查看: 14539|回复: 2
SD卡+FATFS文件系统出错
发表于 2015-1-2 22:55:30 | 显示全部楼层 |阅读模式
照着野火带文件系统的程序写了一编,下载到板子里面,发现操作失败,后来又把野火的程序编译下载进去,还是不行,出错的地方在f_open,返回值是13, There is no valid FAT volume on the physical drive
   /* USART1 config */
                USART1_Config();
                printf("\r\n this is a fatfs test demo \r\n");
                /* Sdio Interrupt Config */
                NVIC_Configuration();
                /* Register work area for each volume (Always succeeds regardless of disk status) */
                res = f_mount(0,&fs);
        //res = f_mkfs(0,0,_MAX_SS);有人说要加这个  格式化,可是我加了  这里就会出错,返回1
//                f_mkdir("sub");
//                f_mkdir("sub/sub1");
                /* function disk_initialize() has been called in f_open */
                /* Create new file on the drive 0 */
                res = f_open(&fnew, "0:newfile.txt", FA_CREATE_ALWAYS | FA_WRITE );//res =13, There is no valid FAT volume on the physical drive 就是这里有问题
                if ( res == FR_OK )
                        res = f_write(&fnew, textFileBuffer, sizeof(textFileBuffer), &bw);
                        f_close(&fnew);
                res = f_open(&fnew, "0:newfile.txt", FA_OPEN_EXISTING | FA_READ);
                res = f_read(&fnew, buffer, sizeof(buffer), &br);
                printf("\r\n erere %s ", buffer);
                /* Close open files */
                f_close(&fnew);
    /* Unregister work area prior to discard it */
    f_mount(0, NULL);
                while(1);
 楼主| 发表于 2015-1-3 23:22:19 | 显示全部楼层
没人知道吗,为什么会是13这里 res = f_open(&fnew, "0:newfile.txt", FA_CREATE_ALWAYS | FA_WRITE );//res =13, There is no valid FAT volume on the physical drive 就是这里有问题
 楼主| 发表于 2015-1-4 23:18:57 | 显示全部楼层
问题以解决  把SD格式化
GMT+8, 2024-11-26 19:11 , Processed in 0.032411 second(s), 23 queries , Gzip On.
