查看: 1821|回复: 1
[求助] RK3588板上推理遇到段错误,求大佬们帮忙看看有无解决思路
发表于 2025-4-2 16:45:13 | 显示全部楼层 |阅读模式
  项目中一个魔改的YOLO Classify模型,在PC端上可以正常将ONNX转换成RKNN模型并通过模拟器推理出正确结果,但是将该RKNN模型放到鲁班猫RK3588板子上,使用Rknntoolkit-lite2进行推理,出现"段错误"并终止。图1这是在PC虚拟机上转换模型并模拟器推理的输出,图2是RK3588板上的推理终端信息,我看二者的Feature Tensor Information Table和Const Tensor Information Table都是完全一致的,大佬们在部署模型时是否遇到过类似问题?以及能否提供些解决思路?相关代码模型以及数据都已经打包,如果需要的话直接解压就可以运行,谢谢!“”
通过网盘分享的文件:yolo.zip
链接: https://pan.baidu.com/s/1kEnZYqCwQFE0hFneIxGmhA?pwd=fe9h 提取码: fe9h
--来自百度网盘超级会员v6的分享
图2:RK3588板上报错
图2:RK3588板上报错
图1:PC虚拟机上模拟器运行结果
图1:PC虚拟机上模拟器运行结果
 楼主| 发表于 2025-4-2 16:46:57 | 显示全部楼层
完整报错信息:
cat@lubancat:~/gra/2025.4.2$ python3 yolo_inference_lite.py
W rknn-toolkit-lite2 version: 2.3.0
W Verbose file path is invalid, debug info will not dump to file.
D target set by user is: None
D Starting ntp or adb, target soc is RK3588, device id is: None
I RKNN: [09:32:38.385] RKNN Runtime Information, librknnrt version: 2.3.0 (c949ad889d@2024-11-07T11:35:33)
I RKNN: [09:32:38.385] RKNN Driver Information, version: 0.9.8
I RKNN: [09:32:38.386] RKNN Model Information, version: 6, toolkit version: 2.3.0(compiler version: 2.3.0 (c949ad889d@2024-11-07T11:39:30)), target: RKNPU v2, target platform: rk35                          88, framework name: ONNX, framework layout: NCHW, model inference type: static_shape
D RKNN: [09:32:38.386] allocated memory, name: task, virt addr: 0x7f865f4000, dma addr: 0xfffc0000, obj addr: 0xffffff8142a9a000, size: 260760, aligned size: 262144, fd: 4, handle:                           1, flags: 0x40b, gem name: 1, iommu domain id: 0
D RKNN: [09:32:38.467] allocated memory, name: weight, virt addr: 0x7f61a83000, dma addr: 0xf9d42000, obj addr: 0xffffff8142a9ec00, size: 103275136, aligned size: 103276544, fd: 5,                           handle: 2, flags: 0x403, gem name: 2, iommu domain id: 0
D RKNN: [09:32:38.504] subgraph0 regcmdbuffer size: 1457728, taskbuffer size: 260760
D RKNN: [09:32:38.513] allocated memory, name: internal, virt addr: 0x7f85372000, dma addr: 0xf937f000, obj addr: 0xffffff8142b54c00, size: 10235904, aligned size: 10235904, fd: 6,                           handle: 3, flags: 0x403, gem name: 3, iommu domain id: 0
D RKNN: [09:32:38.515] ---------------------------------------------------------------------------------------------------------------------------------
D RKNN: [09:32:38.515]                                            Feature Tensor Information Table
D RKNN: [09:32:38.515] -----------------------------------------------------------------------------------------------+---------------------------------
D RKNN: [09:32:38.515] ID  User           Tensor                DataType  DataFormat   OrigShape      NativeShape     |     [Start       End)       Size
D RKNN: [09:32:38.515] 2   Conv           in_T                  FLOAT16   NC1HWC2      (1,3,224,224)  (1,4,224,224,3) | 0xf93c8800 0xf9412000 0x00049800
D RKNN: [09:32:38.515] 3   MaxPool        1262                  FLOAT16   NC1HWC2      (1,64,112,112) (1,32,112,112,8) | 0xf9412000 0xf959a000 0x00188000
D RKNN: [09:32:38.515] 4   Conv           in                    FLOAT16   NC1HWC2      (1,3,224,224)  (1,4,224,224,3) | 0xf937f000 0xf93c8800 0x00049800
D RKNN: [09:32:38.515] 5   MaxPool        1364                  FLOAT16   NC1HWC2      (1,64,112,112) (1,32,112,112,8) | 0xf93c8800 0xf9550800 0x00188000
D RKNN: [09:32:38.515] 6   ConvRelu       718                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf959a000 0xf95fc000 0x00062000
D RKNN: [09:32:38.515] 7   ConvRelu       867                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf95fc000 0xf965e000 0x00062000
D RKNN: [09:32:38.515] 8   ConvExSwish    in                    FLOAT16   NC1HWC2      (1,3,224,224)  (1,4,224,224,3) | 0xf937f000 0xf93c8800 0x00049800
D RKNN: [09:32:38.515] 9   ConvExSwish    958                   FLOAT16   NC1HWC2      (1,64,112,112) (1,96,112,112,8) | 0xf965e000 0xf9af6000 0x00498000
D RKNN: [09:32:38.515] 10  ConvExSwish    962                   FLOAT16   NC1HWC2      (1,128,56,56)  (1,192,56,56,8) | 0xf9af6000*0xf9d42000 0x0024c000
D RKNN: [09:32:38.515] 11  ConvExSwish    962                   FLOAT16   NC1HWC2      (1,128,56,56)  (1,192,56,56,8) | 0xf9af6000*0xf9d42000 0x0024c000
D RKNN: [09:32:38.515] 12  ConvExSwish    966                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf965e000 0xf9784000 0x00126000
D RKNN: [09:32:38.515] 13  ConvExSwish    970                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf98aa000 0xf99d0000 0x00126000
D RKNN: [09:32:38.515] 14  Add            966                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf965e000 0xf9784000 0x00126000
D RKNN: [09:32:38.515] 14  Add            974                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf99d0000 0xf9af6000 0x00126000
D RKNN: [09:32:38.515] 15  ConvExSwish    975                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf948c800 0xf94ee800 0x00062000
D RKNN: [09:32:38.515] 16  ConvExSwish    979                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf965e000 0xf9784000 0x00126000
D RKNN: [09:32:38.515] 17  Add            975                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf948c800 0xf94ee800 0x00062000
D RKNN: [09:32:38.515] 17  Add            983                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf98aa000 0xf99d0000 0x00126000
D RKNN: [09:32:38.515] 18  ConvExSwish    984                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf94ee800 0xf9550800 0x00062000
D RKNN: [09:32:38.515] 19  ConvExSwish    988                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf965e000 0xf9784000 0x00126000
D RKNN: [09:32:38.515] 20  Add            984                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf94ee800 0xf9550800 0x00062000
D RKNN: [09:32:38.515] 20  Add            992                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf98aa000 0xf99d0000 0x00126000
D RKNN: [09:32:38.515] 21  Concat         993                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf948c800 0xf94ee800 0x00062000
D RKNN: [09:32:38.515] 21  Concat         997                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,96,56,56,8)  | 0xf9784000 0xf98aa000 0x00126000
D RKNN: [09:32:38.515] 22  ConvExSwish    998                   FLOAT16   NC1HWC2      (1,128,56,56)  (1,64,56,56,8)  | 0xf965e000 0xf9722000 0x000c4000
D RKNN: [09:32:38.515] 23  ConvExSwish    1002                  FLOAT16   NC1HWC2      (1,128,56,56)  (1,192,56,56,8) | 0xf9722000 0xf996e000 0x0024c000
D RKNN: [09:32:38.515] 24  ConvExSwish    1006                  FLOAT16   NC1HWC2      (1,256,28,28)  (1,384,28,28,8) | 0xf996e000 0xf9a94000 0x00126000
D RKNN: [09:32:38.515] 25  ConvExSwish    1006                  FLOAT16   NC1HWC2      (1,256,28,28)  (1,384,28,28,8) | 0xf996e000 0xf9a94000 0x00126000
D RKNN: [09:32:38.515] 26  ConvExSwish    1010                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf948c800 0xf951f800 0x00093000
D RKNN: [09:32:38.515] 27  ConvExSwish    1014                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf96f1000 0xf9784000 0x00093000
D RKNN: [09:32:38.515] 28  Add            1010                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf948c800 0xf951f800 0x00093000
D RKNN: [09:32:38.515] 28  Add            1018                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf9784000 0xf9817000 0x00093000
D RKNN: [09:32:38.515] 29  ConvExSwish    1019                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 30  ConvExSwish    1023                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf948c800 0xf951f800 0x00093000
D RKNN: [09:32:38.515] 31  Add            1019                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 31  Add            1027                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf96f1000 0xf9784000 0x00093000
D RKNN: [09:32:38.515] 32  ConvExSwish    1028                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf948c800 0xf94bd800 0x00031000
D RKNN: [09:32:38.515] 33  ConvExSwish    1032                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf94bd800 0xf9550800 0x00093000
D RKNN: [09:32:38.515] 34  Add            1028                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf948c800 0xf94bd800 0x00031000
D RKNN: [09:32:38.515] 34  Add            1036                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf96f1000 0xf9784000 0x00093000
D RKNN: [09:32:38.515] 35  ConvExSwish    1037                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 36  ConvExSwish    1041                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf948c800 0xf951f800 0x00093000
