查看: 2015|回复: 5
[经验\资料] Secure boot option in lubancat aw-image-build for Allwinner H618
发表于 2025-1-3 21:07:22 | 显示全部楼层 |阅读模式
Hello There,
I am using aw-image-build SDK for Allwinner H618,
I want to enable and use secure-boot for Allwinner H618.
Allwinner H618 have support of secure boot , but i can not able to find any secure boot related option in aw-image-build SDK.
Request you to please provide support and steps to enable , compile and boot image with secure boot enabled using aw-image-build SDK for Allwinner H618.
发表于 2025-1-6 11:17:26 | 显示全部楼层
aw-image-build does not support secure boot related content. If you want to use secure boot, you need to use Allwinner's official Tina-SDK. However, Tina SDK is not open source.
 楼主| 发表于 2025-1-6 12:54:21 | 显示全部楼层
H781997429 published on 2025-1-6 11:17
aw-image-build does not support secure boot related content. If you want to use secure boot, you nee ...
Thank you for replay ,
I have tina SDK in hand so can you suggest us the steps or any changes to port or add SECURE boot option in aw-image-build SDK from tina-SDK ?
发表于 2025-1-6 14:35:31 | 显示全部楼层
I have tina SDK in hand so can you suggest us the steps or any changes to  ...
We have never developed based on Tina-SDK, so we cannot provide appropriate advice
 楼主| 发表于 2025-1-6 15:09:17 | 显示全部楼层
ok thank you ,
but is there any analysis or any steps you have discovered for secure boot ?
because we are using the aw-image-build SDK , in which we want to port Secure-boot.
so if you have any existing analysis for Secure-boot then it will be helpfull for us.
 楼主| 发表于 2025-1-8 12:58:09 | 显示全部楼层
Hello There ,
Actually we just want to compile the secure image , which is done on tina OS SDk.
So As i mentioned in my previous message , if there is any analysis or steps done to create Secure boot image in aw-image-build SDK , then please let us know.
We are creating a product based on Allwinner h618 and based on it's functionality we want secure boot.
GMT+8, 2025-12-14 11:25 , Processed in 0.118562 second(s), 26 queries , Gzip On.
