查看: 1758|回复: 3
【求助】GD32模拟I2C问题
发表于 2024-5-27 12:38:34 | 显示全部楼层 |阅读模式
  • 时序及其示波器显示波形如下所示,黄色为SDA。前面发送的数据没有任何问题,但是当接收数据的时候出现了如下所示问题。试过很多方法无果前来请教各位大佬!
  • GPIO设置如图所示,SCK和SDA均为推挽输出。
  • image.png -
  • 代码如下
    void i2c_start(void)
        BK1080_SDA_DIR_OUT;
        BK1080_SDA_HIGH;
        bk1080_delay(1);
        BK1080_SCK_HIGH;
        bk1080_delay(1);
        BK1080_SDA_LOW;
        bk1080_delay(1);
        BK1080_SCK_LOW;
        bk1080_delay(1);
    static void i2c_stop(void)
        BK1080_SDA_DIR_OUT;
        BK1080_SDA_LOW;
        bk1080_delay(1);
        BK1080_SCK_LOW;
        bk1080_delay(1);
        BK1080_SCK_HIGH;
        bk1080_delay(1);
        BK1080_SDA_HIGH;
        bk1080_delay(1);
    static void i2c_send(uint8_t data)
        BK1080_SDA_DIR_OUT;
        BK1080_SCK_LOW;
        bk1080_delay(2);
        for (uint8_t i = 0; i < 8; i++)
            if (data & 0x80)
                BK1080_SDA_HIGH;
                BK1080_SDA_LOW;
            bk1080_delay(1);
            BK1080_SCK_HIGH;
            bk1080_delay(1);
            BK1080_SCK_LOW;
            bk1080_delay(2);
            data <<= 1;
    static uint8_t i2c_read(void)
        uint8_t data = 0;
        BK1080_SDA_DIR_IN;
        BK1080_SCK_LOW;
        bk1080_delay(2);
            data <<= 1;
            BK1080_SCK_HIGH;
            bk1080_delay(1);
            data |= BK1080_SDA_READ;
            bk1080_delay(1);
            BK1080_SCK_LOW;
            bk1080_delay(2);
        return data;
    static void i2c_send_ack(iic_ack_t ack)
        BK1080_SDA_DIR_OUT;
        BK1080_SCK_LOW;
        bk1080_delay(1);
        if (ack)
            BK1080_SDA_HIGH;
            BK1080_SDA_LOW;
        bk1080_delay(1);
        BK1080_SCK_HIGH;
        bk1080_delay(1);
        BK1080_SCK_LOW;
        bk1080_delay(2);
    static uint8_t i2c_get_ack(void)
        uint8_t ack;
        BK1080_SDA_DIR_IN;
        BK1080_SCK_LOW;
        bk1080_delay(5);
        BK1080_SCK_HIGH;
        bk1080_delay(1);
        ack = BK1080_SDA_READ;
        bk1080_delay(1);
        BK1080_SCK_LOW;
        bk1080_delay(2);
        return ack;
 楼主| 发表于 2024-5-27 12:38:59 | 显示全部楼层
MCU为GD32F330CBT6
Device ID 为0x80
发表于 2024-5-28 09:03:30 | 显示全部楼层
因为主机是IO口模拟IIC,所以发送没问题.但是可能从机不是IO模拟的IIC,从机发送IIC时因为没有上拉电阻所以驱动能力不够?
发表于 2024-5-28 09:06:08 | 显示全部楼层
另外看起来你这个波形很奇怪请检查1.主从机是否共地2.主从机电压是否一直.可以考虑SCL与SDA线上分别串联一个10-100欧姆电阻来增加通讯稳定性.
GMT+8, 2025-4-10 02:48 , Processed in 0.192881 second(s), 29 queries , Gzip On.