D RKNN: [09:32:38.515] 37  Add            1037                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 37  Add            1045                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf96f1000 0xf9784000 0x00093000
D RKNN: [09:32:38.515] 38  ConvExSwish    1046                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf948c800 0xf94bd800 0x00031000
D RKNN: [09:32:38.515] 39  ConvExSwish    1050                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf94bd800 0xf9550800 0x00093000
D RKNN: [09:32:38.515] 40  Add            1046                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf948c800 0xf94bd800 0x00031000
D RKNN: [09:32:38.515] 40  Add            1054                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf96f1000 0xf9784000 0x00093000
D RKNN: [09:32:38.515] 41  ConvExSwish    1055                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 42  ConvExSwish    1059                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf948c800 0xf951f800 0x00093000
D RKNN: [09:32:38.515] 43  Add            1055                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 43  Add            1063                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf96f1000 0xf9784000 0x00093000
D RKNN: [09:32:38.515] 44  Concat         1064                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf948c800 0xf94bd800 0x00031000
D RKNN: [09:32:38.515] 44  Concat         1068                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,192,28,28,8) | 0xf965e000 0xf96f1000 0x00093000
D RKNN: [09:32:38.515] 45  ConvExSwish    1069                  FLOAT16   NC1HWC2      (1,256,28,28)  (1,128,28,28,8) | 0xf94bd800 0xf951f800 0x00062000
D RKNN: [09:32:38.515] 46  ConvAddRelu    721                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf93c8800 0xf942a800 0x00062000
D RKNN: [09:32:38.515] 46  ConvAddRelu    718                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf959a000 0xf95fc000 0x00062000
D RKNN: [09:32:38.515] 47  ConvRelu       725                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf948c800 0xf94ee800 0x00062000
D RKNN: [09:32:38.515] 48  ConvAddRelu    870                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf942a800 0xf948c800 0x00062000
D RKNN: [09:32:38.515] 48  ConvAddRelu    867                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf95fc000 0xf965e000 0x00062000
D RKNN: [09:32:38.515] 49  ConvRelu       874                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf94ee800 0xf9550800 0x00062000
D RKNN: [09:32:38.515] 50  ConvAddRelu    728                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf937f000 0xf93e1000 0x00062000
D RKNN: [09:32:38.515] 50  ConvAddRelu    725                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf948c800 0xf94ee800 0x00062000
D RKNN: [09:32:38.515] 51  ConvRelu       732                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf9550800 0xf95b2800 0x00062000
D RKNN: [09:32:38.515] 52  Conv           735                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 53  ConvAddRelu    877                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf93e1000 0xf9443000 0x00062000
D RKNN: [09:32:38.515] 53  ConvAddRelu    874                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf94ee800 0xf9550800 0x00062000
D RKNN: [09:32:38.515] 54  ConvRelu       881                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf9443000 0xf94a5000 0x00062000
D RKNN: [09:32:38.515] 55  Conv           884                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 56  ConvAddRelu    732                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf9550800 0xf95b2800 0x00062000
D RKNN: [09:32:38.515] 56  ConvAddRelu    1280                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf93b0000 0xf93e1000 0x00031000
D RKNN: [09:32:38.515] 57  ConvRelu       741                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 58  ConvAddRelu    881                   FLOAT16   NC1HWC2      (1,64,56,56)   (1,32,56,56,8)  | 0xf9443000 0xf94a5000 0x00062000
D RKNN: [09:32:38.515] 58  ConvAddRelu    1382                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf93e1000 0xf9412000 0x00031000
D RKNN: [09:32:38.515] 59  ConvRelu       890                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf9412000 0xf9443000 0x00031000
D RKNN: [09:32:38.515] 60  ConvAddRelu    744                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf93b0000 0xf93e1000 0x00031000
D RKNN: [09:32:38.515] 60  ConvAddRelu    741                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 61  ConvRelu       748                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf9443000 0xf9474000 0x00031000
D RKNN: [09:32:38.515] 62  Conv           751                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 63  ConvAddRelu    893                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf93e1000 0xf9412000 0x00031000
D RKNN: [09:32:38.515] 63  ConvAddRelu    890                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf9412000 0xf9443000 0x00031000
D RKNN: [09:32:38.515] 64  ConvAddRelu    748                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf9443000 0xf9474000 0x00031000
D RKNN: [09:32:38.515] 64  ConvAddRelu    1295                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 65  ConvRelu       757                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 66  ConvAddRelu    760                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 66  ConvAddRelu    757                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 67  ConvRelu       764                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf93e1000 0xf93f9800 0x00018800
D RKNN: [09:32:38.515] 68  Conv           767                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf937f000 0xf938c000 0x0000d000
D RKNN: [09:32:38.515] 69  ConvAddRelu    764                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf93e1000 0xf93f9800 0x00018800
D RKNN: [09:32:38.515] 69  ConvAddRelu    1310                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf938c000 0xf9399000 0x0000d000
D RKNN: [09:32:38.515] 70  ConvRelu       773                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf937f000 0xf938c000 0x0000d000
D RKNN: [09:32:38.515] 71  ConvAddRelu    776                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf938c000 0xf9399000 0x0000d000
D RKNN: [09:32:38.515] 71  ConvAddRelu    773                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf937f000 0xf938c000 0x0000d000
D RKNN: [09:32:38.515] 72  ConvRelu       780                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf9399000 0xf93a6000 0x0000d000
D RKNN: [09:32:38.515] 73  ConvAddRelu    783                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf937f000 0xf938c000 0x0000d000
D RKNN: [09:32:38.515] 73  ConvAddRelu    780                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf9399000 0xf93a6000 0x0000d000
D RKNN: [09:32:38.515] 74  ConvRelu       787                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf938c000 0xf9399000 0x0000d000
D RKNN: [09:32:38.515] 75  ConvAddRelu    790                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf937f000 0xf938c000 0x0000d000
D RKNN: [09:32:38.515] 75  ConvAddRelu    787                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf938c000 0xf9399000 0x0000d000
D RKNN: [09:32:38.515] 76  ConvTranspose  794                   FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf9399000 0xf93a6000 0x0000d000
D RKNN: [09:32:38.515] 77  ConvRelu       813                   FLOAT16   NC1HWC2      (1,512,14,14)  (1,256,14,14,8) | 0xf93e1000 0xf9412000 0x00031000
D RKNN: [09:32:38.515] 78  Conv           816                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 79  ConvAddRelu    813                   FLOAT16   NC1HWC2      (1,512,14,14)  (1,256,14,14,8) | 0xf93e1000 0xf9412000 0x00031000
D RKNN: [09:32:38.515] 79  ConvAddRelu    1337                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 80  ConvRelu       822                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 81  ConvAddRelu    825                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 81  ConvAddRelu    822                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 82  ConvTranspose  829                   FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf93e1000 0xf93f9800 0x00018800
