查看: 837|回复: 1
[求助] u-boot启动问题
发表于 2025-1-7 20:41:40 | 显示全部楼层 |阅读模式
官方的 mfgtools-release-20200111 固件,直接下载成功,启动发现缺少 ** Unable to read file /uEnv.txt ** 文件
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+g7bb6453 (Oct 11 2019 - 08:59:57 +0000)
CPU:   Freescale i.MX6ULL rev1.1 69 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 41C
Reset cause: POR
Board: MX6ULL 14x14 EVK
I2C:   ready
DRAM:  512 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc1(part 0) is current device
Net:   FEC1
Error: FEC1 address not set.
Normal Boot
Hit any key to stop autoboot:  0
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
  arguments (sizes in 512-byte blocks):
    [user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
    [gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
    [check|set|complete] - mode, complete set partitioning completed
  WARNING: Partitioning is a write-once setting once it is set to complete.
  Power cycling is required to initialize partitions after set to complete.
mmc bootbus dev boot_bus_width reset_boot_bus_width boot_mode
- Set the BOOT_BUS_WIDTH field of the specified device
mmc bootpart-resize <dev> <boot part size MB> <RPMB part size MB>
- Change sizes of boot and RPMB partitions of specified device
mmc partconf dev boot_ack boot_partition partition_access
- Change the bits of the PARTITION_CONFIG field of the specified device
mmc rst-function dev value
- Change the RST_n_FUNCTION field of the specified device
   WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.
mmc setdsr <value> - set DSR register value
loading [mmc 1:1] /uEnv.txt ...
reading /uEnv.txt
 楼主| 发表于 2025-1-8 22:22:44 | 显示全部楼层
问题已解决,不知道什么原因,bootcmd值丢失,重新设置一下就好了
GMT+8, 2025-4-15 22:41 , Processed in 0.156953 second(s), 24 queries , Gzip On.
