查看: 17451|回复: 1
出现警告的原因,不懂啊
发表于 2014-10-8 11:03:37 | 显示全部楼层 |阅读模式
#define LCD_CS(x)   GPIO_WriteBit(GPIOE, GPIO_Pin_0, x)
#define LCD_RESET(x) GPIO_WriteBit(GPIOE, GPIO_Pin_1, x)
#define LCD_AO(x)   GPIO_WriteBit(GPIOE, GPIO_Pin_2, x)
#define LCD_SCL(x)   GPIO_WriteBit(GPIOE, GPIO_Pin_3, x)
#define LCD_SI(x)  GPIO_WriteBit(GPIOE, GPIO_Pin_4, x)
以上部分是宏定义
但是在使用的时候就出现警告
void Write_Command(uint8_t command)
int i,j;
j=0x80;
LCD_CS(0);           //CS=0;
LCD_AO(0);           //CD=0;
for(i=0;i<8;i++)
  LCD_SCL(0);      //SCL=0;
  if(command&j)
   LCD_SI(1);   //SDA=1;
   LCD_SI(0);   //SDA=0;
  LCD_SCL(1);      //SCL=1;
  j=j>>1;
LCD_CS(1);           //CS=1;
出现的警告如下所示:
..\..\User\lcd12864\lcd12864.c(58): warning:  #188-D: enumerated type mixed with another type
..\..\User\lcd12864\lcd12864.c:         LCD_CS(0);           //CS=0;
..\..\User\lcd12864\lcd12864.c:         ^
求大神们帮忙看看啊
发表于 2014-10-8 15:45:05 | 显示全部楼层
重复定义了吧,应该是宏重复定义了,而且定义的数字不一样
GMT+8, 2024-11-23 08:00 , Processed in 0.028794 second(s), 23 queries , Gzip On.
