查看: 19054|回复: 4
求助:IAR 软件一开工程即出“ multiply defined”问题
发表于 2014-6-8 15:12:03 | 显示全部楼层 |阅读模式
刚学软件,依视频教程安装IAR软件(管理员方式安装),并打开第二章例程的 GPIO_LED 时出现错误:请教什么原因。电脑win7 64位。安装的是 IAR 6.3版本的。其错误提示如下:(错误提示很长很长,但是都是一个原因)
  1. Sun Jun 08, 2014 13:55:40: Register/sfr 'NV_FOPT.RESERVED' multiply defined. Extra definitions are ignored.
  2. Sun Jun 08, 2014 13:55:40: Register/sfr 'NV_FOPT.RESERVED' multiply defined. Extra definitions are ignored.
  3. Sun Jun 08, 2014 13:55:40: Register/sfr 'NV_FOPT.RESERVED' multiply defined. Extra definitions are ignored.
  4. Sun Jun 08, 2014 13:55:40: Register/sfr 'NV_FOPT.RESERVED' multiply defined. Extra definitions are ignored.
  5. Sun Jun 08, 2014 13:55:40: Register/sfr 'NV_FOPT.RESERVED' multiply defined. Extra definitions are ignored.
  6. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_MPRA.RESERVED' multiply defined. Extra definitions are ignored.
  7. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_MPRA.RESERVED' multiply defined. Extra definitions are ignored.
  8. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_MPRA.RESERVED' multiply defined. Extra definitions are ignored.
  9. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_MPRA.RESERVED' multiply defined. Extra definitions are ignored.
  10. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_MPRA.RESERVED' multiply defined. Extra definitions are ignored.
  11. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_MPRA.RESERVED' multiply defined. Extra definitions are ignored.
  12. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_MPRA.RESERVED' multiply defined. Extra definitions are ignored.
  13. Sun Jun 08, 2014 13:55:40: Register/sfr 'AIPS0_PACRA.RESERVED' multiply defined. Extra definitions are ignored.
发表于 2014-6-8 15:18:02 | 显示全部楼层
重复定义了,看看你是不是把两个相同的文件加入到工程了
发表于 2014-6-8 15:32:45 | 显示全部楼层
没关系了,不影响使用
 楼主| 发表于 2014-6-8 16:49:51 | 显示全部楼层
山外メ雲ジ 发表于 2014-6-8 15:32
没关系了,不影响使用
非常感谢!
 楼主| 发表于 2014-6-8 16:50:10 | 显示全部楼层
谢谢了,我看看
GMT+8, 2025-12-14 20:55 , Processed in 0.045870 second(s), 24 queries , Gzip On.
