查看: 1303|回复: 2
[求助] 鲁班猫2上运行qt程序报错
发表于 2024-10-16 01:56:50 | 显示全部楼层 |阅读模式
lubancat2,上安装qt5(qt5.12.8库和qtcreator)后,编译一个简单的windows窗口demo,运行时命令行报错,报错内容为:
  1. libGL error: MESA-LOADER: failed to open rockchip: /usr/lib/dri/rockchip_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
  2. libGL error: failed to load driver: rockchip
  3. libGL error: MESA-LOADER: failed to open rockchip: /usr/lib/dri/rockchip_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
  4. libGL error: failed to load driver: rockchip
请求有经验的朋友,帮忙分析解决一下,谢谢!
 楼主| 发表于 2024-10-16 01:58:07 | 显示全部楼层
补充一下:
板子是lubancat2
系统是Ubuntu20.04
发表于 2024-10-16 10:38:39 | 显示全部楼层
猫的ubuntu20 没有做mesa 驱动的,系统用的是RK自带的闭源GPU驱动,理论上出现上述错误也不影响qt程序启动的。
如果要解决相关报错,可以参考3588 的解决方法:https://blog.csdn.net/wo_squirrel/article/details/134458252
GMT+8, 2025-4-6 23:54 , Processed in 0.144025 second(s), 26 queries , Gzip On.