D RKNN: [09:32:38.515] 83  ConvRelu       848                   FLOAT16   NC1HWC2      (1,256,28,28)  (1,128,28,28,8) | 0xf93f9800 0xf945b800 0x00062000
D RKNN: [09:32:38.515] 84  Conv           851                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 85  ConvAddRelu    848                   FLOAT16   NC1HWC2      (1,256,28,28)  (1,128,28,28,8) | 0xf93f9800 0xf945b800 0x00062000
D RKNN: [09:32:38.515] 85  ConvAddRelu    1352                  FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf945b800 0xf948c800 0x00031000
D RKNN: [09:32:38.515] 86  ConvRelu       857                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 87  ConvAddRelu    860                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf93e1000 0xf9412000 0x00031000
D RKNN: [09:32:38.515] 87  ConvAddRelu    857                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 88  Transpose      897                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf93b0000 0xf93e1000 0x00031000
D RKNN: [09:32:38.515] 88  Transpose      897_exSecondary       FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 89  Reshape        907                   FLOAT16   UNDEFINED    (1,28,28,128)  (1,28,28,128)   | 0xf9443000 0xf947b000 0x00038000
D RKNN: [09:32:38.515] 89  Reshape        907_exSecondary       FLOAT16   NC1HWC2      (1,28,28,128)  (1,14,28,128,8) | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 90  Reshape        907                   FLOAT16   UNDEFINED    (1,28,28,128)  (1,28,28,128)   | 0xf9443000 0xf947b000 0x00038000
D RKNN: [09:32:38.515] 90  Reshape        907_1_exSecondary     FLOAT16   NC1HWC2      (1,28,28,128)  (1,14,28,128,8) | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 91  Mul            919_rs                FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf93e1000 0xf9412000 0x00031000
D RKNN: [09:32:38.515] 92  Transpose      933-rs                FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 92  Transpose      933-rs_exSecondary    FLOAT16   NC1HWC2      (1,784,1,128)  (1,784,1,128,8) | 0xf9443000 0xf94a5000 0x00062000
D RKNN: [09:32:38.515] 93  Conv           933_rs                FLOAT16   NC1HWC2      (784,128,1,1)  (784,64,1,1,8)  | 0xf93e1000 0xf9412000 0x00031000
D RKNN: [09:32:38.515] 94  Transpose      933_rs_mm             FLOAT16   NC1HWC2      (784,1,1,1)    (784,8,1,1,8)   | 0xf937f000 0xf9385200 0x00006200
D RKNN: [09:32:38.515] 94  Transpose      933_rs_mm_exSecondary FLOAT16   NC1HWC2      (784,1,1,1)    (784,4,1,1,8)   | 0xf9385200 0xf9388920 0x00003720
D RKNN: [09:32:38.515] 95  Sqrt           934_rs                FLOAT16   NC1HWC2      (1,784,1,1)    (1,3136,1,1,8)  | 0xf9388940 0xf938ba40 0x00003100
D RKNN: [09:32:38.515] 96  Expand         935-rs                FLOAT16   NC1HWC2      (1,784,1,1)    (1,800,1,1,8)   | 0xf937f000 0xf937fc80 0x00000c80
D RKNN: [09:32:38.515] 97  Div            919_rs#1              FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf93b0000 0xf93e1000 0x00031000
D RKNN: [09:32:38.515] 97  Div            935_rs_expand         FLOAT16   NC1HWC2      (1,784,1,128)  (1,400,1,128,8) | 0xf9443000 0xf9475000 0x00032000
D RKNN: [09:32:38.515] 98  Transpose      939-rs                FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 98  Transpose      939-rs_exSecondary    FLOAT16   NC1HWC2      (1,784,1,128)  (1,784,1,128,8) | 0xf93b0000 0xf9412000 0x00062000
D RKNN: [09:32:38.515] 99  Transpose      864                   FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf9412000 0xf9443000 0x00031000
D RKNN: [09:32:38.515] 99  Transpose      864_exSecondary       FLOAT16   NC1HWC2      (1,128,28,28)  (1,64,28,28,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 100 Reshape        920                   FLOAT16   UNDEFINED    (1,28,28,128)  (1,28,28,128)   | 0xf93b0000 0xf93e8000 0x00038000
D RKNN: [09:32:38.515] 100 Reshape        920_exSecondary       FLOAT16   NC1HWC2      (1,28,28,128)  (1,14,28,128,8) | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 101 Reshape        920                   FLOAT16   UNDEFINED    (1,28,28,128)  (1,28,28,128)   | 0xf93b0000 0xf93e8000 0x00038000
D RKNN: [09:32:38.515] 101 Reshape        920_1_exSecondary     FLOAT16   NC1HWC2      (1,28,28,128)  (1,14,28,128,8) | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 102 Mul            932_rs                FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf9474000 0xf94a5000 0x00031000
D RKNN: [09:32:38.515] 103 Transpose      936-rs                FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 103 Transpose      936-rs_exSecondary    FLOAT16   NC1HWC2      (1,784,1,128)  (1,784,1,128,8) | 0xf9474000 0xf94d6000 0x00062000
D RKNN: [09:32:38.515] 104 Conv           936_rs                FLOAT16   NC1HWC2      (784,128,1,1)  (784,64,1,1,8)  | 0xf93b0000 0xf93e1000 0x00031000
D RKNN: [09:32:38.515] 105 Transpose      936_rs_mm             FLOAT16   NC1HWC2      (784,1,1,1)    (784,8,1,1,8)   | 0xf93e1000 0xf93e7200 0x00006200
D RKNN: [09:32:38.515] 105 Transpose      936_rs_mm_exSecondary FLOAT16   NC1HWC2      (784,1,1,1)    (784,4,1,1,8)   | 0xf9419000 0xf941c720 0x00003720
D RKNN: [09:32:38.515] 106 Sqrt           937_rs                FLOAT16   NC1HWC2      (1,784,1,1)    (1,3136,1,1,8)  | 0xf941c740 0xf941f840 0x00003100
D RKNN: [09:32:38.515] 107 Expand         938-rs                FLOAT16   NC1HWC2      (1,784,1,1)    (1,800,1,1,8)   | 0xf9419000 0xf9419c80 0x00000c80
D RKNN: [09:32:38.515] 108 Div            932_rs#1              FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf93e8000 0xf9419000 0x00031000
D RKNN: [09:32:38.515] 108 Div            938_rs_expand         FLOAT16   NC1HWC2      (1,784,1,128)  (1,400,1,128,8) | 0xf937f000 0xf93b1000 0x00032000
D RKNN: [09:32:38.515] 109 Transpose      940-rs                FLOAT16   NC1HWC2      (1,784,1,128)  (1,392,1,128,8) | 0xf93b1000 0xf93e2000 0x00031000
D RKNN: [09:32:38.515] 109 Transpose      940-rs_exSecondary    FLOAT16   NC1HWC2      (1,784,1,128)  (1,784,1,128,8) | 0xf9474000 0xf94d6000 0x00062000
D RKNN: [09:32:38.515] 110 exMatMul       939_tp-rs             FLOAT16   NC1HWC2      (1,128,1,784)  (1,64,1,784,8)  | 0xf9443000 0xf9474000 0x00031000
D RKNN: [09:32:38.515] 110 exMatMul       941-rs                FLOAT16   NC1HWC2      (1,128,1,784)  (1,64,1,784,8)  | 0xf937f000 0xf93b0000 0x00031000
D RKNN: [09:32:38.515] 110 exMatMul       939_tp-rs_exSecondary FLOAT16   NC1HWC2      (1,128,1,784)  (1,520,1,784,8) | 0xf9474000 0xf9602280 0x0018e280
D RKNN: [09:32:38.515] 111 Sub            942_mm                FLOAT16   NC1HWC2      (1,784,1,784)  (1,392,1,784,8) | 0xf9784000 0xf98b0200 0x0012c200
D RKNN: [09:32:38.515] 112 TopK           944-rs                FLOAT16   NC1HWC2      (1,784,1,784)  (1,392,1,784,8) | 0xf937f000 0xf94ab200 0x0012c200
D RKNN: [09:32:38.515] 113 ReduceMax      948-rs                FLOAT16   UNDEFINED    (1,784,1,1)    (1,784,1,1)     | 0xf94ab200 0xf94ab820 0x00000620
D RKNN: [09:32:38.515] 114 Expand         1102-rs               FLOAT16   NC1HWC2      (1,1,1,1)      (1,4,1,1,8)     | 0xf937f000 0xf937f010 0x00000010
D RKNN: [09:32:38.515] 115 Reshape        948-rs                FLOAT16   UNDEFINED    (1,784,1,1)    (1,784,1,1)     | 0xf94ab200 0xf94ab820 0x00000620
D RKNN: [09:32:38.515] 115 Reshape        948-rs_exSecondary    FLOAT16   NC1HWC2      (1,784,1,1)    (1,6272,1,1,8)  | 0xf938b440 0xf9391640 0x00006200
D RKNN: [09:32:38.515] 116 Div            1080                  FLOAT16   NC1HWC2      (1,1,28,28)    (1,4,28,28,8)   | 0xf9391640 0xf9394740 0x00003100
D RKNN: [09:32:38.515] 116 Div            1104_expand           FLOAT16   NC1HWC2      (1,1,28,28)    (1,16,28,28,8)  | 0xf937f040 0xf938b440 0x0000c400
D RKNN: [09:32:38.515] 117 Add            1105                  FLOAT16   NC1HWC2      (1,1,28,28)    (1,4,28,28,8)   | 0xf938b440 0xf938e540 0x00003100
D RKNN: [09:32:38.515] 118 Mul            1073                  FLOAT16   NC1HWC2      (1,256,28,28)  (1,384,28,28,8) | 0xf965e000 0xf9784000 0x00126000
D RKNN: [09:32:38.515] 118 Mul            1107                  FLOAT16   NC1HWC2      (1,1,28,28)    (1,4,28,28,8)   | 0xf937f000 0xf9382100 0x00003100
D RKNN: [09:32:38.515] 118 Mul            1073_exSecondary      FLOAT16   NC1HWC2      (1,256,28,28)  (1,128,28,28,8) | 0xf9382100 0xf93e4100 0x00062000
D RKNN: [09:32:38.515] 119 ConvExSwish    1108                  FLOAT16   NC1HWC2      (1,256,28,28)  (1,128,28,28,8) | 0xf93e4100 0xf9446100 0x00062000
D RKNN: [09:32:38.515] 120 ConvExSwish    1112                  FLOAT16   NC1HWC2      (1,512,14,14)  (1,768,14,14,8) | 0xf9446100 0xf94d9100 0x00093000
