查看: 2037|回复: 6
STM32f103C8T6的2通道DMA+ADC,数据不正常
发表于 2024-6-21 16:00:23 | 显示全部楼层 |阅读模式
10火花
STM32f103C8T6的2通道DMA+ADC,数据不正常,求指点
 楼主| 发表于 2024-6-21 16:01:02 | 显示全部楼层
#define ADC1_DR_Address    ((u32)0x4001244C)
__IO u16 ADC_ConvertedValue[2]={0,0};
void ADC1_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
        RCC_ADCCLKConfig(RCC_PCLK2_Div8);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 ;
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5);
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
        ADC_InitStructure.ADC_ScanConvMode = ENABLE;
        ADC_InitStructure.ADC_NbrOfChannel = 2;
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_ConvertedValue;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 2;
        DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        DMA_Cmd(DMA1_Channel1, ENABLE);
        ADC_DMACmd(ADC1, ENABLE);
        ADC_Cmd(ADC1, ENABLE);
        ADC_ResetCalibration(ADC1);
        while (ADC_GetResetCalibrationStatus(ADC1) == SET);
        ADC_StartCalibration(ADC1);
        while (ADC_GetCalibrationStatus(ADC1) == SET);
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
 楼主| 发表于 2024-6-21 16:03:11 | 显示全部楼层
请大家帮忙看看,这个设置是有啥问题,搞了1天了,数据还不正常
 楼主| 发表于 2024-6-27 11:17:10 | 显示全部楼层
没人回复,自己顶一下
发表于 2024-6-28 09:07:01 | 显示全部楼层
1.建议分开调试,先确认ADC采集数据正确吗?可以在采集数据后将数据通过串口打印出来,看看不加入DMA模块的情况下数据是否正常.如果是要求连续采集的情况,可以将数据放入一个数组,采集一定量后一起打印.
2.如果采集数据没问题,第二步就是重新打开DMA模块,看看是否是DMA模块在移动数据后,数据出现变化?
确定问题后再去仔细检查对应模块配置.
 楼主| 发表于 2024-7-5 11:52:13 | 显示全部楼层
Nalimca 发表于 2024-6-28 09:07
1.建议分开调试,先确认ADC采集数据正确吗?可以在采集数据后将数据通过串口打印出来,看看不加入DMA模块的情 ...
单通道没有问题,双通道有问题
发表于 2024-7-8 08:51:50 | 显示全部楼层
lumilu 发表于 2024-7-5 11:52
单通道没有问题,双通道有问题
是通道切换后出现问题吗,一般通道切换后,需要采集一些数据后才能稳定,可以考虑通道切换后前面几个数据丢弃
GMT+8, 2025-4-6 06:45 , Processed in 0.183459 second(s), 23 queries , Gzip On.
