查看: 21002|回复: 1
对话框最大化
发表于 2014-6-15 16:48:10 | 显示全部楼层 |阅读模式
我建立的对话框 触摸正常 但对话框最大化最小化 不能实现,请问什么问题,用UCGUI BUILDER 调试能最大化,也能最小化 ,但是移植到开发板 最大化,最小化就不能用了,请问什么问题?代码如下:
**                      uCGUIBuilder                            **
**                  Version:   4.0.0.0                          **
**                     2012 / 04                               **
**                   CpoyRight to: wyl                          **
**              Email:ucguibuilder@163.com                        **
**          This text was Created by uCGUIBuilder               **
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
#include "WM.h"
#include "BUTTON.h"
#include "CHECKBOX.h"
#include "DROPDOWN.h"
#include "EDIT.h"
#include "FRAMEWIN.h"
#include "LISTBOX.h"
#include "MULTIEDIT.h"
#include "RADIO.h"
#include "SLIDER.h"
#include "TEXT.h"
#include "PROGBAR.h"
#include "SCROLLBAR.h"
#include "LISTVIEW.h"
WM_HWIN  handle;
//EventsFunctionList
//EndofEventsFunctionList
*       static data
*       Dialog resource
* This table conatins the info required to create the dialog.
* It has been created by ucGUIbuilder.
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
    { FRAMEWIN_CreateIndirect,  "Caption",           0,                       0,  0,  320,240,FRAMEWIN_CF_MOVEABLE,0},
    { BUTTON_CreateIndirect,    "BUTTON0",           GUI_ID_BUTTON0,          90, 65, 88, 31, 0,0}
**      FunctionName:void PaintDialog(WM_MESSAGE * pMsg)
**      Function: to initialize the Dialog items
**      call this function in _cbCallback --> WM_PAINT
    WM_HWIN hWin = pMsg->hWin;
**      FunctionName:void InitDialog(WM_MESSAGE * pMsg)
**      call this function in _cbCallback --> WM_INIT_DIALOG
    //FRAMEWIN
    FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
    FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
    FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
*       Dialog callback routine
static void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
        case WM_PAINT:
            PaintDialog(pMsg);
            break;
        case WM_INIT_DIALOG:
            InitDialog(pMsg);
            break;
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                    break;
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
                    break;
            break;
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                    break;
                case GUI_ID_CANCEL:
                    break;
            break;
        default:
            WM_DefaultProc(pMsg);
*       MainTask
void MainTask(void)
    GUI_Init();
    WM_SetDesktopColor(GUI_WHITE);      /* Automacally update desktop window */
    WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
    //PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
    //FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
    //BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
    //CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
    //DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
    //SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
    //SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
    //HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
    //RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
    //GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
handle = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
FRAMEWIN_SetMoveable(handle,0);
GUI_TOUCH_Exec();
GUI_Exec();
发表于 2014-6-15 16:49:56 | 显示全部楼层
好像是framewin才可以最大化最小化,对话框好像不行
GMT+8, 2025-12-14 11:35 , Processed in 0.041928 second(s), 24 queries , Gzip On.
