查看: 27608|回复: 17
问几个问题,在 SPI模块 章节的
发表于 2013-8-23 22:04:51 | 显示全部楼层 |阅读模式
一,
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
其中 “ -1 ”是什么意思? 是不是因为 “ \0 ”
二,
在 SPI_FLASH_Init() 函数中
void SPI_FLASH_Init(void)
  SPI_InitTypeDef  SPI_InitStructure;
  /* Enable SPI1 and GPIO clocks */
  /*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
       SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
       and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD, ENABLE); // ??????????????
  /*!< SPI_FLASH_SPI Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  /*!< Configure SPI_FLASH_SPI pins: SCK */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  /*!< Configure SPI_FLASH_SPI pins: MISO */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  /*!< Configure SPI_FLASH_SPI pins: MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  /*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  /* Deselect the FLASH: Chip Select high */
  SPI_FLASH_CS_HIGH();
  /* SPI1 configuration */
  // W25X16: data input on the DIO pin is sampled on the rising edge of the CLK.
  // Data on the DO and DIO pins are clocked out on the falling edge of CLK.
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStructure);
  /* Enable SPI1  */
  SPI_Cmd(SPI1, ENABLE);
其中为什么要使能GPIOD ? 我看没有用到GPIOD啊。
三,
在main() 函数中:
        /* 配置串口1为:115200 8-N-1 */
        USART1_Config();
        printf("\r\n 这是一个2M串行flash(W25X16)实验 \r\n");
        /* 2M串行flash W25X16初始化 */
        SPI_FLASH_Init();
        /* Get SPI Flash Device ID */
        DeviceID = SPI_FLASH_ReadDeviceID();
        Delay( 200 );
        /* Get SPI Flash ID */
        FlashID = SPI_FLASH_ReadID();
        printf("\r\n FlashID is 0x%X,  Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
        /* Check the SPI Flash ID */
        if (FlashID == sFLASH_ID)  /* #define  sFLASH_ID  0xEF3015 */
                printf("\r\n 检测到华邦串行flash W25X16 !\r\n");
                /* Erase SPI FLASH Sector to write on */
                SPI_FLASH_SectorErase(FLASH_SectorToErase);
                /* 将发送缓冲区的数据写到flash中 */
                SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
                printf("\r\n 写入的数据为:%s \r\t", Tx_Buffer);
                /* 将刚刚写入的数据读出来放到接收缓冲区中 */
                SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
                printf("\r\n 读出的数据为:%s \r\n", Tx_Buffer); // ??????????????
                /* 检查写入的数据与读出的数据是否相等 */
                TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
                if( PASSED == TransferStatus1 )
                        printf("\r\n 2M串行flash(W25X16)测试成功!\n\r");
                        printf("\r\n 2M串行flash(W25X16)测试失败!\n\r");
        }// if (FlashID == sFLASH_ID)
                printf("\r\n 获取不到 W25X16 ID!\n\r");
        SPI_Flash_PowerDown();
        while(1);
我感觉应该把“ Tx_Buffer ”换成“ Rx_Buffer ”吧。
发表于 2013-8-23 23:16:59 | 显示全部楼层
BufferSize  你 看看火哥 用在 哪个地方嘛,根据那个地方来分析为啥要减1
发表于 2013-8-23 23:18:58 | 显示全部楼层
好像是没用到 GPIOD  ,你注释一下它,看看能不能运行正常就知道了
发表于 2013-8-23 23:21:05 | 显示全部楼层
发现楼主的细心程度,吓人啊!!!
支持一个
那个应该把“ Tx_Buffer ”换成“ Rx_Buffer ” !明显火哥 粗心了
发表于 2013-8-24 12:32:43 | 显示全部楼层
比妹子还漂亮,赞一个
 楼主| 发表于 2013-8-24 17:51:35 | 显示全部楼层
OK 谢谢哦 我试试
 楼主| 发表于 2013-8-24 17:54:07 | 显示全部楼层
风落小鱼 发表于 2013-8-24 12:32
比妹子还漂亮,赞一个
发表于 2013-8-24 20:40:14 | 显示全部楼层
GPIOD 没用到  可以注释  Tx_Buffer 应该换成 Rx_Buffer  我试过了  可以的  不过我也不大懂第一个问题  你弄明白的话麻烦也告诉我一下  谢谢
 楼主| 发表于 2013-8-24 22:02:00 | 显示全部楼层
楼上男 发表于 2013-8-24 20:40
GPIOD 没用到  可以注释  Tx_Buffer 应该换成 Rx_Buffer  我试过了  可以的  不过我也不大懂第一个问题  你 ...
OK 搞定了通知你
 楼主| 发表于 2013-8-30 16:29:18 | 显示全部楼层
柴柴 发表于 2013-8-24 22:02
OK 搞定了通知你
计算a的成员个数,例如 字符串指针a,
那么a的大小是a指向字符串的长度
*a就是a指向字符串的第一个字符,
countof计算a的字符个数,
个数-1
BufferSize就是所有的字符去掉结束符\n的数量
发表于 2013-8-30 16:40:43 | 显示全部楼层
计算a的成员个数,例如 字符串指针a,
那么a的大小是a ...
你确定?
这里是求数组的长度吧
如果 a 是字符串的指针,那么 sizeof(a) 是求长度吗?不是 strlen 才是求长度吗?
发表于 2013-8-30 17:18:43 | 显示全部楼层
小栋 发表于 2013-8-30 16:40
你确定?
sizeof 字符串地址,结果应该是 4。
如果是 sizeof 数组,这样是 数组 空间
 楼主| 发表于 2013-8-31 16:53:37 | 显示全部楼层
你确定?
      strlen()计算字符数组的字符数,以"\0"为结束判断,不计算为'\0'的数组元素。
      而sizeof计算数据(包括数组、变量、类型、结构体等)所占内存空间,用字节数表示。
 楼主| 发表于 2013-8-31 16:55:43 | 显示全部楼层
昨天回复错了,回复给我自己了,如果没看到了话可以看一下。
发表于 2013-9-3 21:36:00 | 显示全部楼层
但是这样做有什么意义吗?
发表于 2013-9-3 22:09:06 | 显示全部楼层
但是这样做有什么意义吗?
数组元素个数啊!!!
例如你把寄存器配置写到数组里,调用这个宏来求数组元素,就不需要老是手动定义数组元素个数了
发表于 2013-9-4 09:20:04 | 显示全部楼层
格拉姆 发表于 2013-9-3 22:09
数组元素个数啊!!!
例如你把寄存器配置写到数组里,调用这个宏来求数组元素,就不需要老是手动定义数 ...
我是说为什么要 用‘/’呢? 如果不用个的话会怎么样?
发表于 2013-9-4 23:23:48 | 显示全部楼层
不 /sizeof(*(a)) ,是求数组占用的空间
除非 数组是 char 型那样,每个元素占用1个字节,那情况下,才是 数组占用空间 == 数组元素个数
如果数组是 uint32 类型,则每个元素 4字节,不符合条件
GMT+8, 2024-11-23 10:27 , Processed in 0.037594 second(s), 23 queries , Gzip On.
