查看: 10270|回复: 2
大神们帮忙看看,我显示汉子为什么乱码?
发表于 2015-4-4 10:17:31 | 显示全部楼层 |阅读模式
#include "XBF.h"
#include "bsp_led.h"
SD_FONT *ExFont;
SD_FONT SDFont;
static int _cbGetData(U32 Off, U16 NumBytes, void * pVoid, void * pBuffer) {
  FIL hFile;
  UINT  NumBytesRead;
        FRESULT fres;
  hFile = *(FIL *)pVoid;
  // Set file pointer to the requested position
        fres = f_lseek(&hFile, Off) ;
  if (fres != FR_OK) {
    return 1; // Error
  // Read font data
        fres = f_read(&hFile, pBuffer, NumBytes, &NumBytesRead);
    return 1; // Error
  if (NumBytesRead != NumBytes) {
    return 1; // Error
  return 0;   // Ok
void CreateFont(SD_FONT *ExFont)
        FRESULT res;
  res = f_open(&ExFont->hFontFile,XBF_FONT_PATH,FA_READ|FA_OPEN_EXISTING);
        if (res == FR_OK)
                LED2(ON);
        GUI_XBF_CreateFont(        &ExFont->XFont,
        &ExFont->XBF_Data,
        GUI_XBF_TYPE_PROP_AA4_EXT,
        _cbGetData,
        &ExFont->hFontFile);
        /* éèÖÃGUI×Öìå */
        GUI_SetFont(&ExFont->XFont);
        /* éèÖÃÎı¾×Öìå */
        TEXT_SetDefaultFont(&ExFont->XFont);
        /* éèÖÃGUI×Öìå±àÂë */
        GUI_UC_SetEncodeUTF8();
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
    { FRAMEWIN_CreateIndirect,  "Caption",           0,                       0,  0,  240,320,FRAMEWIN_CF_MOVEABLE,0},
    { TEXT_CreateIndirect,      "你好",              GUI_ID_TEXT0,            22, 69, 201,134,0,0}
void PaintDialog(WM_MESSAGE * pMsg)
    WM_HWIN hWin = pMsg->hWin;
void InitDialog(WM_MESSAGE * pMsg)
    //FRAMEWIN
    FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
    FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
    FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
    //GUI_ID_TEXT0
          CreateFont(&SDFont);
          TEXT_SetDefaultFont(&SDFont.XFont);
    TEXT_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_TEXT0),0x0000ff);
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT0),&SDFont.XFont);
static void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
        case WM_PAINT:
            PaintDialog(pMsg);
            break;
        case WM_INIT_DIALOG:
            InitDialog(pMsg);
            break;
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                    break;
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
                    break;
            break;
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                    break;
                case GUI_ID_CANCEL:
                    break;
            break;
        default:
            WM_DefaultProc(pMsg);
void MainTask(void)
    GUI_Init();
    WM_SetDesktopColor(GUI_WHITE);      /* Automacally update desktop window */
    WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
    //PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
    //FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
    //BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
    //CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
    //DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
    //SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
    //SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
    //HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
    //RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
        GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
在main函数调用maintask();
发表于 2015-4-4 16:41:05 | 显示全部楼层
 楼主| 发表于 2015-4-5 14:53:34 | 显示全部楼层
谢谢火哥,我已经搞出来了
GMT+8, 2024-11-24 20:06 , Processed in 0.027004 second(s), 23 queries , Gzip On.