D RKNN: [09:32:38.515] 121 ConvExSwish    1112                  FLOAT16   NC1HWC2      (1,512,14,14)  (1,768,14,14,8) | 0xf9446100 0xf94d9100 0x00093000
D RKNN: [09:32:38.515] 122 ConvExSwish    1116                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf937f000 0xf93c8800 0x00049800
D RKNN: [09:32:38.515] 123 ConvExSwish    1120                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 124 Add            1116                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf937f000 0xf93c8800 0x00049800
D RKNN: [09:32:38.515] 124 Add            1124                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 125 ConvExSwish    1125                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9412000 0xf942a800 0x00018800
D RKNN: [09:32:38.515] 126 ConvExSwish    1129                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf937f000 0xf93c8800 0x00049800
D RKNN: [09:32:38.515] 127 Add            1125                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9412000 0xf942a800 0x00018800
D RKNN: [09:32:38.515] 127 Add            1133                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf942a800 0xf9474000 0x00049800
D RKNN: [09:32:38.515] 128 ConvExSwish    1134                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 129 ConvExSwish    1138                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 130 Add            1134                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 130 Add            1142                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 131 ConvExSwish    1143                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 132 ConvExSwish    1147                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 133 Add            1143                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 133 Add            1151                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 134 ConvExSwish    1152                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 135 ConvExSwish    1156                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 136 Add            1152                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 136 Add            1160                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 137 ConvExSwish    1161                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 138 ConvExSwish    1165                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 139 Add            1161                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 139 Add            1169                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 140 ConvExSwish    1170                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 141 ConvExSwish    1174                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 142 Add            1170                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 142 Add            1178                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 143 ConvExSwish    1179                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 144 ConvExSwish    1183                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 145 Add            1179                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 145 Add            1187                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 146 ConvExSwish    1188                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 147 ConvExSwish    1192                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf9412000 0xf945b800 0x00049800
D RKNN: [09:32:38.515] 148 Add            1188                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf937f000 0xf9397800 0x00018800
D RKNN: [09:32:38.515] 148 Add            1196                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf945b800 0xf94a5000 0x00049800
D RKNN: [09:32:38.515] 149 Concat         1197                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,128,14,14,8) | 0xf9397800 0xf93b0000 0x00018800
D RKNN: [09:32:38.515] 149 Concat         1201                  FLOAT16   NC1HWC2      (1,256,14,14)  (1,384,14,14,8) | 0xf93c8800 0xf9412000 0x00049800
D RKNN: [09:32:38.515] 150 ConvExSwish    1202                  FLOAT16   NC1HWC2      (1,512,14,14)  (1,256,14,14,8) | 0xf9412000 0xf9443000 0x00031000
D RKNN: [09:32:38.515] 151 ConvExSwish    1206                  FLOAT16   NC1HWC2      (1,512,14,14)  (1,768,14,14,8) | 0xf937f000 0xf9412000 0x00093000
D RKNN: [09:32:38.515] 152 ConvExSwish    1210                  FLOAT16   NC1HWC2      (1,1024,7,7)   (1,1630,7,7,8)  | 0xf9412000 0xf9460000 0x0004e000
D RKNN: [09:32:38.515] 153 ConvExSwish    1210                  FLOAT16   NC1HWC2      (1,1024,7,7)   (1,1630,7,7,8)  | 0xf9412000 0xf9460000 0x0004e000
D RKNN: [09:32:38.515] 154 ConvExSwish    1214                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf937f000 0xf93a6000 0x00027000
D RKNN: [09:32:38.515] 155 ConvExSwish    1218                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf93cd000 0xf93f4000 0x00027000
D RKNN: [09:32:38.515] 156 Add            1214                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf937f000 0xf93a6000 0x00027000
D RKNN: [09:32:38.515] 156 Add            1222                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf93f4000 0xf941b000 0x00027000
D RKNN: [09:32:38.515] 157 ConvExSwish    1223                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf93cd000 0xf93da000 0x0000d000
D RKNN: [09:32:38.515] 158 ConvExSwish    1227                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf937f000 0xf93a6000 0x00027000
D RKNN: [09:32:38.515] 159 Add            1223                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf93cd000 0xf93da000 0x0000d000
D RKNN: [09:32:38.515] 159 Add            1231                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf93da000 0xf9401000 0x00027000
D RKNN: [09:32:38.515] 160 ConvExSwish    1232                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf937f000 0xf938c000 0x0000d000
D RKNN: [09:32:38.515] 161 ConvExSwish    1236                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf93cd000 0xf93f4000 0x00027000
D RKNN: [09:32:38.515] 162 Add            1232                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf937f000 0xf938c000 0x0000d000
D RKNN: [09:32:38.515] 162 Add            1240                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf93f4000 0xf941b000 0x00027000
D RKNN: [09:32:38.515] 163 Concat         1241                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,270,7,7,8)   | 0xf938c000 0xf9399000 0x0000d000
D RKNN: [09:32:38.515] 163 Concat         1245                  FLOAT16   NC1HWC2      (1,512,7,7)    (1,814,7,7,8)   | 0xf93a6000 0xf93cd000 0x00027000
D RKNN: [09:32:38.515] 164 ConvExSwish    1246                  FLOAT16   NC1HWC2      (1,1024,7,7)   (1,542,7,7,8)   | 0xf93cd000 0xf93e7000 0x0001a000
D RKNN: [09:32:38.515] 165 ConvExSwish    1250                  FLOAT16   NC1HWC2      (1,1024,7,7)   (1,1630,7,7,8)  | 0xf937f000 0xf93cd000 0x0004e000
D RKNN: [09:32:38.515] 166 Conv           1253                  FLOAT16   NC1HWC2      (1,1280,7,7)   (1,2036,7,7,8)  | 0xf93cd000 0xf942e800 0x00061800
D RKNN: [09:32:38.515] 167 Conv           1253                  FLOAT16   NC1HWC2      (1,1280,7,7)   (1,2036,7,7,8)  | 0xf93cd000 0xf942e800 0x00061800
D RKNN: [09:32:38.515] 168 Conv           1257                  FLOAT16   NC1HWC2      (1,1280,1,1)   (1,640,1,1,8)   | 0xf937fa00 0xf9380400 0x00000a00
D RKNN: [09:32:38.515] 169 Conv           1253                  FLOAT16   NC1HWC2      (1,1280,7,7)   (1,2036,7,7,8)  | 0xf93cd000 0xf942e800 0x00061800
D RKNN: [09:32:38.515] 170 Conv           1254                  FLOAT16   NC1HWC2      (1,1280,1,1)   (1,640,1,1,8)   | 0xf937fa00 0xf9380400 0x00000a00
D RKNN: [09:32:38.515] 171 Reshape        1260                  FLOAT16   NC1HWC2      (1,1280,1,1)   (1,640,1,1,8)   | 0xf937f000 0xf937fa00 0x00000a00
D RKNN: [09:32:38.515] 171 Reshape        1260_exSecondary      FLOAT16   NC1HWC2      (1,1280,1,1)   (1,640,1,1,8)   | 0xf937fa00 0xf9380400 0x00000a00
D RKNN: [09:32:38.515] 172 OutputOperator 1261                  FLOAT16   UNDEFINED    (1,1280)       (1,1280)        | 0xf9380500 0xf9380f00 0x00000a00
D RKNN: [09:32:38.515] 173 Reshape        1259_mm               FLOAT16   NC1HWC2      (1,1,1,1)      (1,8,1,1,8)     | 0xf9380400 0xf9380420 0x00000020
D RKNN: [09:32:38.515] 174 OutputOperator 1259                  FLOAT16   UNDEFINED    (1,1)          (1,1)           | 0xf937f040 0xf937f080 0x00000040
