查看: 22001|回复: 2
火哥那个stm32的pwm输出为什么设置为静态函数啊
发表于 2014-7-2 22:59:14 | 显示全部楼层 |阅读模式
[code=c]
[/code]
  1. /*
  2. * º¯ÊýÃû£ºTIM3_Mode_Config
  3. * ÃèÊö  £ºÅäÖÃTIM3Êä³öµÄPWMÐźŵÄģʽ£¬ÈçÖÜÆÚ¡¢¼«ÐÔ¡¢Õ¼¿Õ±È
  4. * ÊäÈë  £ºÎÞ
  5. * Êä³ö  £ºÎÞ
  6. * µ÷Óà £ºÄÚ²¿µ÷ÓÃ
  7. */
  8. static void TIM3_Mode_Config(void)
  9. {
  10.   TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  11.   TIM_OCInitTypeDef  TIM_OCInitStructure;
  12.   /* PWMÐźŵçƽÌø±äÖµ */
  13.   u16 CCR1_Val = 500;
  14.   u16 CCR2_Val = 375;
  15.   u16 CCR3_Val = 250;
  16.   u16 CCR4_Val = 125;
  17. /* -----------------------------------------------------------------------
  18.     TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
  19.     TIM3CLK = 72 MHz, Prescaler = 0x0, TIM3 counter clock = 72 MHz
  20.     TIM3 ARR Register = 999 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
  21.     TIM3 Frequency = 72 KHz.
  22.     TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
  23.     TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
  24.     TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
  25.     TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
  26.   ----------------------------------------------------------------------- */
  27.   /* Time base configuration */
  28.   TIM_TimeBaseStructure.TIM_Period = 999;       //µ±¶¨Ê±Æ÷´Ó0¼ÆÊýµ½999£¬¼´Îª1000´Î£¬ÎªÒ»¸ö¶¨Ê±ÖÜÆÚ
  29.   TIM_TimeBaseStructure.TIM_Prescaler = 0;      //ÉèÖÃÔ¤·ÖƵ£º²»Ô¤·ÖƵ£¬¼´Îª72MHz
  30.   TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;  //ÉèÖÃʱÖÓ·ÖƵϵÊý£º²»·ÖƵ
  31.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //ÏòÉϼÆÊýģʽ
  32.   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  33.   /* PWM1 Mode configuration: Channel1 */
  34.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;      //ÅäÖÃΪPWMģʽ1
  35.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  36.   TIM_OCInitStructure.TIM_Pulse = CCR1_Val;     //ÉèÖÃÌø±äÖµ£¬µ±¼ÆÊýÆ÷¼ÆÊýµ½Õâ¸öֵʱ£¬µçƽ·¢ÉúÌø±ä
  37.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //µ±¶¨Ê±Æ÷¼ÆÊýֵСÓÚCCR1_ValʱΪ¸ßµçƽ
  38.   TIM_OC1Init(TIM3, &TIM_OCInitStructure);   //ʹÄÜͨµÀ1
  39.   TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  40.   /* PWM1 Mode configuration: Channel2 */
  41.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  42.   TIM_OCInitStructure.TIM_Pulse = CCR2_Val;    //ÉèÖÃͨµÀ2µÄµçƽÌø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  43.   TIM_OC2Init(TIM3, &TIM_OCInitStructure);    //ʹÄÜͨµÀ2
  44.   TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  45.   /* PWM1 Mode configuration: Channel3 */
  46.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  47.   TIM_OCInitStructure.TIM_Pulse = CCR3_Val;  //ÉèÖÃͨµÀ3µÄµçƽÌø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  48.   TIM_OC3Init(TIM3, &TIM_OCInitStructure);   //ʹÄÜͨµÀ3
  49.   TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  50.   /* PWM1 Mode configuration: Channel4 */
  51.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  52.   TIM_OCInitStructure.TIM_Pulse = CCR4_Val;  //ÉèÖÃͨµÀ4µÄµçƽÌø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  53.   TIM_OC4Init(TIM3, &TIM_OCInitStructure);  //ʹÄÜͨµÀ4
  54.   TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  55.   TIM_ARRPreloadConfig(TIM3, ENABLE);       // ʹÄÜTIM3ÖØÔؼĴæÆ÷ARR
  56.   /* TIM3 enable counter */
  57.   TIM_Cmd(TIM3, ENABLE);                   //ʹÄܶ¨Ê±Æ÷3
  58. }
发表于 2014-7-2 23:00:16 | 显示全部楼层
这是什么代码。。。。
一般来说,没有被外部文件调用的函数都可以设置成静态函数,但不设置成静态函数也没问题
 楼主| 发表于 2014-7-2 23:02:54 | 显示全部楼层
羊舌悦 发表于 2014-7-2 23:00
这是什么代码。。。。
一般来说,没有被外部文件调用的函数都可以设置成静态函数,但不设置成静态函数也 ...
我想在主函数里条用这个pwm函数,不能设置成静态函数吧
GMT+8, 2024-11-24 12:04 , Processed in 0.028928 second(s), 23 queries , Gzip On.
