查看: 1601|回复: 10
[求助] EBF6UL/ULL刷机重启后报错
发表于 2024-10-23 00:08:34 | 显示全部楼层 |阅读模式
之前第一次运行是成功的,后面烧录好几次SD卡(256G,不知道和内存量有没有关系)也都是前几次可以登入Debian系统,然后配置fire-config重启后,报同样的错误信息。
日志部分(标粗的是和正常启动不同的)
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.35-imx6 (root@cicd-ubuntu.embedfire.local) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #1.2307stable SMP PREEMPT Thu Jul 27 09:15:44 UTC 2023
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: div instructions available: patching division code
[    3.974803]   No soundcards found.
[    3.980557] Freeing unused kernel memory: 1024K
[    3.985449] Run /init as init process
Loading, please wait...
Starting version 241
[    5.483452] cfg80211: failed to load regulatory.db
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
Warning: fsck not present, so skipping root file system
[    7.911546] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Block bitmap for group 4160 not in group (block 0)!
[    7.921986] EXT4-fs (mmcblk0p2): group descriptors corrupted!
mount: mounting /dev/mmcblk0p2 on /root failed: Structure needs cleaning
Failed to mount /dev/mmcblk0p2 as root file system.
以下是标粗部分正常显示
[    5.514459] cfg80211: failed to load regulatory.db
[    7.125646] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[    8.009273] systemd[1]: System time before build time, advancing clock.
[    8.058176] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    8.081113] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 10 (buster)!
发表于 2024-10-23 11:27:57 | 显示全部楼层
回帖奖励 +2 火花
我感觉有可能sd卡太大了,有没有小一点的试一下?
 楼主| 发表于 2024-10-23 20:59:11 | 显示全部楼层
还有个问题就是系统提示我填写用户名和密码的时候,突然蹦出来一堆信息,接着就是不断地
default username:password is [debian:temppwd]
npi login: debian
[  OK  ] Started solve_qt_deb.service.
         Starting Terminate Psplash Act Screen...
Password:          Starting Generic Board Startup...
         Stopping OpenBSD Secure Shell server...
[  OK  ] Stopped OpenBSD Secure Shell server.
[  OK  ] Started Terminate Psplash Act Screen.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped Daily rotation of log files.
[  OK  ] Stopped target Sound Card.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Stopped target System Time Synchronized.
[  OK  ] Stoppe▒         Stopping Serial Getty on ttymxc0...
         Stopping System Logging Service...
         Stopping rng-tools.service...
         Stopping Login Service...
         Stopping Regular background program processing daemon...
         Stopping LSB: Start busybox udhcpd at boot time...
[  OK  ] Stopped Regular background program processing daemon.
[  OK  ] Stopped System Logging Service.
[  OK  ] Stopped Login Service.
[  OK  ] Stopped Serial Getty on ttymxc0.
[  OK  ] Stopped Generic Board Startup.
[  OK  ] Stopped rng-tools.service.
         Stopping Permit User Sessions...
[  OK  ] Removed slice system-serial\x2dgetty.slice.
[  OK  ] Stopped LSB: Start busybox udhcpd at boot time.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Network.
         Stopping WPA supplicant...
         Stopping Connection service...
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped WPA supplicant.
[  OK  ] Stopped Connection service.
         Stopping D-Bus System Message Bus...
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed Syslog Socket.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Paths.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
[  OK  ] Stopped target Local Encrypted Volumes.
[  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
[  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
         Stopping Load/Save Screen …ness of backlight:backlight...
         Stopping Update UTMP about System Boot/Shutdown...
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
         Stopping Load/Save Random Seed...
         Stopping Network Time Synchronization...
[  OK  ] Stopped Load/Save Screen B…htness of backlight:backlight.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped Update UTMP about System Boot/Shutdown.
[  OK  ] Removed slice system-systemd\x2dbacklight.slice.
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting /mnt/.psplash...
         Unmounting /boot...
[FAILED] Failed unmounting /mnt/.psplash.
[  OK  ] Stopped target Swap.
[  OK  ] Unmounted /boot.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Stopped Create System Users.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Reached target Shutdown.
[  OK  ] Reached target Final Step.
[  OK  ] Started Reboot.
[  OK  ] Reached target Reboot.
[   92.694900] watchdog: watchdog0: watchdog did not stop!
[  105.530555] systemd-journald[200]: Failed to send WATCHDOG=1 notification message: Connection refused
[  105.820244] imx2-wdt 20bc000.wdog: Device shutdown: Expect reboot!
[  105.826575] reboot: Restarting system
发表于 2024-10-24 08:56:03 | 显示全部楼层
你这个是不是第一次启动?第一次启动会有个初始化的过程的
 楼主| 发表于 2024-10-24 12:51:07 来自手机 | 显示全部楼层
可是我等了快10分钟,第一次启动确实能跑通,但是sudo fire-config后重启就会出现一楼的问题
发表于 2024-10-24 15:09:04 | 显示全部楼层
什么日期的镜像,我可以去看看
发表于 2024-10-24 15:09:42 | 显示全部楼层
还有你的fire-config 改了什么东西导致启动不了了
 楼主| 发表于 2024-10-27 19:37:55 | 显示全部楼层
YiangYiang 发表于 2024-10-24 15:09
什么日期的镜像,我可以去看看
ebf_debian_2020_05_20,ebf_debian_2023_08_03这两个视频版本,还有其他的也试了
 楼主| 发表于 2024-10-27 19:38:38 | 显示全部楼层
就是按照视频操作,enable了flasher
 楼主| 发表于 2024-10-27 19:43:10 | 显示全部楼层
什么日期的镜像,我可以去看看
imx6ull-debian-buster-console-armhf-2020-05-19-2gb.img
 楼主| 发表于 2024-10-30 13:33:32 | 显示全部楼层
买了新的SD卡,32G的,终于跑通了
GMT+8, 2025-4-4 21:02 , Processed in 0.125081 second(s), 28 queries , Gzip On.
