查看: 22918|回复: 9
请教一个EXTI 按键的问题
发表于 2014-4-23 22:53:28 | 显示全部楼层 |阅读模式
试过key1之后我试着把两个按键的程序合并起来,key1控制led1,key2控制led2,但是只有led1和key1有用,led2常亮,以下是部分代码,还请高手赐教。
exti.c部分:
#include "exti.h"
void NVIC_chushihua_PA0(void)
    //dingyi  jiegouti
    NVIC_InitTypeDef NVIC_PA0;
          //peizhi youxianji
    //shezhi jiegouti chengyuan
    NVIC_PA0.NVIC_IRQChannel=EXTI0_IRQn;
    NVIC_PA0.NVIC_IRQChannelCmd=ENABLE;
    NVIC_PA0.NVIC_IRQChannelPreemptionPriority=0;
    NVIC_PA0.NVIC_IRQChannelSubPriority=0;
    NVIC_Init(&NVIC_PA0);
void EXTI_chushihua_PA0(void)
   EXTI_InitTypeDef EXTI_PA0;
         GPIO_InitTypeDef GPIO_PA0;
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOA,ENABLE);
        /////IMPORTANT STEP!!!
        NVIC_chushihua_PA0();
         GPIO_PA0.GPIO_Mode=GPIO_Mode_IPU;//SHANG LA MODE
         GPIO_PA0.GPIO_Pin=GPIO_Pin_0;
         GPIO_Init(GPIOA,&GPIO_PA0);
         EXTI_PA0.EXTI_Line=EXTI_Line0;
         EXTI_PA0.EXTI_LineCmd=ENABLE;
         EXTI_PA0.EXTI_Mode=EXTI_Mode_Interrupt;
         EXTI_PA0.EXTI_Trigger=EXTI_Trigger_Falling ;
         EXTI_Init(&EXTI_PA0);
void NVIC_chushihua_PC13(void)
    //dingyi  jiegouti
    NVIC_InitTypeDef NVIC_PC13;
          //peizhi youxianji
    NVIC_PC13.NVIC_IRQChannel=EXTI15_10_IRQn;
    NVIC_PC13.NVIC_IRQChannelCmd=ENABLE;
    NVIC_PC13.NVIC_IRQChannelPreemptionPriority=0;
    NVIC_PC13.NVIC_IRQChannelSubPriority=0;
    NVIC_Init(&NVIC_PC13);
void EXTI_chushihua_PC13(void)
   EXTI_InitTypeDef EXTI_PC13;
         GPIO_InitTypeDef GPIO_PC13;
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOC,ENABLE);
        NVIC_chushihua_PC13();
         GPIO_PC13.GPIO_Mode=GPIO_Mode_IPU;//SHANG LA MODE
         GPIO_PC13.GPIO_Pin=GPIO_Pin_13;
         GPIO_Init(GPIOC,&GPIO_PC13);
         EXTI_PC13.EXTI_Line=EXTI_Line13;
         EXTI_PC13.EXTI_LineCmd=ENABLE;
         EXTI_PC13.EXTI_Mode=EXTI_Mode_Interrupt;
         EXTI_PC13.EXTI_Trigger=EXTI_Trigger_Falling ;
         EXTI_Init(&EXTI_PC13);
中断程序部分:
void EXTI0_IRQHandler(void)
   if (EXTI_GetFlagStatus(EXTI_Line0) == SET)
       GPIO_WriteBit(GPIOB,GPIO_Pin_0,(1-GPIO_ReadOutputDataBit(GPIOB,GPIO_Pin_0)));
                   EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI15_10_IRQHandler(void)
   if (EXTI_GetFlagStatus(EXTI_Line13) == SET)
       GPIO_WriteBit(GPIOF,GPIO_Pin_7,(1-GPIO_ReadOutputDataBit(GPIOF,GPIO_Pin_7)));
                   EXTI_ClearITPendingBit(EXTI_Line13);
初学者,先谢谢了!
发表于 2014-4-23 22:55:08 | 显示全部楼层
设断点,看看能不能进入中断呗
 楼主| 发表于 2014-4-23 23:28:33 | 显示全部楼层
栾端静 发表于 2014-4-23 22:55
设断点,看看能不能进入中断呗
额,请问设断点是怎么个设法呢?
发表于 2014-4-24 08:50:05 | 显示全部楼层
mxpp 发表于 2014-4-23 23:28
额,请问设断点是怎么个设法呢?
debug状态右上角有个红色大点
发表于 2014-4-24 09:48:15 | 显示全部楼层
调试一下看看能不能进入中断
 楼主| 发表于 2014-4-24 15:08:11 | 显示全部楼层
设断点,看看能不能进入中断呗
谢谢!问题解决了!
 楼主| 发表于 2014-4-24 15:08:31 | 显示全部楼层
刀_口 发表于 2014-4-24 08:50
debug状态右上角有个红色大点
谢谢!问题解决了!
 楼主| 发表于 2014-4-24 15:09:05 | 显示全部楼层
魏秋月 发表于 2014-4-24 09:48
调试一下看看能不能进入中断
谢谢!问题解决了!
发表于 2014-4-24 15:20:58 | 显示全部楼层
mxpp 发表于 2014-4-24 15:09
谢谢!问题解决了!
什么原因?
发表于 2014-4-24 16:15:26 | 显示全部楼层
LZ最好把怎么解决问题说一下,不然对其它问题少年不好.
GMT+8, 2024-11-24 03:57 , Processed in 0.031594 second(s), 23 queries , Gzip On.
