高中生
最后登录1970-1-1
在线时间 小时
注册时间2015-1-22
const uint16_t Sine12bit[32] = {
2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056,
3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909,
599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647};
const uint16_t Tri12bit[32] = {
0, 0, 0, 0, 0, 0, 0, 0, 200, 400,
600, 800, 1000, 1200, 1400, 1600, 1800, 2000, 2200, 2400,
2600, 2800, 3000, 3200, 3400, 3600, 3800, 4000, 3000, 2000, 1000, 0};
const uint16_t Sta12bit[32] = {
1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000,
1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000};
uint32_t DualSine12bit[32];
* @brief 使能DAC的时钟,初始化GPIO
* @param 无
* @retval 无
static void DAC_Config(void)
DAC_InitTypeDef DAC_InitStructure;
/* 使能GPIOA时钟 */
/* 使能DAC时钟 */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
/* DAC的GPIO配置,模拟输入 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
/* 配置DAC 通道1 */
DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO; //使用TIM2作为触发源
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; //不使用波形发生器
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; //不使用DAC输出缓冲
DAC_Init(DAC_Channel_1, &DAC_InitStructure);
/* 配置DAC 通道2 */
DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO; //使用TIM6作为触发源
DAC_Init(DAC_Channel_2, &DAC_InitStructure);
DAC_SetChannel1Data(DAC_Align_12b_R, 0x0000);
DAC_SetChannel2Data(DAC_Align_12b_R, 0x0000);
/* 使能通道1 由PA4输出 */
DAC_Cmd(DAC_Channel_1, ENABLE);
/* 使能通道2 由PA5输出 */
DAC_Cmd(DAC_Channel_2, ENABLE);
/* 使能DAC的DMA请求 */
DAC_DMACmd(DAC_Channel_2, ENABLE);
DAC_DMACmd(DAC_Channel_1, ENABLE);
//DAC_DualSoftwareTriggerCmd(ENABLE);
* @brief 配置TIM
* @param 无
* @retval 无
static void DAC_TIM2_Config(void)
/* 使能TIM2时钟 */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
/* TIM2基本定时器配置 */
// TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = 19; //定时周期 20
TIM_TimeBaseStructure.TIM_Prescaler = 0x0; //预分频,不分频
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; //时钟分频系数
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* 配置TIM2触发源 */
TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
/* 使能TIM2 */
TIM_Cmd(TIM2, ENABLE);
static void DAC_TIM6_Config(void)
/* 使能TIM6时钟 */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
/* TIM6基本定时器配置 */
TIM_TimeBaseStructure.TIM_Period = 39; //定时周期 40
TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
/* 配置TIM6触发源 */
TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
/* 使能TIM2 */
TIM_Cmd(TIM6, ENABLE);
* @brief 配置DMA
* @param 无
* @retval 无
static void DAC2_DMA_Config(void)
/* 使能DMA2时钟 */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
/* 配置DMA2 */
DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40007414; //外设数据地址DAC_DHR12R2
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&Tri12bit ; //内存数据地址 Tri12bit
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //数据传输方向内存至外设
DMA_InitStructure.DMA_BufferSize = 32; //缓存大小为32字节
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设数据地址固定
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存数据地址自增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //外设数据以字为单位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //内存数据以字为单位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环模式
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //高DMA通道优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //非内存至内存模式
DMA_Init(DMA2_Channel4, &DMA_InitStructure);
/* 使能DMA2-14通道 */
DMA_Cmd(DMA2_Channel4, ENABLE);
static void DAC1_DMA_Config(void)
/* 使能DMA2时钟 */
/* 配置DMA2 */
DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40007408; //外设数据地址DAC_DHR12R1
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&Sine12bit ; //内存数据地址 Sine12bit
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //高DMA通道优先级
DMA_Init(DMA2_Channel3, &DMA_InitStructure);
/* 使能DMA2-13通道 */
DMA_Cmd(DMA2_Channel3, ENABLE);
* @brief DAC初始化函数
* @param 无
* @retval 无
void DAC_Mode_Init(void)
//uint32_t Idx = 0;
DAC_Config();
DAC_TIM6_Config();
DAC2_DMA_Config();
DAC_TIM2_Config();
DAC1_DMA_Config();
/* 填充正弦波形数据,双通道右对齐*/
//for (Idx = 0; Idx < 32; Idx++)
// DualSine12bit[Idx] = (Sine12bit[Idx] << 16) + (Sine12bit[Idx]);
DAC1由TIME2控制,DMA2CH3通道传输数据至DAC_DHR12R1寄存器,地址0x40007408。写入的数据为正弦波。
DAC2由TIME6控制,DMA2CH4通道传输数据至DAC_DHR12R2寄存器,地址0x40007414。写入的数据为锯齿波。
想要分别产生不同频率的正弦波与锯齿波。 分别只配置各自通道时,两通道都能产生各自的波形。
​问题有两个:
1.无论单独配置任一通道,未配置的通道也产生波形且与被配置通道波形一样;
​2.两通道同时打开时,无法独立输出两个波形,有明显的干扰,但两通道输出结果一样。
求解,会不会是后续电路对输出有影响?
