学前班
最后登录1970-1-1
在线时间 小时
注册时间2014-7-19
/*Include---------------------------*/
#include"stm32f10x_lib.h" //包含所有的头文件
#include<stdio.h>
//----------------函数声明--------------------
void Delay_MS(u16 dly);
void RCC_Configuration(void);
void GPIO_Configuration(void);
void USART1_Configuration(void);
void SYSTICK_Configuration(void);
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
#ifdef DEBUG
debug();
#endif
u8 sec,min;
u16 RxData;
//u8 ID_num[12];
//u16 data;
//------------初始化------------
RCC_Configuration();
SYSTICK_Configuration();
GPIO_Configuration();
USART1_Configuration();
sec=20;
min=1;
/* printf("\nThe ID: \n");
for(i=0;i<12;i++)
ID_num[i] = *(u8 *)(0x1FFFF7E9+i);
printf("%x",ID_num[i]);
//ID 是否等于 ffd3e4324b38388127143ff 如果等于置标志flag=1
printf("\t The time is : \n");
FlagStatus Status;
Status = SysTick_GetFlagStatus(SysTick_FLAG_COUNT);
RxData = USART_ReceiveData(USART1);
if(RxData!=0)
if(Status == RESET)
if(sec==60)
sec=0;
min++;
sec++;
printf("\t %d:%d",min,sec);
printf("\t %d",RxData);
* Function Name : Delay_Ms
* Description : delay 1 ms.
* Input : dly (ms)
* Output : None
* Return : None
u16 i,j;
for(i=0;i<dly;i++)
for(j=1000;j>0;j--);
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
//----------使用外部RC晶振-----------
RCC_DeInit(); //初始化为缺省值
RCC_HSEConfig(RCC_HSE_ON); //使能外部的高速时钟
while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET); //等待外部高速时钟使能就绪
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
FLASH_SetLatency(FLASH_Latency_2); //Flash 2 wait state
RCC_HCLKConfig(RCC_SYSCLK_Div1); //HCLK = SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); //PCLK2 = HCLK
RCC_PCLK1Config(RCC_HCLK_Div2); //PCLK1 = HCLK/2
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); //PLLCLK = 8MHZ * 9 =72MHZ
RCC_PLLCmd(ENABLE); //Enable PLLCLK
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLLCLK is ready
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock
while(RCC_GetSYSCLKSource()!=0x08); //Wait till PLL is used as system clock source
//---------打开相应外设时钟--------------------
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE); //使能APB2外设的GPIOA的时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
* Function Name : GPIO_Configuration
* Description : 初始化GPIO外设
* Input : None
* Output : None
* Return : None
GPIO_InitTypeDef GPIO_InitStructure; //声明一个结构体变量
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //选择PC.10(TXD) 和 PC.11
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //输出模式为复用推挽输出
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化GPIOC寄存器
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //选择PC.10(TXD) 和 PC.11(RXD) //管脚频率为50MHZ
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //输出模式为浮空输入
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化GPIOA寄存器
//将USART3的TXD和RXD重映射到PC10和pc11
//GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE);
USART_InitTypeDef U3;
U3.USART_BaudRate =9600;
U3.USART_WordLength = USART_WordLength_8b;
U3.USART_StopBits = USART_StopBits_1;
U3.USART_Parity = USART_Parity_No;
U3.USART_Mode = USART_Mode_Rx|USART_Mode_Tx;
U3.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_Init(USART1, &U3);
USART_Cmd(USART1,ENABLE);
* Function Name : SYSTICK_Configuration
* Description : 初始化SYSTICK系统定时器
* Input : None
* Output : None
* Return : None
SysTick_CounterCmd(SysTick_Counter_Disable);
SysTick_ITConfig(DISABLE);
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_DiARM);
SysTick_SetReload(9000*1000);
SysTick_CounterCmd(SysTick_Counter_Enable);
* Function Name : fputc
* Description : 重定向这个C库(stdio)printf函数 文件流——》串口USART1
* Input : ch,*f
* Output : None
* Return : None
int fputc(int ch,FILE *f)
//ch送给USART1
USART_SendData(USART1, ch);
//等待发送完毕
while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET) ;
//返回ch
return(ch);
