查看: 19507|回复: 2
为什么LED初始化函数最后早关LED?
发表于 2014-7-25 10:17:59 | 显示全部楼层 |阅读模式
void LED_GPIO_Config(void)
        /*define a GPIO_InitTypeDef type structure*/
        /*Open the fpCLK of the GPIOB,GPIOF */
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOF,ENABLE);
        /*Select the under control Pin_GPIOB_0*/
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_0;
        /*Setting the pin mode as Push pull output */
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
        /*Setting the pin speed as 50MHz*/
        /*Call Library Function to initialize the GPIOB0*/
        /*Close all LED lights*/
        GPIO_SetBits(GPIOB, GPIO_Pin_0);
最后的        /*Close all LED lights*/
        GPIO_SetBits(GPIOB, GPIO_Pin_0);  起什么作用》??
发表于 2014-7-25 10:30:28 | 显示全部楼层
就是关闭led。。防止在初始化完成后,它就自己亮了
 楼主| 发表于 2014-7-25 10:35:59 | 显示全部楼层
强烈支持,非常感谢哥们
GMT+8, 2024-11-27 17:27 , Processed in 0.028776 second(s), 23 queries , Gzip On.