D RKNN: [09:32:38.515] 175 Reshape        out_mm                FLOAT16   NC1HWC2      (1,71,1,1)     (1,40,1,1,8)    | 0xf9380440 0xf93804e0 0x000000a0
D RKNN: [09:32:38.515] 176 OutputOperator out                   FLOAT16   UNDEFINED    (1,71)         (1,71)          | 0xf937f080 0xf937f140 0x000000c0
D RKNN: [09:32:38.515]                                     Const Tensor Information Table
D RKNN: [09:32:38.515] ----------------------------------------------------------------------------+---------------------------------
D RKNN: [09:32:38.515] ID  User          Tensor                          DataType  OrigShape       |     [Start       End)       Size
D RKNN: [09:32:38.515] 2   Conv          1263                            FLOAT16   (64,3,7,7)      | 0xf9ff2800 0xf9ffec00 0x0000c400
D RKNN: [09:32:38.515] 2   Conv          1264                            FLOAT     (64)            | 0xf9ffec00 0xf9ffed00 0x00000100
D RKNN: [09:32:38.515] 4   Conv          1365                            FLOAT16   (64,3,7,7)      | 0xfcea7500 0xfceb3900 0x0000c400
D RKNN: [09:32:38.515] 4   Conv          1366                            FLOAT     (64)            | 0xfceb3900 0xfceb3a00 0x00000100
D RKNN: [09:32:38.515] 6   ConvRelu      1266                            FLOAT16   (64,64,3,3)     | 0xf9ffed00 0xfa010d00 0x00012000
D RKNN: [09:32:38.515] 6   ConvRelu      1267                            FLOAT     (64)            | 0xfa010d00 0xfa010e00 0x00000100
D RKNN: [09:32:38.515] 7   ConvRelu      1368                            FLOAT16   (64,64,3,3)     | 0xfceb3a00 0xfcec5a00 0x00012000
D RKNN: [09:32:38.515] 7   ConvRelu      1369                            FLOAT     (64)            | 0xfcec5a00 0xfcec5b00 0x00000100
D RKNN: [09:32:38.515] 8   ConvExSwish   1395                            FLOAT16   (64,3,6,6)      | 0xfcffc800 0xfd005800 0x00009000
D RKNN: [09:32:38.515] 8   ConvExSwish   1396                            FLOAT     (64)            | 0xfd005800 0xfd005900 0x00000100
D RKNN: [09:32:38.515] 9   ConvExSwish   1398                            FLOAT16   (128,64,3,3)    | 0xfd005900 0xfd029900 0x00024000
D RKNN: [09:32:38.515] 9   ConvExSwish   1399                            FLOAT     (128)           | 0xfd029900 0xfd029b00 0x00000200
D RKNN: [09:32:38.515] 10  ConvExSwish   1401                            FLOAT16   (64,128,1,1)    | 0xfd029b00 0xfd02db00 0x00004000
D RKNN: [09:32:38.515] 10  ConvExSwish   1402                            FLOAT     (64)            | 0xfd02db00 0xfd02dc00 0x00000100
D RKNN: [09:32:38.515] 11  ConvExSwish   1422                            FLOAT16   (64,128,1,1)    | 0xfd06a200 0xfd06e200 0x00004000
D RKNN: [09:32:38.515] 11  ConvExSwish   1423                            FLOAT     (64)            | 0xfd06e200 0xfd06e300 0x00000100
D RKNN: [09:32:38.515] 12  ConvExSwish   1404                            FLOAT16   (64,64,1,1)     | 0xfd02dc00 0xfd02fc00 0x00002000
D RKNN: [09:32:38.515] 12  ConvExSwish   1405                            FLOAT     (64)            | 0xfd02fc00 0xfd02fd00 0x00000100
D RKNN: [09:32:38.515] 13  ConvExSwish   1407                            FLOAT16   (64,64,3,3)     | 0xfd02fd00 0xfd041d00 0x00012000
D RKNN: [09:32:38.515] 13  ConvExSwish   1408                            FLOAT     (64)            | 0xfd041d00 0xfd041e00 0x00000100
D RKNN: [09:32:38.515] 15  ConvExSwish   1410                            FLOAT16   (64,64,1,1)     | 0xfd041e00 0xfd043e00 0x00002000
D RKNN: [09:32:38.515] 15  ConvExSwish   1411                            FLOAT     (64)            | 0xfd043e00 0xfd043f00 0x00000100
D RKNN: [09:32:38.515] 16  ConvExSwish   1413                            FLOAT16   (64,64,3,3)     | 0xfd043f00 0xfd055f00 0x00012000
D RKNN: [09:32:38.515] 16  ConvExSwish   1414                            FLOAT     (64)            | 0xfd055f00 0xfd056000 0x00000100
D RKNN: [09:32:38.515] 18  ConvExSwish   1416                            FLOAT16   (64,64,1,1)     | 0xfd056000 0xfd058000 0x00002000
D RKNN: [09:32:38.515] 18  ConvExSwish   1417                            FLOAT     (64)            | 0xfd058000 0xfd058100 0x00000100
D RKNN: [09:32:38.515] 19  ConvExSwish   1419                            FLOAT16   (64,64,3,3)     | 0xfd058100 0xfd06a100 0x00012000
D RKNN: [09:32:38.515] 19  ConvExSwish   1420                            FLOAT     (64)            | 0xfd06a100 0xfd06a200 0x00000100
D RKNN: [09:32:38.515] 22  ConvExSwish   1425                            FLOAT16   (128,128,1,1)   | 0xfd06e300 0xfd076300 0x00008000
D RKNN: [09:32:38.515] 22  ConvExSwish   1426                            FLOAT     (128)           | 0xfd076300 0xfd076500 0x00000200
D RKNN: [09:32:38.515] 23  ConvExSwish   1428                            FLOAT16   (256,128,3,3)   | 0xfd076500 0xfd106500 0x00090000
D RKNN: [09:32:38.515] 23  ConvExSwish   1429                            FLOAT     (256)           | 0xfd106500 0xfd106900 0x00000400
D RKNN: [09:32:38.515] 24  ConvExSwish   1431                            FLOAT16   (128,256,1,1)   | 0xfd106900 0xfd116900 0x00010000
D RKNN: [09:32:38.515] 24  ConvExSwish   1432                            FLOAT     (128)           | 0xfd116900 0xfd116b00 0x00000200
D RKNN: [09:32:38.515] 25  ConvExSwish   1470                            FLOAT16   (128,256,1,1)   | 0xfd2f8300 0xfd308300 0x00010000
D RKNN: [09:32:38.515] 25  ConvExSwish   1471                            FLOAT     (128)           | 0xfd308300 0xfd308500 0x00000200
D RKNN: [09:32:38.515] 26  ConvExSwish   1434                            FLOAT16   (128,128,1,1)   | 0xfd116b00 0xfd11eb00 0x00008000
D RKNN: [09:32:38.515] 26  ConvExSwish   1435                            FLOAT     (128)           | 0xfd11eb00 0xfd11ed00 0x00000200
D RKNN: [09:32:38.515] 27  ConvExSwish   1437                            FLOAT16   (128,128,3,3)   | 0xfd11ed00 0xfd166d00 0x00048000
D RKNN: [09:32:38.515] 27  ConvExSwish   1438                            FLOAT     (128)           | 0xfd166d00 0xfd166f00 0x00000200
D RKNN: [09:32:38.515] 29  ConvExSwish   1440                            FLOAT16   (128,128,1,1)   | 0xfd166f00 0xfd16ef00 0x00008000
D RKNN: [09:32:38.515] 29  ConvExSwish   1441                            FLOAT     (128)           | 0xfd16ef00 0xfd16f100 0x00000200
D RKNN: [09:32:38.515] 30  ConvExSwish   1443                            FLOAT16   (128,128,3,3)   | 0xfd16f100 0xfd1b7100 0x00048000
D RKNN: [09:32:38.515] 30  ConvExSwish   1444                            FLOAT     (128)           | 0xfd1b7100 0xfd1b7300 0x00000200
D RKNN: [09:32:38.515] 32  ConvExSwish   1446                            FLOAT16   (128,128,1,1)   | 0xfd1b7300 0xfd1bf300 0x00008000
D RKNN: [09:32:38.515] 32  ConvExSwish   1447                            FLOAT     (128)           | 0xfd1bf300 0xfd1bf500 0x00000200
D RKNN: [09:32:38.515] 33  ConvExSwish   1449                            FLOAT16   (128,128,3,3)   | 0xfd1bf500 0xfd207500 0x00048000
D RKNN: [09:32:38.515] 33  ConvExSwish   1450                            FLOAT     (128)           | 0xfd207500 0xfd207700 0x00000200
D RKNN: [09:32:38.515] 35  ConvExSwish   1452                            FLOAT16   (128,128,1,1)   | 0xfd207700 0xfd20f700 0x00008000
D RKNN: [09:32:38.515] 35  ConvExSwish   1453                            FLOAT     (128)           | 0xfd20f700 0xfd20f900 0x00000200
D RKNN: [09:32:38.515] 36  ConvExSwish   1455                            FLOAT16   (128,128,3,3)   | 0xfd20f900 0xfd257900 0x00048000
D RKNN: [09:32:38.515] 36  ConvExSwish   1456                            FLOAT     (128)           | 0xfd257900 0xfd257b00 0x00000200
D RKNN: [09:32:38.515] 38  ConvExSwish   1458                            FLOAT16   (128,128,1,1)   | 0xfd257b00 0xfd25fb00 0x00008000
D RKNN: [09:32:38.515] 38  ConvExSwish   1459                            FLOAT     (128)           | 0xfd25fb00 0xfd25fd00 0x00000200
D RKNN: [09:32:38.515] 39  ConvExSwish   1461                            FLOAT16   (128,128,3,3)   | 0xfd25fd00 0xfd2a7d00 0x00048000
D RKNN: [09:32:38.515] 39  ConvExSwish   1462                            FLOAT     (128)           | 0xfd2a7d00 0xfd2a7f00 0x00000200
D RKNN: [09:32:38.515] 41  ConvExSwish   1464                            FLOAT16   (128,128,1,1)   | 0xfd2a7f00 0xfd2aff00 0x00008000
D RKNN: [09:32:38.515] 41  ConvExSwish   1465                            FLOAT     (128)           | 0xfd2aff00 0xfd2b0100 0x00000200
D RKNN: [09:32:38.515] 42  ConvExSwish   1467                            FLOAT16   (128,128,3,3)   | 0xfd2b0100 0xfd2f8100 0x00048000
D RKNN: [09:32:38.515] 42  ConvExSwish   1468                            FLOAT     (128)           | 0xfd2f8100 0xfd2f8300 0x00000200
