查看: 2681|回复: 1
[求助] buildroot 编译根文件系统
发表于 2024-10-22 10:25:10 | 显示全部楼层 |阅读模式
按照野火https://doc.embedfire.com/lubanc ... root/buildroot.html
这个教程完全一致去配置的 结果编译总是这个报错,实际并未选中qt5 有没有遇到类似问题的朋友指点一下:
实际报错如下
make[1]: Leaving directory '/home/book/linux/tool/buildroot-2021.02.3/output/build/host-cmake-3.15.5/Bootstrap.cmk'
loading initial cache file /home/book/linux/tool/buildroot-2021.02.3/output/build/host-cmake-3.15.5/Bootstrap.cmk/InitialCacheFlags.cmake
qmake: could not exec '/usr/lib/qt5/bin/qmake': No such file or directory
CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5Core/Qt5CoreConfig.cmake:27 (message):
  The imported target "Qt5::Core" references the file
     "/usr/lib/qt5/bin/qmake"
  but this file does not exist.  Possible reasons include:
  * The file was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and contained
     "/usr/lib/x86_64-linux-gnu/cmake/Qt5Core/Qt5CoreConfigExtras.cmake"
  but not all the files it references.
Call Stack (most recent call first):
  /usr/lib/x86_64-linux-gnu/cmake/Qt5Core/Qt5CoreConfigExtras.cmake:6 (_qt5_Core_check_file_exists)
  /usr/lib/x86_64-linux-gnu/cmake/Qt5Core/Qt5CoreConfig.cmake:184 (include)
  Tests/RunCMake/CMakeLists.txt:337 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/book/linux/tool/buildroot-2021.02.3/output/build/host-cmake-3.15.5/CMakeFiles/CMakeOutput.log".
See also "/home/book/linux/tool/buildroot-2021.02.3/output/build/host-cmake-3.15.5/CMakeFiles/CMakeError.log".
Error when bootstrapping CMake:
Problem while running initial CMake
package/pkg-generic.mk:231: recipe for target '/home/book/linux/tool/buildroot-2021.02.3/output/build/host-cmake-3.15.5/.stamp_configured' failed
make: *** [/home/book/linux/tool/buildroot-2021.02.3/output/build/host-cmake-3.15.5/.stamp_configured] Error 11
发表于 2024-11-15 13:57:34 | 显示全部楼层
是不是没有选配Qt5,但是需要QT5中的qmake工具来参与编译其他的工具包,也就是其他的工具包依赖qt5
GMT+8, 2025-12-14 22:46 , Processed in 0.079938 second(s), 24 queries , Gzip On.
