously unselected package aic8800fdrvpackage.
(Reading database ... 54131 files and directories currently installed.)
Preparing to unpack aic8800fdrvpackage_arm64.deb ...
Install aic8800 wifi driver!!!!!
Unpacking aic8800fdrvpackage (1.0.3) ...
Setting up aic8800fdrvpackage (1.0.3) ...
udev done
device exist
/var/lib/dpkg/info/aic8800fdrvpackage.postinst: line 10: eject: command not found
cp fw done
make -C /lib/modules/5.4.125/build M=/AIC8800/drivers/aic8800 ARCH=arm64 CROSS_COMPILE= modules
make[1]: Entering directory '/usr/src/linux-headers-5.4.125'
  CC [M]  /AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.o
/AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c: In function ‘rwnx_send_add_if’:
/AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:616:31: warning: this statement may fall through [-Wimplicit-fallthrough=]
  616 |         add_if_req_param->p2p = true;
/AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:619:5: note: here
  619 |     case NL80211_IFTYPE_STATION:
/AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:629:31: warning: this statement may fall through [-Wimplicit-fallthrough=]
  629 |         add_if_req_param->p2p = true;
/AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:632:5: note: here
  632 |     case NL80211_IFTYPE_AP:
/bin/sh: 1: scripts/basic/fixdep: Exec format error
make[3]: *** [scripts/Makefile.build:283: /AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.o] Error 126
make[3]: *** Deleting file '/AIC8800/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.o'
make[2]: *** [scripts/Makefile.build:550: /AIC8800/drivers/aic8800/aic8800_fdrv] Error 2
make[1]: *** [Makefile:1805: /AIC8800/drivers/aic8800] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.4.125'
make: *** [Makefile:55: modules] Error 2
make failed, install aic8800 wifi drvier failed
dpkg: error processing package aic8800fdrvpackage (--install):
installed aic8800fdrvpackage package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
aic8800fdrvpackage
求助大佬这个怎么解决
发表于 2024-5-22 11:57:31 | 显示全部楼层
需要编译驱动源码,用内核源码编
发表于 2024-7-1 06:43:00 | 显示全部楼层
不知道你解决了没有 一种解决方法留给后来人
1、主要问题:/bin/sh: 1: scripts/basic/fixdep: Exec format error
2、原因:这个fixdep是x86格式的  可以用file fixdep看一下
3、解决方法: 在包含scripts的目录下执行make scripts重新生成arm64格式的fixdep即可
*另外,从报错来看,你还要apt-get install eject一下
这种USB Wifi默认是识别成一个USB大容量存储设备 安装驱动时的eject操作可以触发USB Wifi重新枚举成另外一个设备(不同的PID和VID)才能正常加载安装的驱动。
GMT+8, 2025-4-13 03:35 , Processed in 0.166059 second(s), 26 queries , Gzip On.