D RKNN: [09:32:38.515] 45  ConvExSwish   1473                            FLOAT16   (256,256,1,1)   | 0xfd308500 0xfd328500 0x00020000
D RKNN: [09:32:38.515] 45  ConvExSwish   1474                            FLOAT     (256)           | 0xfd328500 0xfd328900 0x00000400
D RKNN: [09:32:38.515] 46  ConvAddRelu   1269                            FLOAT16   (64,64,3,3)     | 0xfa010e00 0xfa022e00 0x00012000
D RKNN: [09:32:38.515] 46  ConvAddRelu   1270                            FLOAT     (64)            | 0xfa022e00 0xfa022f00 0x00000100
D RKNN: [09:32:38.515] 47  ConvRelu      1272                            FLOAT16   (64,64,3,3)     | 0xfa022f00 0xfa034f00 0x00012000
D RKNN: [09:32:38.515] 47  ConvRelu      1273                            FLOAT     (64)            | 0xfa034f00 0xfa035000 0x00000100
D RKNN: [09:32:38.515] 48  ConvAddRelu   1371                            FLOAT16   (64,64,3,3)     | 0xfcec5b00 0xfced7b00 0x00012000
D RKNN: [09:32:38.515] 48  ConvAddRelu   1372                            FLOAT     (64)            | 0xfced7b00 0xfced7c00 0x00000100
D RKNN: [09:32:38.515] 49  ConvRelu      1374                            FLOAT16   (64,64,3,3)     | 0xfced7c00 0xfcee9c00 0x00012000
D RKNN: [09:32:38.515] 49  ConvRelu      1375                            FLOAT     (64)            | 0xfcee9c00 0xfcee9d00 0x00000100
D RKNN: [09:32:38.515] 50  ConvAddRelu   1275                            FLOAT16   (64,64,3,3)     | 0xfa035000 0xfa047000 0x00012000
D RKNN: [09:32:38.515] 50  ConvAddRelu   1276                            FLOAT     (64)            | 0xfa047000 0xfa047100 0x00000100
D RKNN: [09:32:38.515] 51  ConvRelu      1278                            FLOAT16   (128,64,3,3)    | 0xfa047100 0xfa06b100 0x00024000
D RKNN: [09:32:38.515] 51  ConvRelu      1279                            FLOAT     (128)           | 0xfa06b100 0xfa06b300 0x00000200
D RKNN: [09:32:38.515] 52  Conv          1281                            FLOAT16   (128,128,3,3)   | 0xfa06b300 0xfa0b3300 0x00048000
D RKNN: [09:32:38.515] 52  Conv          1282                            FLOAT     (128)           | 0xfa0b3300 0xfa0b3500 0x00000200
D RKNN: [09:32:38.515] 53  ConvAddRelu   1377                            FLOAT16   (64,64,3,3)     | 0xfcee9d00 0xfcefbd00 0x00012000
D RKNN: [09:32:38.515] 53  ConvAddRelu   1378                            FLOAT     (64)            | 0xfcefbd00 0xfcefbe00 0x00000100
D RKNN: [09:32:38.515] 54  ConvRelu      1380                            FLOAT16   (128,64,3,3)    | 0xfcefbe00 0xfcf1fe00 0x00024000
D RKNN: [09:32:38.515] 54  ConvRelu      1381                            FLOAT     (128)           | 0xfcf1fe00 0xfcf20000 0x00000200
D RKNN: [09:32:38.515] 55  Conv          1383                            FLOAT16   (128,128,3,3)   | 0xfcf20000 0xfcf68000 0x00048000
D RKNN: [09:32:38.515] 55  Conv          1384                            FLOAT     (128)           | 0xfcf68000 0xfcf68200 0x00000200
D RKNN: [09:32:38.515] 56  ConvAddRelu   1284                            FLOAT16   (128,64,1,1)    | 0xfa0b3500 0xfa0b7500 0x00004000
D RKNN: [09:32:38.515] 56  ConvAddRelu   1285                            FLOAT     (128)           | 0xfa0b7500 0xfa0b7700 0x00000200
D RKNN: [09:32:38.515] 57  ConvRelu      1287                            FLOAT16   (128,128,3,3)   | 0xfa0b7700 0xfa0ff700 0x00048000
D RKNN: [09:32:38.515] 57  ConvRelu      1288                            FLOAT     (128)           | 0xfa0ff700 0xfa0ff900 0x00000200
D RKNN: [09:32:38.515] 58  ConvAddRelu   1386                            FLOAT16   (128,64,1,1)    | 0xfcf68200 0xfcf6c200 0x00004000
D RKNN: [09:32:38.515] 58  ConvAddRelu   1387                            FLOAT     (128)           | 0xfcf6c200 0xfcf6c400 0x00000200
D RKNN: [09:32:38.515] 59  ConvRelu      1389                            FLOAT16   (128,128,3,3)   | 0xfcf6c400 0xfcfb4400 0x00048000
D RKNN: [09:32:38.515] 59  ConvRelu      1390                            FLOAT     (128)           | 0xfcfb4400 0xfcfb4600 0x00000200
D RKNN: [09:32:38.515] 60  ConvAddRelu   1290                            FLOAT16   (128,128,3,3)   | 0xfa0ff900 0xfa147900 0x00048000
D RKNN: [09:32:38.515] 60  ConvAddRelu   1291                            FLOAT     (128)           | 0xfa147900 0xfa147b00 0x00000200
D RKNN: [09:32:38.515] 61  ConvRelu      1293                            FLOAT16   (256,128,3,3)   | 0xfa147b00 0xfa1d7b00 0x00090000
D RKNN: [09:32:38.515] 61  ConvRelu      1294                            FLOAT     (256)           | 0xfa1d7b00 0xfa1d7f00 0x00000400
D RKNN: [09:32:38.515] 62  Conv          1296                            FLOAT16   (256,256,3,3)   | 0xfa1d7f00 0xfa2f7f00 0x00120000
D RKNN: [09:32:38.515] 62  Conv          1297                            FLOAT     (256)           | 0xfa2f7f00 0xfa2f8300 0x00000400
D RKNN: [09:32:38.515] 63  ConvAddRelu   1392                            FLOAT16   (128,128,3,3)   | 0xfcfb4600 0xfcffc600 0x00048000
D RKNN: [09:32:38.515] 63  ConvAddRelu   1393                            FLOAT     (128)           | 0xfcffc600 0xfcffc800 0x00000200
D RKNN: [09:32:38.515] 64  ConvAddRelu   1299                            FLOAT16   (256,128,1,1)   | 0xfa2f8300 0xfa308300 0x00010000
D RKNN: [09:32:38.515] 64  ConvAddRelu   1300                            FLOAT     (256)           | 0xfa308300 0xfa308700 0x00000400
D RKNN: [09:32:38.515] 65  ConvRelu      1302                            FLOAT16   (256,256,3,3)   | 0xfa308700 0xfa428700 0x00120000
D RKNN: [09:32:38.515] 65  ConvRelu      1303                            FLOAT     (256)           | 0xfa428700 0xfa428b00 0x00000400
D RKNN: [09:32:38.515] 66  ConvAddRelu   1305                            FLOAT16   (256,256,3,3)   | 0xfa428b00 0xfa548b00 0x00120000
D RKNN: [09:32:38.515] 66  ConvAddRelu   1306                            FLOAT     (256)           | 0xfa548b00 0xfa548f00 0x00000400
D RKNN: [09:32:38.515] 67  ConvRelu      1308                            FLOAT16   (512,256,3,3)   | 0xfa548f00 0xfa788f00 0x00240000
D RKNN: [09:32:38.515] 67  ConvRelu      1309                            FLOAT     (512)           | 0xfa788f00 0xfa789700 0x00000800
D RKNN: [09:32:38.515] 68  Conv          1311                            FLOAT16   (512,512,3,3)   | 0xfa789700 0xfac09700 0x00480000
D RKNN: [09:32:38.515] 68  Conv          1312                            FLOAT     (512)           | 0xfac09700 0xfac09f00 0x00000800
D RKNN: [09:32:38.515] 69  ConvAddRelu   1314                            FLOAT16   (512,256,1,1)   | 0xfac09f00 0xfac49f00 0x00040000
D RKNN: [09:32:38.515] 69  ConvAddRelu   1315                            FLOAT     (512)           | 0xfac49f00 0xfac4a700 0x00000800
D RKNN: [09:32:38.515] 70  ConvRelu      1317                            FLOAT16   (512,512,3,3)   | 0xfac4a700 0xfb0ca700 0x00480000
D RKNN: [09:32:38.515] 70  ConvRelu      1318                            FLOAT     (512)           | 0xfb0ca700 0xfb0caf00 0x00000800
D RKNN: [09:32:38.515] 71  ConvAddRelu   1320                            FLOAT16   (512,512,3,3)   | 0xfb0caf00 0xfb54af00 0x00480000
D RKNN: [09:32:38.515] 71  ConvAddRelu   1321                            FLOAT     (512)           | 0xfb54af00 0xfb54b700 0x00000800
D RKNN: [09:32:38.515] 72  ConvRelu      1323                            FLOAT16   (512,512,3,3)   | 0xfb54b700 0xfb9cb700 0x00480000
D RKNN: [09:32:38.515] 72  ConvRelu      1324                            FLOAT     (512)           | 0xfb9cb700 0xfb9cbf00 0x00000800
D RKNN: [09:32:38.515] 73  ConvAddRelu   1326                            FLOAT16   (512,512,3,3)   | 0xfb9cbf00 0xfbe4bf00 0x00480000
D RKNN: [09:32:38.515] 73  ConvAddRelu   1327                            FLOAT     (512)           | 0xfbe4bf00 0xfbe4c700 0x00000800
D RKNN: [09:32:38.515] 74  ConvRelu      1329                            FLOAT16   (512,512,3,3)   | 0xfbe4c700 0xfc2cc700 0x00480000
D RKNN: [09:32:38.515] 74  ConvRelu      1330                            FLOAT     (512)           | 0xfc2cc700 0xfc2ccf00 0x00000800
D RKNN: [09:32:38.515] 75  ConvAddRelu   1332                            FLOAT16   (512,512,3,3)   | 0xfc2ccf00 0xfc74cf00 0x00480000
D RKNN: [09:32:38.515] 75  ConvAddRelu   1333                            FLOAT     (512)           | 0xfc74cf00 0xfc74d700 0x00000800
D RKNN: [09:32:38.515] 76  ConvTranspose Resize_73_2deconv_i1            FLOAT16   (512,1,4,4)     | 0xffdb4a00 0xffdb8a00 0x00004000
D RKNN: [09:32:38.515] 77  ConvRelu      1335                            FLOAT16   (256,512,3,3)   | 0xfc74d700 0xfc98d700 0x00240000
D RKNN: [09:32:38.515] 77  ConvRelu      1336                            FLOAT     (256)           | 0xfc98d700 0xfc98db00 0x00000400
D RKNN: [09:32:38.515] 78  Conv          1338                            FLOAT16   (256,256,3,3)   | 0xfc98db00 0xfcaadb00 0x00120000
