查看: 23136|回复: 3
I2C的程序中,I2C_EE_BufferWrite函数里面Addr这个变量是用来干啥的?
发表于 2014-8-18 16:41:52 | 显示全部楼层 |阅读模式
void I2C_EE_BufferWrite(u8* pBuffer, u8 WriteAddr, u16 NumByteToWrite)
  u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
  Addr = WriteAddr % I2C_PageSize;
  count = I2C_PageSize - Addr;
  NumOfPage =  NumByteToWrite / I2C_PageSize;
  NumOfSingle = NumByteToWrite % I2C_PageSize;
  /* If WriteAddr is I2C_PageSize aligned  */
  if(Addr == 0)
    /* If NumByteToWrite < I2C_PageSize */
    if(NumOfPage == 0)
      I2C_EE_PageWrite(pBuffer, WriteAddr, NumOfSingle);
      I2C_EE_WaitEepromStandbyState();
    /* If NumByteToWrite > I2C_PageSize */
      while(NumOfPage--)
        I2C_EE_PageWrite(pBuffer, WriteAddr, I2C_PageSize);
        WriteAddr +=  I2C_PageSize;
        pBuffer += I2C_PageSize;
      if(NumOfSingle!=0)
  /* If WriteAddr is not I2C_PageSize aligned  */
    if(NumOfPage== 0)
      NumByteToWrite -= count;
      if(count != 0)
        I2C_EE_PageWrite(pBuffer, WriteAddr, count);
        WriteAddr += count;
        pBuffer += count;
      while(NumOfPage--)
      if(NumOfSingle != 0)
直接上程序吧
发表于 2014-8-18 16:43:07 | 显示全部楼层
存储要写入的地址,在EEPROM某页内的地址,看这句就知道了:Addr = WriteAddr % I2C_PageSize;
 楼主| 发表于 2014-8-19 09:50:08 | 显示全部楼层
谢谢  那么WriteAddr是什么,也是一个地址吧?
发表于 2014-8-19 09:55:14 | 显示全部楼层
WriteAddr是外部传入的形参,要写入的逻辑地址
GMT+8, 2024-11-24 14:12 , Processed in 0.026044 second(s), 23 queries , Gzip On.
