查看: 252|回复: 1
[求助] pro开发板sd卡刷机卡住
发表于 2025-3-25 23:25:00 | 显示全部楼层 |阅读模式
sd卡启动成功后,在fire-config中选择了wifi使能和刷机到emmc中,重新启动后卡住,log在下面,这个该怎么解决啊
Starting eMMC Flasher from microSD media
Version: [1.20180412: all ssh regneration override...]
Prepare environment for flashing
Starting at Thu Jan  1 08:34:42 CST 1970
==> Giving system time to stablize...
5 4 3  2 1
==> Preparing /tmp
==> Preparing sysctl
==> sysctl: vm.min_free_kbytes=[1622]
==> sysctl: setting: [sysctl -w vm.min_free_kbytes=16384]
vm.min_free_kbytes = 16384
==> Determining root drive
==> root_drive=[/dev/mmcblk1p2]
====> Root drive identified at [/dev/mmcblk1p2]
==> Boot Drive [/dev/mmcblk1p1]
==> Figuring out Source and Destination devices
====> Source identified: [/dev/mmcblk1]
====> Destination identified: [/dev/mmcblk0]
==> Figuring out machine
====> Machine is Embedfire_i.MX6ULL_Board
====> Machine is compatible with BeagleBone Black
====> The Boot and Root drives are identified to be different.
====> Giving system time to stablize...
5 4 3 2 1
====> Mounting /dev/mmcblk1p1 Read Only over /boot/uboot
[   23.104076] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
5 4 3 2 1
Checking for Valid bbb-eeprom header
Checking running system
==> Copying: [/dev/mmcblk1] -> [/dev/mmcblk0]
==> lsblk:
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk1      179:0    0  7.3G  0 disk
|-mmcblk1p1  179:1    0   40M  0 part /boot/uboot
`-mmcblk1p2  179:2    0  7.2G  0 part /
mmcblk1boot0 179:8    0    4M  1 disk
mmcblk1boot1 179:16   0    4M  1 disk
==> df -h | grep rootfs:
!==> Error: [/dev/mmcblk0] does not exist
writing to [/dev/mmcblk0] failed...
==> Stopping Cylon LEDs ...
Traceback (last called is first):
     reset_leds() in /opt/scripts/tools/eMMC/functions.sh:432
     write_failure() in /opt/scripts/tools/eMMC/functions.sh:450
     check_running_system() in /opt/scripts/tools/eMMC/functions.sh:613
     main() in /opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh:47
The command kill $CYLON_PID > /dev/null 2>&1 exited with exit code 2.
Tearing Down script environment
==> Unmounting /tmp
blockdev: cannot open /dev/mmcblk0: No such file or directory
[   28.639310] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[   28.639310]
[   28.648560] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[   28.648560]  ]---
[  121.498723] random: crng init done
 楼主| 发表于 2025-3-25 23:38:23 | 显示全部楼层
改用usb启动后,中间突然就失败,连续多次都是这样
GMT+8, 2025-4-3 09:39 , Processed in 0.140318 second(s), 28 queries , Gzip On.