D RKNN: [09:32:38.515] 78  Conv          1339                            FLOAT     (256)           | 0xfcaadb00 0xfcaadf00 0x00000400
D RKNN: [09:32:38.515] 79  ConvAddRelu   1341                            FLOAT16   (256,512,1,1)   | 0xfcaadf00 0xfcaedf00 0x00040000
D RKNN: [09:32:38.515] 79  ConvAddRelu   1342                            FLOAT     (256)           | 0xfcaedf00 0xfcaee300 0x00000400
D RKNN: [09:32:38.515] 80  ConvRelu      1344                            FLOAT16   (256,256,3,3)   | 0xfcaee300 0xfcc0e300 0x00120000
D RKNN: [09:32:38.515] 80  ConvRelu      1345                            FLOAT     (256)           | 0xfcc0e300 0xfcc0e700 0x00000400
D RKNN: [09:32:38.515] 81  ConvAddRelu   1347                            FLOAT16   (256,256,3,3)   | 0xfcc0e700 0xfcd2e700 0x00120000
D RKNN: [09:32:38.515] 81  ConvAddRelu   1348                            FLOAT     (256)           | 0xfcd2e700 0xfcd2eb00 0x00000400
D RKNN: [09:32:38.515] 82  ConvTranspose Resize_103_2deconv_i1           FLOAT16   (256,1,4,4)     | 0xffdb8a00 0xffdbaa00 0x00002000
D RKNN: [09:32:38.515] 83  ConvRelu      1350                            FLOAT16   (128,256,3,3)   | 0xfcd2eb00 0xfcdbeb00 0x00090000
D RKNN: [09:32:38.515] 83  ConvRelu      1351                            FLOAT     (128)           | 0xfcdbeb00 0xfcdbed00 0x00000200
D RKNN: [09:32:38.515] 84  Conv          1353                            FLOAT16   (128,128,3,3)   | 0xfcdbed00 0xfce06d00 0x00048000
D RKNN: [09:32:38.515] 84  Conv          1354                            FLOAT     (128)           | 0xfce06d00 0xfce06f00 0x00000200
D RKNN: [09:32:38.515] 85  ConvAddRelu   1356                            FLOAT16   (128,256,1,1)   | 0xfce06f00 0xfce16f00 0x00010000
D RKNN: [09:32:38.515] 85  ConvAddRelu   1357                            FLOAT     (128)           | 0xfce16f00 0xfce17100 0x00000200
D RKNN: [09:32:38.515] 86  ConvRelu      1359                            FLOAT16   (128,128,3,3)   | 0xfce17100 0xfce5f100 0x00048000
D RKNN: [09:32:38.515] 86  ConvRelu      1360                            FLOAT     (128)           | 0xfce5f100 0xfce5f300 0x00000200
D RKNN: [09:32:38.515] 87  ConvAddRelu   1362                            FLOAT16   (128,128,3,3)   | 0xfce5f300 0xfcea7300 0x00048000
D RKNN: [09:32:38.515] 87  ConvAddRelu   1363                            FLOAT     (128)           | 0xfcea7300 0xfcea7500 0x00000200
D RKNN: [09:32:38.515] 89  Reshape       919_rs#1_i1                     INT64     (4)             | 0xffdbacc0 0xffdbace0 0x00000020
D RKNN: [09:32:38.515] 90  Reshape       919_rs_i1                       INT64     (4)             | 0xffdbab80 0xffdbaba0 0x00000020
D RKNN: [09:32:38.515] 93  Conv          ReduceSum_170_i1                FLOAT16   (1,128,1,1)     | 0xffdbabc0 0xffdbacc0 0x00000100
D RKNN: [09:32:38.515] 96  Expand        935_rs_expand_i1                INT64     (4)             | 0xffe1a880 0xffe1a8a0 0x00000020
D RKNN: [09:32:38.515] 100 Reshape       932_rs#1_i1                     INT64     (4)             | 0xffdbab40 0xffdbab60 0x00000020
D RKNN: [09:32:38.515] 101 Reshape       932_rs_i1                       INT64     (4)             | 0xffdbaa00 0xffdbaa20 0x00000020
D RKNN: [09:32:38.515] 104 Conv          ReduceSum_173_i1                FLOAT16   (1,128,1,1)     | 0xffdbaa40 0xffdbab40 0x00000100
D RKNN: [09:32:38.515] 107 Expand        938_rs_expand_i1                INT64     (4)             | 0xffe1a840 0xffe1a860 0x00000020
D RKNN: [09:32:38.515] 111 Sub           943                             FLOAT     (1,1,1,1)       | 0xffdb4980 0xffdb4984 0x00000004
D RKNN: [09:32:38.515] 112 TopK          1573                            INT64     (1)             | 0xffdb4900 0xffdb4908 0x00000008
D RKNN: [09:32:38.515] 113 ReduceMax     ReduceMax_307_axes              INT64     (1)             | 0xffdb4940 0xffdb4948 0x00000008
D RKNN: [09:32:38.515] 114 Expand        1104_expand_i1                  INT64     (4)             | 0xffdbad40 0xffdbad60 0x00000020
D RKNN: [09:32:38.515] 115 Reshape       Unsqueeze_285_2rs_i1            INT64     (4)             | 0xffdbad00 0xffdbad20 0x00000020
D RKNN: [09:32:38.515] 117 Add           1106                            FLOAT     (1,1,1,1)       | 0xffdb49c0 0xffdb49c4 0x00000004
D RKNN: [09:32:38.515] 119 ConvExSwish   1476                            FLOAT16   (512,256,3,3)   | 0xfd328900 0xfd568900 0x00240000
D RKNN: [09:32:38.515] 119 ConvExSwish   1477                            FLOAT     (512)           | 0xfd568900 0xfd569100 0x00000800
D RKNN: [09:32:38.515] 120 ConvExSwish   1479                            FLOAT16   (256,512,1,1)   | 0xfd569100 0xfd5a9100 0x00040000
D RKNN: [09:32:38.515] 120 ConvExSwish   1480                            FLOAT     (256)           | 0xfd5a9100 0xfd5a9500 0x00000400
D RKNN: [09:32:38.515] 121 ConvExSwish   1536                            FLOAT16   (256,512,1,1)   | 0xfe0edd00 0xfe12dd00 0x00040000
D RKNN: [09:32:38.515] 121 ConvExSwish   1537                            FLOAT     (256)           | 0xfe12dd00 0xfe12e100 0x00000400
D RKNN: [09:32:38.515] 122 ConvExSwish   1482                            FLOAT16   (256,256,1,1)   | 0xfd5a9500 0xfd5c9500 0x00020000
D RKNN: [09:32:38.515] 122 ConvExSwish   1483                            FLOAT     (256)           | 0xfd5c9500 0xfd5c9900 0x00000400
D RKNN: [09:32:38.515] 123 ConvExSwish   1485                            FLOAT16   (256,256,3,3)   | 0xfd5c9900 0xfd6e9900 0x00120000
D RKNN: [09:32:38.515] 123 ConvExSwish   1486                            FLOAT     (256)           | 0xfd6e9900 0xfd6e9d00 0x00000400
D RKNN: [09:32:38.515] 125 ConvExSwish   1488                            FLOAT16   (256,256,1,1)   | 0xfd6e9d00 0xfd709d00 0x00020000
D RKNN: [09:32:38.515] 125 ConvExSwish   1489                            FLOAT     (256)           | 0xfd709d00 0xfd70a100 0x00000400
D RKNN: [09:32:38.515] 126 ConvExSwish   1491                            FLOAT16   (256,256,3,3)   | 0xfd70a100 0xfd82a100 0x00120000
D RKNN: [09:32:38.515] 126 ConvExSwish   1492                            FLOAT     (256)           | 0xfd82a100 0xfd82a500 0x00000400
D RKNN: [09:32:38.515] 128 ConvExSwish   1494                            FLOAT16   (256,256,1,1)   | 0xfd82a500 0xfd84a500 0x00020000
D RKNN: [09:32:38.515] 128 ConvExSwish   1495                            FLOAT     (256)           | 0xfd84a500 0xfd84a900 0x00000400
D RKNN: [09:32:38.515] 129 ConvExSwish   1497                            FLOAT16   (256,256,3,3)   | 0xfd84a900 0xfd96a900 0x00120000
D RKNN: [09:32:38.515] 129 ConvExSwish   1498                            FLOAT     (256)           | 0xfd96a900 0xfd96ad00 0x00000400
D RKNN: [09:32:38.515] 131 ConvExSwish   1500                            FLOAT16   (256,256,1,1)   | 0xfd96ad00 0xfd98ad00 0x00020000
D RKNN: [09:32:38.515] 131 ConvExSwish   1501                            FLOAT     (256)           | 0xfd98ad00 0xfd98b100 0x00000400
D RKNN: [09:32:38.515] 132 ConvExSwish   1503                            FLOAT16   (256,256,3,3)   | 0xfd98b100 0xfdaab100 0x00120000
D RKNN: [09:32:38.515] 132 ConvExSwish   1504                            FLOAT     (256)           | 0xfdaab100 0xfdaab500 0x00000400
D RKNN: [09:32:38.515] 134 ConvExSwish   1506                            FLOAT16   (256,256,1,1)   | 0xfdaab500 0xfdacb500 0x00020000
D RKNN: [09:32:38.515] 134 ConvExSwish   1507                            FLOAT     (256)           | 0xfdacb500 0xfdacb900 0x00000400
D RKNN: [09:32:38.515] 135 ConvExSwish   1509                            FLOAT16   (256,256,3,3)   | 0xfdacb900 0xfdbeb900 0x00120000
D RKNN: [09:32:38.515] 135 ConvExSwish   1510                            FLOAT     (256)           | 0xfdbeb900 0xfdbebd00 0x00000400
D RKNN: [09:32:38.515] 137 ConvExSwish   1512                            FLOAT16   (256,256,1,1)   | 0xfdbebd00 0xfdc0bd00 0x00020000
D RKNN: [09:32:38.515] 137 ConvExSwish   1513                            FLOAT     (256)           | 0xfdc0bd00 0xfdc0c100 0x00000400
D RKNN: [09:32:38.515] 138 ConvExSwish   1515                            FLOAT16   (256,256,3,3)   | 0xfdc0c100 0xfdd2c100 0x00120000
D RKNN: [09:32:38.515] 138 ConvExSwish   1516                            FLOAT     (256)           | 0xfdd2c100 0xfdd2c500 0x00000400
D RKNN: [09:32:38.515] 140 ConvExSwish   1518                            FLOAT16   (256,256,1,1)   | 0xfdd2c500 0xfdd4c500 0x00020000
D RKNN: [09:32:38.515] 140 ConvExSwish   1519                            FLOAT     (256)           | 0xfdd4c500 0xfdd4c900 0x00000400
D RKNN: [09:32:38.515] 141 ConvExSwish   1521                            FLOAT16   (256,256,3,3)   | 0xfdd4c900 0xfde6c900 0x00120000
