查看: 1257|回复: 1
霸天虎STM32F407 99-FreeRTOS+emXGUI屏幕不亮
发表于 2024-11-5 11:44:23 | 显示全部楼层 |阅读模式
[2024-11-05 11:35:09.591]
Power On Reset occurred....[2024-11-05 11:35:09.591]
[2024-11-05 11:35:09.596]
No need to configure RTC....[2024-11-05 11:35:09.596]
野火emXGUI演示例程
<<-GTP-INFO->> Unknown IC Version: 911_2160
<<-GTP-DEBUG->> [611]RES
<<-GTP-DEBUG-ARRAY->>
80   51   1e   0f   55   37   03   05   00   01
<<-GTP-INFO->> X_MAX = 3870, Y_MAX = 14165, TRIGGER = 0x03
!!SD卡挂载文件系统失败。(3)[2024-11-05 11:35:11.057]
!!可能原因:没有接入SD卡。[2024-11-05 11:35:11.068]
<<-GUI-ERROR->> File_System Failed.
[2024-11-05 11:35:11.083]
Firmware name: Fire_FreeRTOS, hardware version: V1.0.0, software version: V0.1.0[2024-11-05 11:35:11.089]
Fault on thread Boot_Interface[2024-11-05 11:35:11.092]
Error: Thread stack(200043c8) was overflow[2024-11-05 11:35:11.095]
===== Thread stack information =====[2024-11-05 11:35:11.101]
====================================[2024-11-05 11:35:11.104]
Bus fault is caused by precise data access violation[2024-11-05 11:35:11.109]
The bus fault occurred address is 59a646d0[2024-11-05 11:35:11.113]
Dump call stack has an error[2024-11-05 11:35:11.116]
大佬们,帮忙看一下,谁遇到这种问题,电容触摸屏—触摸画板实验是正常的,但freertos_emXGUI_开机例程屏幕不亮,
srcdata已经刷过了,走过路过,帮忙解答一下,谢谢!
发表于 2024-11-13 16:15:16 | 显示全部楼层
刷的是不是rtos里面单独的资料的,不同的工程资料不一样的
GMT+8, 2025-4-6 17:31 , Processed in 0.163847 second(s), 25 queries , Gzip On.