D RKNN: [09:32:38.515] 141 ConvExSwish   1522                            FLOAT     (256)           | 0xfde6c900 0xfde6cd00 0x00000400
D RKNN: [09:32:38.515] 143 ConvExSwish   1524                            FLOAT16   (256,256,1,1)   | 0xfde6cd00 0xfde8cd00 0x00020000
D RKNN: [09:32:38.515] 143 ConvExSwish   1525                            FLOAT     (256)           | 0xfde8cd00 0xfde8d100 0x00000400
D RKNN: [09:32:38.515] 144 ConvExSwish   1527                            FLOAT16   (256,256,3,3)   | 0xfde8d100 0xfdfad100 0x00120000
D RKNN: [09:32:38.515] 144 ConvExSwish   1528                            FLOAT     (256)           | 0xfdfad100 0xfdfad500 0x00000400
D RKNN: [09:32:38.515] 146 ConvExSwish   1530                            FLOAT16   (256,256,1,1)   | 0xfdfad500 0xfdfcd500 0x00020000
D RKNN: [09:32:38.515] 146 ConvExSwish   1531                            FLOAT     (256)           | 0xfdfcd500 0xfdfcd900 0x00000400
D RKNN: [09:32:38.515] 147 ConvExSwish   1533                            FLOAT16   (256,256,3,3)   | 0xfdfcd900 0xfe0ed900 0x00120000
D RKNN: [09:32:38.515] 147 ConvExSwish   1534                            FLOAT     (256)           | 0xfe0ed900 0xfe0edd00 0x00000400
D RKNN: [09:32:38.515] 150 ConvExSwish   1539                            FLOAT16   (512,512,1,1)   | 0xfe12e100 0xfe1ae100 0x00080000
D RKNN: [09:32:38.515] 150 ConvExSwish   1540                            FLOAT     (512)           | 0xfe1ae100 0xfe1ae900 0x00000800
D RKNN: [09:32:38.515] 151 ConvExSwish   1542                            FLOAT16   (1024,512,3,3)  | 0xfe1ae900 0xfeaae900 0x00900000
D RKNN: [09:32:38.515] 151 ConvExSwish   1543                            FLOAT     (1024)          | 0xfeaae900 0xfeaaf900 0x00001000
D RKNN: [09:32:38.515] 152 ConvExSwish   1545                            FLOAT16   (512,1024,1,1)  | 0xfeaaf900 0xfebaf900 0x00100000
D RKNN: [09:32:38.515] 152 ConvExSwish   1546                            FLOAT     (512)           | 0xfebaf900 0xfebb0100 0x00000800
D RKNN: [09:32:38.515] 153 ConvExSwish   1566                            FLOAT16   (512,1024,1,1)  | 0xffab3100 0xffbb3100 0x00100000
D RKNN: [09:32:38.515] 153 ConvExSwish   1567                            FLOAT     (512)           | 0xffbb3100 0xffbb3900 0x00000800
D RKNN: [09:32:38.515] 154 ConvExSwish   1548                            FLOAT16   (512,512,1,1)   | 0xfebb0100 0xfec30100 0x00080000
D RKNN: [09:32:38.515] 154 ConvExSwish   1549                            FLOAT     (512)           | 0xfec30100 0xfec30900 0x00000800
D RKNN: [09:32:38.515] 155 ConvExSwish   1551                            FLOAT16   (512,512,3,3)   | 0xfec30900 0xff0b0900 0x00480000
D RKNN: [09:32:38.515] 155 ConvExSwish   1552                            FLOAT     (512)           | 0xff0b0900 0xff0b1100 0x00000800
D RKNN: [09:32:38.515] 157 ConvExSwish   1554                            FLOAT16   (512,512,1,1)   | 0xff0b1100 0xff131100 0x00080000
D RKNN: [09:32:38.515] 157 ConvExSwish   1555                            FLOAT     (512)           | 0xff131100 0xff131900 0x00000800
D RKNN: [09:32:38.515] 158 ConvExSwish   1557                            FLOAT16   (512,512,3,3)   | 0xff131900 0xff5b1900 0x00480000
D RKNN: [09:32:38.515] 158 ConvExSwish   1558                            FLOAT     (512)           | 0xff5b1900 0xff5b2100 0x00000800
D RKNN: [09:32:38.515] 160 ConvExSwish   1560                            FLOAT16   (512,512,1,1)   | 0xff5b2100 0xff632100 0x00080000
D RKNN: [09:32:38.515] 160 ConvExSwish   1561                            FLOAT     (512)           | 0xff632100 0xff632900 0x00000800
D RKNN: [09:32:38.515] 161 ConvExSwish   1563                            FLOAT16   (512,512,3,3)   | 0xff632900 0xffab2900 0x00480000
D RKNN: [09:32:38.515] 161 ConvExSwish   1564                            FLOAT     (512)           | 0xffab2900 0xffab3100 0x00000800
D RKNN: [09:32:38.515] 164 ConvExSwish   1569                            FLOAT16   (1024,1024,1,1) | 0xffbb3900 0xffdb3900 0x00200000
D RKNN: [09:32:38.515] 164 ConvExSwish   1570                            FLOAT     (1024)          | 0xffdb3900 0xffdb4900 0x00001000
D RKNN: [09:32:38.515] 165 ConvExSwish   model.9.conv.conv.weight        FLOAT16   (1280,1024,1,1) | 0xf9d44280 0xf9fc4280 0x00280000
D RKNN: [09:32:38.515] 165 ConvExSwish   model.9.conv.conv.bias          FLOAT     (1280)          | 0xf9fc4280 0xf9fc5680 0x00001400
D RKNN: [09:32:38.515] 166 Conv          GlobalAveragePool_433_2conv0_i1 FLOAT16   (1,1280,7,7)    | 0xffdfaa00 0xffe19400 0x0001ea00
D RKNN: [09:32:38.515] 166 Conv          GlobalAveragePool_433_2conv0_i2 FLOAT     (1280)          | 0xffe19400 0xffe1a800 0x00001400
D RKNN: [09:32:38.515] 167 Conv          GlobalAveragePool_430_2conv0_i1 FLOAT16   (1,1280,7,7)    | 0xffddabc0 0xffdf95c0 0x0001ea00
D RKNN: [09:32:38.515] 167 Conv          GlobalAveragePool_430_2conv0_i2 FLOAT     (1280)          | 0xffdf95c0 0xffdfa9c0 0x00001400
D RKNN: [09:32:38.515] 168 Conv          model.9.linear2.weight          FLOAT16   (1,1280,1,1)    | 0xf9ff1dc0 0xf9ff27c0 0x00000a00
D RKNN: [09:32:38.515] 168 Conv          model.9.linear2.bias            FLOAT     (1)             | 0xf9ff27c0 0xf9ff2800 0x00000040
D RKNN: [09:32:38.515] 169 Conv          GlobalAveragePool_427_2conv0_i1 FLOAT16   (1,1280,7,7)    | 0xffdbad80 0xffdd9780 0x0001ea00
D RKNN: [09:32:38.515] 169 Conv          GlobalAveragePool_427_2conv0_i2 FLOAT     (1280)          | 0xffdd9780 0xffddab80 0x00001400
D RKNN: [09:32:38.515] 170 Conv          model.9.linear.weight           FLOAT16   (71,1280,1,1)   | 0xf9fc5680 0xf9ff1c80 0x0002c600
D RKNN: [09:32:38.515] 170 Conv          model.9.linear.bias             FLOAT     (71)            | 0xf9ff1c80 0xf9ff1dc0 0x00000140
D RKNN: [09:32:38.515] 171 Reshape       Flatten_434_2rs_i1              INT64     (2)             | 0xffe1a800 0xffe1a810 0x00000010
D RKNN: [09:32:38.515] 173 Reshape       1259_mm_tp_rs_i1                INT64     (2)             | 0xffdfa9c0 0xffdfa9d0 0x00000010
D RKNN: [09:32:38.515] 175 Reshape       out_mm_tp_rs_i1                 INT64     (2)             | 0xffddab80 0xffddab90 0x00000010
D RKNN: [09:32:38.525] ----------------------------------------
D RKNN: [09:32:38.525] Total Internal Memory Size: 9996KB
D RKNN: [09:32:38.525] Total Weight Memory Size: 99163.6KB
D RKNN: [09:32:38.525] The RKNN_FLAG_EXECUTE_FALLBACK_PRIOR_DEVICE_GPU is not set and without GPU op in Graphs, OpenCL will not be initialized
W RKNN: [09:32:38.526] query RKNN_QUERY_INPUT_DYNAMIC_RANGE error, rknn model is static shape type, please export rknn with dynamic_shapes
W Query dynamic range failed. Ret code: RKNN_ERR_MODEL_INVALID. (If it is a static shape RKNN model, please ignore the above warning message.)
W The input[0] need NHWC data format, but NCHW set, the data format and data buffer will be changed to NHWC.
W The input[1] need NHWC data format, but NCHW set, the data format and data buffer will be changed to NHWC.
D RKNN: [09:32:38.528] allocated memory, name: in, virt addr: 0x7f85328000, dma addr: 0xf9335000, obj addr: 0xffffff8142b52800, size: 301056, aligned size: 303104, fd: 7, handle: 4                          , flags: 0x403, gem name: 4, iommu domain id: 0
D RKNN: [09:32:38.529] allocated memory, name: in_T, virt addr: 0x7f6e4a8000, dma addr: 0xf92eb000, obj addr: 0xffffff8142b55400, size: 301056, aligned size: 303104, fd: 8, handle:                           5, flags: 0x403, gem name: 5, iommu domain id: 0
D RKNN: [09:32:38.529] allocated memory, name: out, virt addr: 0x7f88e26000, dma addr: 0xf92ea000, obj addr: 0xffffff8142b56c00, size: 192, aligned size: 4096, fd: 9, handle: 6, fl                          ags: 0x403, gem name: 6, iommu domain id: 0
D RKNN: [09:32:38.529] allocated memory, name: 1259, virt addr: 0x7f88e25000, dma addr: 0xf92e9000, obj addr: 0xffffff8142b52c00, size: 64, aligned size: 4096, fd: 10, handle: 7, f                          lags: 0x403, gem name: 7, iommu domain id: 0
D RKNN: [09:32:38.529] allocated memory, name: 1261, virt addr: 0x7f88e24000, dma addr: 0xf92e8000, obj addr: 0xffffff8142b53400, size: 2560, aligned size: 4096, fd: 11, handle: 8,                           flags: 0x403, gem name: 8, iommu domain id: 0
D RKNN: [09:32:38.529] enable argb mode, dtype: FLOAT, channel: 3
D RKNN: [09:32:38.529] update cvt sign: 0
D RKNN: [09:32:38.529] normalize target: CPU
D RKNN: [09:32:38.531] enable argb mode, dtype: FLOAT, channel: 3
D RKNN: [09:32:38.531] update cvt sign: 0
D RKNN: [09:32:38.531] normalize target: CPU
W RKNN: [09:32:38.534] Failed to get NPU freq, take 1000MHz as default NPU freq
D RKNN: [09:32:38.534] Get DDR frequency: 528MHz
段错误 (核心已转储)
GMT+8, 2025-12-14 11:38 , Processed in 0.110198 second(s), 28 queries , Gzip On.
